Old 10-09-2010, 09:11:17 PM   #1
JasonZE
why do my lifters bleed down????
Im still having issues with lifter noise mainly on start up which is making me
This is on my newly built 383 and have run it for a a few rides now and have tried a new set of lifters (sealed power) and changed the oil from running in oil to a racing 25/50 and the new oil did make the hot oil pressure better but still hearing a few lifters tap untill they pump up in the mornings or after sitting for a few hours.
springs measure 110# at installed height and lift is not exceeding the heads
So what else can cause the problem do I try a different brand lifter as much as i dont want to take the intake back off I would if I think it will cure the issue.
Cheers for any insight
Jason.......
JasonZE is offline   Reply With Quote
Old 10-09-2010, 09:58:09 PM   #2
High Country Z
I would try a lighter oil, possibly 10-40, although the lifters shouldn't be bleeding down no matter what oil you use, lighter oil will get to the lifters quicker on start up versus the heavier oil.
"Country Folks Can Survive"...Bocephus - 1981
High Country Z is offline   Reply With Quote
Old 10-10-2010, 08:56:38 AM   #3
meangreen73
Im running sealed power lifters also. I have no problem with them and I also used to run 20-50 oil. I changed to 15-40 cause it still has zinc in it.
73 Camaro
-402 bbc
-TH400 (3500 stall)
-12 bolt 4:10 gear
meangreen73 is offline   Reply With Quote
Old 10-10-2010, 09:32:37 AM   #4
Cardinal
There is no good reason to run a 50 weight oil especially if you live in a cooler climate. IF you do run 50 weight, you have to let the engine warm up completely before doing anything with it.
Today's oils are still better than they were 40 years ago, especially the synthetic and synthetic blends.
As for your lifters bleeding down, I've never experienced your problem. You might try synthetic oil as it sticks to the parts much better than regular oil. I had a 80 Chevette that rattled loudly when it was first started up. At 5K miles I changed the oil to Mobil 1 and the rattle can stopped making noise.
Cardinal
Cardinal is offline   Reply With Quote
Old 10-10-2010, 09:34:09 AM   #5
old blue 75
This is what I did ^ I have speed pro rollers and had one lifter bleed down.
I was running 10-40 oil drop-ed back to 5-30 and it helped a bunch.
1975 camaro
360ci.
291 pocket ported heads1.94/1.5
stock bottom end (cast flat tops)
288/290 108LCA herbert cam
victor jr 750 vac.
st-10 4 speed
10 bolt 4.10 gears
305-60-15 McCreary road stars
old blue 75 is offline   Reply With Quote
Old 10-10-2010, 10:52:11 AM   #6
Philip
that Nova Guy
Philip's Avatar
Use a different oil filter. Try a Wix, NAPA Gold or AC Delco. Just get rid of the orange one.
64 Nova 400 series 350, 700R4, 3.36 rear gear, GM 4 wheel disc
72 Chevelle wagon, 454, 4L80E, 12 bolt 3.31 posi, GM 4 wheel disc
Philip is online now   Reply With Quote
Old 10-10-2010, 03:58:17 PM   #7
meangreen73
^+1
73 Camaro
-402 bbc
-TH400 (3500 stall)
-12 bolt 4:10 gear
Old 10-10-2010, 07:21:33 PM   #8
Rich Schmidt
Mine do it. I have no idea why. 2nd set of sealed power. They use the same lifters on 1.5 ratio smallblocks wiith 110# springs as they do with 1.7:1 ratio bigblocks and 130# springs,so I am pretty sure it has nothing to do with the load of the springs/rockers. Maybe the design of the lifter has excessive clearance.A lifter should not bleed down,and no matter what filter you use,there is never any oil pressure being stored in the system when the engine sits,all the oil runs out the main bearing bores and back into the pan. It seems to be a lifter issue,thats it.
Rich Schmidt is offline   Reply With Quote
Old 10-10-2010, 08:05:56 PM   #9
High Country Z
My DD, 4.3 vortec V-6 was having bleed down issues. I could only get about a thousand miles out of an oil change before the lifters would bleed down overnight. For whatever reason once I switched to Rotella T, never had a bleed down issue again. 3000 + miles between oil changes now, lifters are quiet.
Old 10-10-2010, 10:56:06 PM   #10
Philip
that Nova Guy
Philip's Avatar
Before you condemn the filter idea try it. I have had numerous customers complain of noisy lifters at start up and cured the problems with a good filter. Every one had a colored filter; orange, green and yellow seem to be the worst offenders. I cut open a new Fram and kept it in the shop to show just how poor a filter it is. There was also a cut open WIX next to it to compare. One company spent money on PR and the other on building a quality filter. The difference in price is too small to make a difference to the customer, but big profits for Allied Signal.
Old 10-10-2010, 11:22:00 PM   #11
Rene Melten
Rene Melten's Avatar
Agree, what does the filter have to do with this? It's not a check valve. The lifter is preloaded and should hold. Somebody correct me if I'm wrong.
'73rs 350 .060 over,Super T-10,3.42 Posi,
AFR Heads, 670 Street Avenger, MSD, Hooker,
10 Bolt, Wilwood/GM 4 wheel disc.
http://i930.photobucket.com/albums/a...0.jpg~original
Rene Melten is offline   Reply With Quote
Old 10-11-2010, 02:08:30 AM   #12
JasonZE
i cant see how a filter will do it and i have tried 2 different types already, its like the lifters that were sitting with the valves open overnight bleed down and when i start the engine it fires instantly and within a few seconds the pressure is at 70psi and the noise is gone I just hate having noise from a new engine. if i get bored enough i may try different brand lifters
Old 10-11-2010, 05:31:14 AM   #13
msb80sc
msb80sc's Avatar
When I worked for Chrysler they came out with a bulletin saying not to use Fram filters on the Cummings diesel or you would void your warranty. The problem was particles would break off the filter media and clog the jets spraying oil on the bottom of the pistons.
Hydraulic lifters have check valves and these same particles could get in there and keep the check valve from seating. Then the lifter collapses.
You'll know it's a good car, cause you'll only need one.
1980 Camaro, Streetfighter.
msb80sc is offline   Reply With Quote
