Old 07-14-2004, 10:50:00 PM   #1
cody
muncie pops out of gear
recently rebuilt muncie never popped out of reverse before now reverse pops out every few seconds and 4th pops out when i let off the gas.is this just a linkage adjustment or something internal..thanks
cody is offline   Reply With Quote
Old 07-15-2004, 01:14:00 AM   #2
70modelz28
mine did the same thing out of like 2nd. the linkage was loose
70modelz28 is offline   Reply With Quote
Old 07-15-2004, 09:01:00 AM   #3
COPO's Avatar
Or syncros are gone or the 3-4 hub assem is worn where the synco locks in. Reverse does not have a syncro.
Mark
1970 Z28
Home Page on 1970 Z28
http://members.rogers.com/mlvd/
[This message has been edited by COPO (edited July 15, 2004).]
[This message has been edited by COPO (edited July 16, 2004).]
Mark
70 Z28, M22, 3.73-Lunati 20120121 Retro Roller Cam
Testing out Brad Penn SAE 30 HP Oil
http://my1970z28.com/COPO/index.htm
Prev Z/28's
1968 Z/28
1971 Z28 4-pd
Z28's I ordered new:
1977 Z28 4-spd w A/C
1978 Z28 4-spd
1980 Z28 4-spd
COPO is online now   Reply With Quote
Old 07-15-2004, 01:44:00 PM   #4
cody
if the 3-4 hub assem. is worn would it cause me to have probs with 3rd gear popping out too?B/C it stays in no matter what,just have probs with reverse when backing up if i dont hold the shifter and 4th when i let off gas.thanks in advance
Old 07-15-2004, 02:04:00 PM   #5
75 400 4 Speed
First step is to get under the car, remove the linkages from the trans. Put an alignment pin in the shifter. Now, place all three shift levers in neutral. Put the linkage up to the hole and turn the joint in or out until it slides in with almost no resistance. Now the nuetral bias of the shifter and the tranny should be aligned.
If you have a Hurst shifter with adjustable shift stops, they could be in too far. With the car off, put the shifter in Reverse, First and Third while watching the shifter plate. If it hits the rear shift stop, you need to back it out until you have about .040 inch clearance give or take a little when you are just eyeballing it. Then shift into Second and Fourth and check the front stop. Adjust accordingly.
If these adjustments don't correc the problem, it is internal.
There is a fine line between hobby and obsession and I think I crossed it!
Click Here: Our Cars
69 SS 350 4 Speed
75 400 4 Speed
93 Z28 6 Speed
[This message has been edited by 75 400 4 Speed (edited July 15, 2004).]
69 SS 350 4 Speed
75 400 4 Speed "Sold"
93 Z28 6 Speed "Sold"
69 L46 4 Speed Corvette Convertible
75 400 4 Speed is offline   Reply With Quote
Old 07-15-2004, 07:03:00 PM   #6
tom3
The reverse deal could be the linkage, reverse arm is easy to get in a bind. The fourth gear can be too much clearance between the input and tail shafts, too thick a gasket at rear of gearbox, or a worn syncro sliding sleeve, or the small teeth on the input shaft. If the tranny was indeed rebuilt all this should be in good shape so hopefully it is the linkage, but not optimistic.
tom3 is offline   Reply With Quote
Old 07-16-2004, 10:33:00 PM   #7
XK1
My first M21 popped out of 4th whenever I let off, then all the time. I ended up replacing the input shaft (4th gear), and the hub assy.
76 Camaro, Blue/Black, .030 350, M21, Z28 body parts.
90 4WD S-10 rustbucket snowbank reducer
XK1 is offline   Reply With Quote
