09-14-2010, 05:59:07 PM
#1
What common hand tools (sizes) for late 2nd gen? Buying tools...
I don't have my car here yet, but I'm getting my toolbox in order for when I go get my '80 from Virginia. What would you say are the most common hand tools you use on your 2nd gen? I've got a pretty well rounded selection of mechanics tools, but I'm looking for comments like "you'll need a high quality 3/4" to break loose that widget" kind of thing. What wrenches or sockets do you reach for the most?
I love hitting the flea market or hunting for tool bargains, so knowing of some things to keep my eyes open for would be greatly appreciated!
Thanks!
1980 Camaro Sport Coupe
 Go Virginia Tech Hokies!
09-14-2010, 06:16:36 PM
#2
BANNED
9/16" wrench
09-14-2010, 06:24:57 PM
#3
3 lb. hammer
09-14-2010, 06:37:09 PM
#4
For tool answers.................
see the tool forum at
www.garagejournal.com
Chuck Sharin
Seattle(area)
CamarosRus@Gmail.com
70 R/S Z-28, 70 SS L-78, 70 R/S SS L-48 (all 4spds)
69 COPO "Recreation"
09-14-2010, 07:10:13 PM
#5
Originally Posted by CamarosRus
I'm already an active member there under the same I.D. Good folks at GJ for sure. Thanks though!
09-14-2010, 07:23:08 PM
#6
Ratcheting box end wrenches.
You've got metric stuff on that 80.
A set of metric crow's foot wrenches will come in handy if you ever mess with the power steering lines.
Otherwise.... a 1/4", 3/8" and 1/2" drive socket set (and some extensions) will handle most of the nuts/bolts on your car.
It's not until you get into rebuilding accesories, steering columns, engines, transmissions and rear ends that you start needing specialty tools.
09-14-2010, 07:25:20 PM
#7
T-50 Torx wrench for removal of seatbelts...Which I still need :P.
09-14-2010, 07:42:54 PM
#8
BANNED
I buy as I go. I have found out that no matter what you have, there is always something that you need!
I find my self always grabbing the 9/16", 1/2", and 7/16" wrenches.
Like mentioned, it seems like 75-80% of the bolts on my car are 3/8"
09-14-2010, 08:30:54 PM
#9
Harbor Freight is your friend when it comes to buying basic tools on the cheap. Most are more than adequate unless you are a mechanic by trade.
I've bought a wide range of stuff from them over the years and been quite satisfied.
09-14-2010, 08:46:03 PM
#10
Personally, I would NOT buy Harbor Freight junk if I wanted tools that will last a lifetime. Most of my tools are Craftsman with a smathering of Snap On, S K Wayne, and Husky tools.
Open end box end wrenches 3/8" to 1", 10 mm to 18 mm
Crescent wrenches 4", 6", 10", 12"
Ball peen hammers: 8 oz, 16 oz, 32 oz.
Soft faced hamers.
Pry bars.
Selection of torx.
Selection of hex key sets.
1/4", 3/8", 1/2" sockets 3/8" to 1" shallow and deep and in metric.
Several p;airs of Vise Grip pliers in all sizes.
A good DVOM (digital volt ohm meter).
A good set of taps and dies (fractional and metric).
Nut drivers.
Drills.
http://www.sears.com/shc/s/p_10153_1...block Type=G4
Cardinal
09-14-2010, 08:56:06 PM
#11
couple cans of PB blaster
grinder with wire wheel
baby sledge (3lb hammer)
cut off wheels for the grinder
09-14-2010, 10:46:45 PM
#12
dead blow or three.
air nibbler is an amazing tool but prolly not neccesary.
bfh
body hammers and dollies (depending on the shape your car is in)
a good welder-see above
cherry picker or chain fall
09-14-2010, 10:47:55 PM
#13
i have HFs pittsburgh brand wrenches and they seem to be a decent tool.
09-14-2010, 10:51:51 PM
#14
1/2 9/16 double box wrench. Comes in handy so much. i have a snapon one i use mainly, but also have a craftsmen version.
1980 Camaro Berlinetta 1979 Camaro Berlinetta w/ T-tops
theflash: Black smoke is generally a sign of running too rich, or you have a diesel.
I want to die in my sleep like my grandfather.... Not screaming and yelling like the passengers in his car.
My nametag says Ryan
09-14-2010, 11:00:12 PM
#15
sears for tools........
| Thread Tools |
| Display Modes |
Linear Mode
