Go Back   NastyZ28.com > General Topics > Troubleshooting & Diagnosis
Old 07-17-2010, 06:52:03 PM   #1
Camarozzz
454 Correct Intake manifold
I have a 1970 Camaro with a 454. The existing Elderbrock intake manifold deck height is 5.25 inches which is too tall and gives me inadequate hood clearance. Installed are the lowest engine mounts w/o sitting the headers on the frame. The intention is to use the existing stock hood and hide the 454 underneath.
Does anyone have any ideas of what to to use for the lowest deck height yet have a dual plane? The heads are large Oval ports.
thx for the help
Camaro Joe
Camarozzz is offline   Reply With Quote
Old 07-17-2010, 07:31:56 PM   #2
badazz81z28
BANNED
Originally Posted by Camarozzz
I have a 1970 Camaro with a 454. The existing Elderbrock intake manifold height is 5.25 inches which is too tall and gives me inadequate hood clearance. Installed are the lowest engine mounts w/o sitting the headers on the frame. The intention is to use the existing stock hood and hide the 454 underneath.
Does anyone have any ideas of what to to use for the lowest deck height? The heads are large Oval ports.
thx for the help
Camaro Joe
Iron Pancake manifold found on stock 454s, or look for the low rise aluminum corvette style. They are not cheap tho..
badazz81z28 is offline   Reply With Quote
Old 07-17-2010, 07:49:19 PM   #3
tallman1970
If you can find the L78/LS6 intake.Try a moroso drop-base air cleaner.Also the thin 2-inch air-cleaner I forgot the make.
tallman1970 is offline   Reply With Quote
Old 07-17-2010, 08:16:21 PM   #4
Z28PILOT
Z28PILOT's Avatar
Lowest , the 73-74 corvette LS4 iron intake. Q-JET only intakes.
Here you go
http://cgi.ebay.com/ebaymotors/1973-...fAccesso ries
http://cgi.ebay.com/ebaymotors/1974-...Q5fAccessories
Z28PILOT is offline   Reply With Quote
Old 07-17-2010, 08:29:57 PM   #5
Camarozzz
Thank you for the suggeston Badazz. Would you know the year of Corvette style?
Old 07-17-2010, 08:31:24 PM   #6
Camarozzz
Thx for feedback Tallman. Any idea what year L78/LS6 intake to look for?
Old 07-17-2010, 08:58:44 PM   #7
tallman1970
http://www.yearone.com/serverfiles/f...ain2.asp?cat=0
They made it from 67-71 L78,L89,LS6 this is expensive try finding a used one.
Old 07-17-2010, 09:00:51 PM   #8
tallman1970
Team Chevelle Part #A569 $375.00
Old 07-17-2010, 10:42:11 PM   #9
Camarozzz
Thx again Tallman. I will call Year one to see if these will fit large oval ports and see what deck height is.
Camaro Joe
Old 07-18-2010, 01:04:43 PM   #10
Dave Nelson
Dave Nelson's Avatar
Gm part # 3955287 396,427,454 lowrise for quadrajet will fit under stock hood.
1970 SS/RS L-34 A/C 4 spd.
When you get to the end of your rope....tie a knot & hang on.
Dave Nelson is online now   Reply With Quote
Old 07-18-2010, 02:00:38 PM   #11
Rich Schmidt
The old edelbrock torker with the carb sitting twisted is the lowest height aftermarket intake I know of.The torker 2 is also very low. With real bigblock motor mounts and a dropped base filter it should go under the stock hood.
I think I have one sitting around that I can measure.It is for sale $100. I know I have it,I just gotta make tiime to stop at the garage where it is at.
Rich Schmidt is offline   Reply With Quote
Old 07-18-2010, 08:54:36 PM   #12
Camarozzz
Dave,
thx also for the lead. I will look into trying to obtain this particular intake. Will this fit the large oval port heads? Is it a dual plane intake?
Camaro Joe
