Old 08-25-2010, 03:28:38 PM   #1
BondoSpecial
BondoSpecial's Avatar
Can I use my 320 grit brush hone for cast rings or must I use 180/220
I have 2 hones - a 220 grit 3 stone hone and a 320 grit BRM brush hone. I am going to assemble a recently 30 over block with new rings and I keep reading that cast rings can "tolerate" a rougher hone grit but does that mean that I CAN'T hone them with the 320 grit brush hone? Do they need the rougher finish or is it just a time and cost saving option to not finish them as fine? I like the finish I get with the brush hone better than the stone hone
(pic of 320 BRM brush honed cylinder I did)
I can buy another brush hone @ coarser grit but just wanted to know if there would be any harm in honing @ 320 for cast iron rings
Thanks
Steve
Steven H. www.carfap.com
2011 Infiniti M37X, 2004 Ford F250 6.8 V10 6 speed manual 4x4, 2000 BMW M5, 1999 C1500, 1994 Town Car, 1976 Jeep DJ5
BondoSpecial is offline   Reply With Quote
Old 09-02-2010, 06:49:23 PM   #2
BondoSpecial
anybody?
Old 09-02-2010, 07:46:49 PM   #3
frankz
Are you asking about rebuilder grade rings w/o moly or chrome?
Build it strong so it wont break-and when it does it will be easier to fix........
frankz is offline   Reply With Quote
Old 09-02-2010, 08:08:43 PM   #4
Damon
What you got there looks fine for just about any typical set of rings. You just don't want it perfectly smooth or there's nowhere for oil to grab onto to the bore to keep the rings lubricated.
1990 454SS pickup. Sold, but I think she found herself a good home.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid-high 12s on street rubber, bottom 12s on DRs with the trans left to shift for itself. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 09-02-2010, 08:56:41 PM   #5
BondoSpecial
I am asking about for plain cast, non plated rings (I would only use moly with a fresh bore)
