Old 05-10-2010, 09:49:18 PM   #1
Philly
Trans am rear end (posi)
I looking at buying a rear end out of a trans am (Smokey & the bandit type car) its posi but i don know if its a decent rear end or if it will fit in my 73 camaro...need some help here.
1973 camaro 454 BBC, 4 speed super T-10 close ratio
781 heads, Eaton posi 3:73's and lots of elbow grease!
My New thread:
http://www.nastyz28.com/forum/showthread.php?t=283800
Philly is offline   Reply With Quote
Old 05-10-2010, 09:56:22 PM   #2
Twisted_Metal's Avatar
Disc brakes?
It will bolt up to the frame, springs and shocks fine.
You may need a different U-joint to mate with the pinion yoke.... Depending on the T/A year.
Old 05-10-2010, 10:22:15 PM   #3
Kamikaze
Kamikaze's Avatar
The original "Smokey & The Bandit" T/A's were the 77-78 body styles which did not yet have the rear wheel disc brake axle. This came on the 79-later.
So many threads have been written about this but just to cover the basics, if you are getting a 79-81 rear with disc brakes, make sure you get the parking brake cables, the master cylinder, the prop valve, the brake pedal pushrod to make the conversion easier.
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 05-10-2010, 10:56:34 PM   #4
BondoSpecial
BondoSpecial's Avatar
If it's truly from a trans am maybe you'll be lucky and it will have 3 series gears and a posi in it
Steven H. www.carfap.com
2011 Infiniti M37X, 2004 Ford F250 6.8 V10 6 speed manual 4x4, 2000 BMW M5, 1999 C1500, 1994 Town Car, 1976 Jeep DJ5
BondoSpecial is offline   Reply With Quote
Old 05-10-2010, 10:58:08 PM   #5
Kamikaze
Kamikaze's Avatar
Originally Posted by 1977_TPI_Camaro
Many of the TA rears are going to have crap gear ratios. Just because it's disc does not automatically mean it also has good gears. A lot of them were highway gears. 3.08 is common to find in the disc rears but it could also well be a 2 series gear
This is true of the 80-81 Turbo cars that had as high as 2.41 gears!
Old 05-10-2010, 10:58:57 PM   #6
BondoSpecial
^caught me before I edited, I didn't realize the original poster was not necessarily asking about discs. But yeah I was surprised to see the low 2.xx gears in the disc rears...
Old 05-11-2010, 01:59:50 AM   #7
flowjoe
I just had two pass through my hands - one was a '79 w/2.41 Posi - I think the other was a '78 but 2.56 posi.
The Pontiacs tend to get higher gearing because, in general, they have a lot of torque and can over come it on the street and because, in general, they don't like to rev so the high gears keep them happy on the highway.
Camaros
'67 LA V8 Convertible, Butternut Yellow
'69 NOR Z/28, Yellow w/black stripes - X-77
'69 LA SS 350, Fathom Green
'69 LA Z/28, Daytona Yellow
'70 LA Z/28, Daytona Yellow
'71 LA RS/SS, Nevada Silver
'71 LA SC, Green
Pontiacs
'67 Firebird convertible
'69 GTO - Triple black, 50,000 miles
Corvettes
'70 LT-1, T-top, 4spd, Bridgehampton Blue
'82 T-top, white
flowjoe is offline   Reply With Quote
Old 05-11-2010, 03:22:38 AM   #8
HOGDADDY
Years back I picked up a rearend out of a 79 or 80 TA w/ 3:42 posi and the guy at salvage yard said it was a limited slip not a posi and only charged me $100.
Its still in my 80 Camaro today.
80-RS 406 th350 3:42
86 Scottsdale 350 Edelbrock heads, Lunati retro- roller, 700r4, Eaton 3:73
67 Camaro convertible
HOGDADDY is offline   Reply With Quote
Old 05-11-2010, 06:23:59 AM   #9
my24ktrat
...Lucked out myself, 3;42 limited slip disc rear out of a T/A from calif. , took the buildsheet out of the car , and it had a 305 4bbl in it , weird combo,the rear is still in my 79 , DC
my24ktrat is offline   Reply With Quote
Old 05-11-2010, 08:28:16 AM   #10
Philly
No disc brakes on this unit. Umm...if it were limited slip ..if i turned one tire,.. the opposite tire would spin in the opposite direction right? and if it was a true posi both tires would spin in the same direction ...correct? it does have low gears in it i think...i'd have to get the code...but if its a posi would 250$ be a good price?
My New thread:
Old 05-11-2010, 09:13:57 AM   #11
my24ktrat
...Limited slip would have both tires turning in the same direction, you can also pull the cover off to check , you'll see that ''S '' spring in it ,also you can turn the axle 1 revolution and count how many times the yolk turns ,that'll give you an idea on the ratio , 2 3/4 times [2;73] , 3 1/2 [3;42] ,etc, hope that helps, DC
Old 05-11-2010, 12:44:47 PM   #12
pulpcowboy
Posts: n/a
Got a PY coded '79 3:42 posi under a 71SS w/stroker and gets great gas mileage (18mpg) compared to that gas guzzlin' 4.11 and can get on it easy, I think it's the perfect ratio.
Old 05-11-2010, 01:13:05 PM   #13
badazz81z28
Limited slip....Posi...is same thing. If you have an open rear, yes the opposite tire will spin in the opposite direction. Posi will rotating both tires in the same direction.
$250 is a decent price for a posi rearend with good gears (3.42 and up)
1970 Camaro
LS Swap/T56 Magnum
Mini-Tubbed!
Detroit Speed Frame/Quadra-Link
Ford 9"
Baer Brakes
badazz81z28 is online now   Reply With Quote
Old 05-11-2010, 03:18:51 PM   #14
Philly
Thanks guys...i appreciate it as always
My New thread:
Old 05-31-2010, 07:41:57 PM   #15
Philly
I got the codes but i'm having a hard time finding it out.
1254333
A178
and other side says GM 24
Any ideas before i take the cover off?
It says on the tag to use limited slip oil only.
I'm gonna go pull it off right now.......
My New thread:
