Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 06-18-2010, 06:01:33 PM   #1
pros / cons of running a aluminum water pump
is there any advantage of running a aluminum water pump besides saving 7lbs of weight off of the front of the motor . prices for these aluminum pumps are insane with prices starting at $150 and up , i can get a nice stock cast iron hvy duty version long pump from kragens for $75.00
Old 06-18-2010, 06:22:56 PM   #2
badazz81z28
I bought an aluminum water pump from White Performance on Ebay. Cost like $60 and works fine. If I recall Lifetime Warranty too.
1970 Camaro
LS Swap/T56 Magnum
Mini-Tubbed!
Detroit Speed Frame/Quadra-Link
Moser/DSE Ford 9"/Tru-Trac 3.90s
14"/13" Baer Brakes
badazz81z28 is offline   Reply With Quote
Old 06-18-2010, 06:25:02 PM   #3
i try and stay far away from EVILBAY !!!!
Old 06-18-2010, 06:39:09 PM   #4
here's what i've found so far from summit and are all cast aluminum natural finish:
weiand action plus water pump $94.20
weiand/team G water pump $ 161.95
edelbrock $155
proform $62
over on speedwaymotors.com they've got really nice competion style aluminum water pumps with very high flow rates but are all short design style and would need the spacers to make it into a long version .they do have a stewart stage I cast iron pump for $69
Old 06-18-2010, 07:18:32 PM   #5
Kamikaze
Kamikaze's Avatar
the only thing I would point out to you is to fill the cooling system with Distilled Water and not Tap water. In nearly any circumstance, mineral deposits in regular tap water does not allow full ability to transfer heat when used with anti freeze, Red Line Water Wetter, Pro Blend 40 Below, or other cooling additives. Also, distilled water will help reduce the electrolysis process in eating away the aluminum casting...
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 06-18-2010, 09:32:18 PM   #6
mrdragster1970
mrdragster1970's Avatar
Location: Chicago, Illinois..... Far S.W. Subs, RT 66 Area
The weight and longevity alone is worth using aluminum.
My Stewart is probably 20 years old, and no rotted spots.
It's also only seen distilled water, and is drained 1/2 the year.
For a well maintained street car aluminum might not be worth it??
Founding member of the Cloudyside. US Navy veteran, and damn proud of it!!
PARTS FOR SALE
'94 Pro-Modified Lumina. Photo's of fast car Photos & License 6.54 @ 213 mph 1.00 60'
'70 1/2 RS, 8.57 @ 159 1.29 60'
'72 plain jane, getting chrome moly chassis
For my babies, never forgotten
mrdragster1970 is online now   Reply With Quote
Old 06-18-2010, 10:21:02 PM   #7
ULTM8Z
Chuck, aside from weight, an aluminum pump has no advantage on a typical street driven car. My factory pump does just fine on the hottest days with the A/C running in bumper to bumper traffic.
ULTM8Z is offline   Reply With Quote
Old 06-19-2010, 01:51:17 AM   #8
gingerbreadman
its nice to hear someone else join the electrolysis bandwagon. there are so many doubters out there but i have seen the terror it can cause. i try to limit my aluminium parts especially radiators as their lifespan can be cut very short with a stray current problem.
in saying that i think thick parts like waterpumps , heads, manifolds etc are way more durable to it than a thin, weak radiator tube is so i have no problem in buying those kind of parts.
i run weiind pumps..cant remember what series they are unfortunatly
gingerbreadman is offline   Reply With Quote
Old 06-19-2010, 02:29:07 AM   #9
70RS_L48
I've been running a tall Edelbrock aluminum water pump (IIRC) for 11 years now, with tap water and Prestone, driven a couple thousand miles per year. Only flushed twice in its life, with a stint sitting for four years without any attention. Not a single leak or bearing failure. Seems to be stout piece for the relative abuse I've provided it. That said, the big difference in cooling for my car came from a Be Cool radiator. Swapping to the aluminum pump just saved weight for me. It didn't change cooling performance.
1970 RS/SS L48 Classic Copper with F41, U14, et al.
70RS_L48 is offline   Reply With Quote
Old 06-19-2010, 04:21:17 AM   #10
ZS10
ZS10's Avatar
I have a Prof Products alum w/p. Its the one thing on the entire engine that bolted on and worked properly.
Just use a bottle of "New car smell".
ZS10 is offline   Reply With Quote
Old 06-19-2010, 01:01:04 PM   #11
hhott71
hhott71's Avatar
Last Rebuilt SBC long water pump I bought was in the $20 range.
The aluminum ones are of the short variety (the ones I've seen) and won't bolt up post '69 accessories. You can by spacers to line up Long water pump pulleys, the power steering and alternator mounts aren't there.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 06-19-2010, 01:47:55 PM   #12
msb80sc
msb80sc's Avatar
I bought an aluminum water pump from midwest motorsports about 5 years ago for $69, still going strong. Looks like they have a better 1 for $79 with a lifetime warr. http://www.midwestmotorsportsinc.com...2848&parent=75 And many others to choose from.
You'll know it's a good car, cause you'll only need one.
1980 Camaro, Streetfighter.
msb80sc is offline   Reply With Quote
Old 06-20-2010, 08:43:04 AM   #13
badazz81z28
Originally Posted by gingerbreadman
its nice to hear someone else join the electrolysis bandwagon. there are so many doubters out there but i have seen the terror it can cause. i try to limit my aluminium parts especially radiators as their lifespan can be cut very short with a stray current problem. in saying that i think thick parts like waterpumps , heads, manifolds etc are way more durable to it than a thin, weak radiator tube is so i have no problem in buying those kind of parts.
What do mean? A copper radiator or a cast water pump is just a susceptable to stray voltage than anything part made of metal...
Since all the new cars have nearly aluminum everything...They must not be too "hazardous" for a DD
1970 Camaro
LS Swap/T56 Magnum
Mini-Tubbed!
14"/13" Baer Brakes
Old 06-20-2010, 10:00:55 AM   #14
74RAT
aluminum deteriorates faster than cast iron. it goes for the metal that is the easiest to rot. there is a zinc anode available that is to be installed into the drain hole plug of the radiator. it's is the sacraficial part vs aluminum because it eats that first before the aluminum/brass/copper/iron.
it's "the mix" of using the dissimilar metals in "one system" that sets up the process of electrolosis in the first place. so,, the sacraficial anode would be the best bet to use when using different metals in a cooling system. hope it helps.
andy
you know you really blew it when,,, all your parts will again,, fit loosely in a 5 gallon bucket!!!!
74RAT is offline   Reply With Quote
Old 06-20-2010, 10:04:27 AM   #15
74RAT
stick the red probe of a volt ohm meter in your radiators filler neck,, into the water,, and ground the other end to the body somewhere. if you show more than 3-4 volts,, your rusting/rotting things. flush/change the coolant. it is totally an electrical process for sure.
andy
