Old 11-07-2010, 02:39:53 PM   #1
77nomad
77nomad's Avatar
C5 or SS camaro brakes
I just got a set of front brakes off a 02 Camaro SS from another member, for the low low price of nothin. (love this place) My question is can these be installed the same way as a C5 set up? Is it worth the effort or should I just go with a C5 set up? I could upgrade to the 13" later. I know there are other kits out there from Baer and Wilwood. I'm not interested in aftermarket. I plan on power tour and other long distance trips, so if something fails in BFE I can get parts rather easy.
The rotors are 12" and the calipers are aluminum w/twin pistons. So I would guess they would perform a touch better than a 1le swap.
Other than machining my stock rotor and the bracket deal to bolt the caliper on, is there anything else I would need? Does anyone make a kit for this? Would the brackets from a C5 swap work? I can get those all day on ebay. I am going to research this a little more but thought I'd ask here first.
The bottom line is, toss them on the shelf or toss them on the car? Sorry for all the questions but I don't ask for help very often.
PTFB Comp. Suspension, Control Arms, SFC's, Steering, Bushings, G-Bars and Sway Bars
383 w/ ST10 4 speed (T56 on the floor waiting)
3.73's
LS brakes front and rear
17x 8/ 17x 11 Torque Thrust II's
Every penny!
77nomad is offline   Reply With Quote
Old 11-07-2010, 11:58:21 PM   #2
3_z28camaro
3_z28camaro's Avatar
The C5 Corvette brake swap works very well. I would recommend it to anyone, the cost is low in comparison to other setups and the parts are available to make it almost a bolt on upgrade. Do not really waste your time with the 2002 Camaro brakes. The only thing that can be transferred over is the calipers alone.
All about C5 brakes:
http://www.nastyz28.com/forum/showthread.php?t=74546
1969 Camaro Z/28 clone (LS1/4L60E in waiting), 1971 RS Z/28 clone (C5 Corvette brakes, LT1/4L60E)
http://www.donkeyrescue.org/
3_z28camaro is offline   Reply With Quote
Old 11-08-2010, 12:02:42 AM   #3
Aceshigh
Pimp Micktastic
Aceshigh's Avatar
Ed Miller sells complete C5 front brake swap kits. I bought his setup 3 years ago IIRC.
HUUUUUUUUGE improvement over stock......love it.
You'll need spindle modifications, but he sells those as well.
I wanted no headaches, so I bought everything through him complete.
Brakes, I just don't want to guesswork any machining......my life and kids life is too important to cheap out on it .
http://www.nastyz28.com/forum/showthread.php?t=185616
For those that were cool, Peace.
For those that are douches, sux to be YOU!!!!
Aceshigh is offline   Reply With Quote
Old 11-08-2010, 04:48:11 AM   #4
5spd540's Avatar
What about the rear. What is a good set up for the rear to match the fronts.
Old 11-08-2010, 05:55:44 AM   #5
Aceshigh
Pimp Micktastic
Aceshigh's Avatar
Ed Miller also sells the rear C5 brackets and kits.
Here's his site.
http://www.flynbye.com/
You can price shop / compare and piece it together yourself
or buy a kit from him or Tobin @ Kore 3 which is also popular.
Tobin is a brake genius as well. http://www.kore3.com/
The most complicated part of doing the rear brakes is getting a parking brake.
For that, most people just use S10 rear disc conversions for cheap.
There's plenty of threads in this section to find part #'s and lists.
Old 11-08-2010, 08:54:42 AM   #6
Randy 81
The LS1 rear brakes work well with the C5 fronts, S10 brakes should be a good match as well.
Randy Pajer
81 Camaro CP 41
http://www.nastyz28.com/forum/showthread.php?t=184672
Randy 81 is online now   Reply With Quote
Old 11-08-2010, 09:11:09 AM   #7
77nomad
77nomad's Avatar
I have a whole 35 bucks into shipping.
I read the sticky and I'm sold. Now if Christmas would come and go so I can spend money stuff other than gifts. What to do with the LS parts though?
3.73's
Every penny!
