Old 09-21-2010, 05:49:45 PM   #1
bodean
holly street avenger 670
would any one be willing to maby gimme a lil advise on giving me a safe setting to start with this holley 670. concerning my fuel setting screws. just to insure it will even start so i can break this fresh 355 in.carb is new still in box .if someone has the time and feels like it ide say a big thank u to you sir
bodean is offline   Reply With Quote
Old 09-21-2010, 06:24:52 PM   #2
80-z28
I bolted mine on straight from the box and it ran fine, only needed a small adjustment to the idle screws.
Original 350 standard bore
Flat top four valve relief pistons
Brodix IK180 64cc heads
Comp XE274H cam
Performer RPM air-gap intake
Quick Fuel SS680VS carb.
TCI breakaway converter
TH350 trans
Original 3:42 rear end
80-z28 is offline   Reply With Quote
Old 09-21-2010, 06:27:43 PM   #3
bodean
i havent opend mine yet.if i understand u rite are u implying the fuel mixture screws already have a factory set to them or are they closed or open all the way.would a turn an a half be a little to far to start with
Old 09-21-2010, 06:46:01 PM   #4
jthomas
jthomas's Avatar
The Street Avenger carbs are wet flow tested and set at the factory. The settings are very close to what you need right out of the box. Bolt it on and fire it up. Do the initial breakin and then fine tune the carb after that.
jthomas is offline   Reply With Quote
Old 09-21-2010, 07:20:33 PM   #5
bodean
thanks for taking the time.i am curious .if i made the perfect carb selection . heres my engin specs.355 flat top pistons202 heads ported and polished with true roler rockers screw in studs guides as well stock hyd lifters. performer intakeis stock in configureation . cam has .214intake 224 exhaust.. 2000-4500 rpm range. 288 intake 298 exhaust adv. duration. @.050. valve lift 443 intake 465 exhaust lobe c/l 112.
Old 09-21-2010, 07:55:55 PM   #6
CamaroMan79
CamaroMan79's Avatar
You probably could of gotten away with something a little smaller, but that 670 will still be a nice carb for that engine.
1978 Z28: 383 stroker; Scat forged crank and rods, SRP pistons, Comp Cams roller valvetrain, AFR 195 heads, SMI Quadrajet, air-gap intake, 1 3/4" headers, th400 trans
CamaroMan79 is online now   Reply With Quote
Old 09-21-2010, 08:12:37 PM   #7
CorkyE
CorkyE's Avatar
Bolt it on and go... Like said, they're pretty much set out of the box. Buddy of mine has ran one on a 383 in his 'vette for 5 years The idle is a bit high with choke engaged but he refuses to touch it.
Corky
79 Z28 bought new, honeymoon ride same year, still have same wife, same car.
CorkyE is online now   Reply With Quote
Old 09-21-2010, 08:47:22 PM   #8
DesmoEd
Idle screws 1.25 turns out and tune from there with a vacuum gauge
They are set up baseline but it wont hurt to verify settings
Sounds like a good carb selection but tranny and gearing are also important factors as well
"The quality of the kite matters little, success depends upon the man sitting in it"
Manfred von Richthofen - circa 1917
1973 Camaro RS - 355ci, 10.1-1, Perf RPM heads, Howards 280/292 HR, 1.52, Holley 300-36, Holley HP650 DP, MSD, Hedman, M-20, 3:73 posi
1969 Corvette - 360ci, 10.25-1, Perf RPM heads, Comp XR276HR, 1.52, RPM air gap, Holley HP750 DP, MSD, Hooker, TKO600RR, 3:73 posi
DesmoEd is offline   Reply With Quote
Old 09-22-2010, 03:47:24 AM   #9
Most of these carbs do not need a lot of adjusting on them if you have the correct carb for your motor.
Old 09-22-2010, 08:39:22 AM   #10
jayb53guy
jayb53guy's Avatar
X5 on above mentioned. Bolt on and go. I swapped out the spring on mine to make the secondaries open quicker and that was it. Its a good carb butI prefer Demon.
Ask not what your country can do for you, but what can you do for your country.
jayb53guy is offline   Reply With Quote
Old 09-22-2010, 10:38:14 AM   #11
bodean
I cant thank u guys enuff. an forgot to metion its a factory 4 speed car borg warner t 10 .373 gears. I hope im abel to achive my correct timing .using trusty ballancer tape hope she stays on .
Old 09-22-2010, 12:01:45 PM   #12
marlin
Do you text alot................?
marlin is offline   Reply With Quote
Old 09-22-2010, 01:30:12 PM   #13
bodean
yeppers .ny I do..i mean mr. marlin
Old 09-22-2010, 04:31:46 PM   #14
DesmoEd
If thats the case I prob would have gone with a 650 DP - vacuum carbs are great on automatics
Get a book on Holleys and learn the basics - they are very easy to tune if you know the different circuits and how they overlap.
The 670 SA has 2 corner idle - it will only have idle screws on the primary side. Lightly seat each one and count the turns. They should be the same and around 1-1.25 turns out.
Thats a good baseline setting
Let us know how the vacuum carb works on a stick/3:73 car
Old 09-22-2010, 08:27:03 PM   #15
bodean
wonder if jegs will hassel me if I bolt it on an dont like it.then ask if they mind letting me swap it for that 650 dp.just got complete drive traine put bak in tonite .tomorrow will prime it .if all goes well then the pumping up oil preasure. and pullys goes on .trying real hard to fire it thursday nite .wife gone aheadan planed mny wk. end for me .rite when im nearing home base. im laughing my hind end off now
