Old 06-16-2005, 05:49:00 PM   #1
James Edwards
th400 kickdown connection on trans question
Pulled my 400 to have it built. Noticed that the connector on the side of trans which has two spades coming out of it. One toward the floorboards and the other toward the ground. Well the orange wire was connected to the top spade and the other spade was bent down and no wire attached. In fact, there was a black wire that was cut off next to the orange wire.
Trans guy told me the orange wire should have been connected to the bottom spade not the top. What's the deal? Which should it be? If it was correct the way it was, what does the bottom spade do? What about the black wire?
James Edwards is offline   Reply With Quote
Old 06-17-2005, 12:44:00 PM   #2
James Edwards
Anyone have any thoughts????
Old 06-17-2005, 06:15:00 PM   #3
73454
Posts: n/a
Did your kickdown work before you pulled the trans out? Did they mess with the kickdown wiring while it was being built? Usually there's only one wire for the TH400 kickdown, and it usually only has a single prong.
Old 06-18-2005, 04:23:00 PM   #4
James Edwards
I think it was working alright, but now that you ask, I'm unsure. How would I know it it was not working?
I pulled the trans out and took it to the builder. So when I pulled it out is when I notice the cut black wire and that the bottom prong was bent down.
Old 06-18-2005, 06:15:00 PM   #5
79BlueSC
79BlueSC's Avatar
u would know if ur kickdown worked if u were in 3rd...and just romped on it the tranny would knock down into second...generally the black wire is the kickdown wire in my experience...also if its the same on a turbo 350 i'd be willing to crawl under mine and take a look..tell me if its the same and i will
[This message has been edited by 79BlueSC (edited June 18, 2005).]
Eric
1979 Sports Coupe, Z28 Clone, My First Car.
3 Years to get done, but..is it ever REALLY done?
Old enough to know better, Too young to care.
79BlueSC is offline   Reply With Quote
Old 06-18-2005, 06:26:00 PM   #6
James Edwards
Hey I appreciate it, but I really am not sure it is the same. Maybe one of the other members knows?
Old 06-19-2005, 01:00:00 AM   #7
night rider
79BlueSC... Your th-350 wouldnt have a kickdown wire. The th-350 uses a cable from pass. front side of trans up to the carb.
1988 Camaro - 355/th-400, black primer, daily driver
http://community.webshots.com/user/nightrider327
Vid clip of my 1988 camaro idling and reving.. New engine combo
http://www.youtube.com/watch?v=a6kfmy4IQQI
night rider is offline   Reply With Quote
Old 06-19-2005, 11:51:00 AM   #8
79BlueSC
79BlueSC's Avatar
i know how my kickdown works..i actually thought that the 400 was the same my bad...sorry about that hey if u had a 350 i'd be here for ya lol
Eric
Old 06-19-2005, 03:50:00 PM   #9
ZS10
ZS10's Avatar
If I remember right the top spade is the one to connect to 12v+ and put through a switch tripped by the throttle. Just hook it up and try it, if it doesn't kick down try the other spade. If neither work you have to do the manual thing.
73RS/LT/427
Just use a bottle of "New car smell".
ZS10 is offline   Reply With Quote
