Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 05-07-2010, 11:50:34 PM   #1
Silver75
Camshaft recommendation for 406 sbc
Hello,
I have been acquiring parts for a new engine build and could use some guidance in selecting a cam.
Engine specs so far.
406ci
cast crank and rods
dish piston comp. around 10.4/1
edelbrock etec 200 heads
roller rockers 1.5 or 1.6 ratio (haven't bought yet)
rpm intake
750 Holley carb
2500 stall TH350
3:73 gears
1 5/8 tube headers
This engine will be put in a street strip car.
I contacted comp cams and they reccommended an XE 274
Thanks,
Dave
Silver75 is offline   Reply With Quote
Old 05-08-2010, 11:34:45 PM   #2
tallman1970
If comp cams xe grinds dont work I would look into Lunati Voodoo line I would run #60104 233/241 @.050 or thier #60105 241/249 @ .050 for your that sbc 400.
tallman1970 is offline   Reply With Quote
Old 05-09-2010, 07:40:27 PM   #3
RustoRod
If you are looking for a budget flat tappet hydraulic cam I would use part # 915-110591 from Speedway motors. It specs .480/.494 228/234 @ .050 on a 106 lsa and sells for $69.95. I am currently using this cam in a 400 sbc in a truck with a similar converter and it works well. However with those heads I would look for similar .050 duration with more lift on the 106 lsa. I would use comp cams XFI lobes and the 1.6 rockers. The 274 XFI intake lobe will give you around .535 lift with the 1.6 rocker.
RustoRod is offline   Reply With Quote
Old 05-10-2010, 01:50:15 AM   #4
NYH1
Silver75, are you going to use the stock 400 5.565" rods or are you going to use a longer 5.7" or 6" rod? I would go with at least a 5.7" rod. I went with 6" rods in my mild 385 stroker.
I was going to use a Comp Cam Xtreme Energy hydraulic flat tappet cam until I started hearing and reading that CC's Xtreme Energy series cams are noisy and that CC's is having higher then usual warranty issues with this series of cam compared to their other series. Two different local machine shops, places that sell them Summit and Jegs to name a few and even guys on this site told me the same thing.
I went with a Lunati Voodoo hydraulic flat tappet cam instead. I'm not anti CC. I thought real hard about using one of their Dual Energy cams. It was actually the best cam on their Camquest6 program. It made the most power and torque at the RPM ranges I was looking for. Which from my understanding is more accurate with that program then the power numbers it shows. I'm using their roller tip rocker arms too.
Just something for you to think about.
'78 Camaro, mild Vortec head 385 stroker motor, 9.1:1 comp., 6" rods, Lunati Voodoo 262/268 hyd. flat tap. cam, Performer RPM Intake, 650 AVS carb, 1 5/8" full len. Hedman Headers, 2 1/2" full len. Flowmaster Dual Exh. Sys. w/Trans. Flow Muffler. TH350 Coan 11" 2600 stall conv., 10 bolt 3.42's Duragrip Posi, '70-'79 Z28 5 spoke mag wheels.
NYH1 is offline   Reply With Quote
Old 05-11-2010, 03:34:46 PM   #5
RacerRick
Isky 280 or 292 megacam. I personally would go with the hotter 292 - it is on a 108 LSA and really rumbles.
80' Z28 -T-tops, and getting 4 speed converstion and a 454
81' Berlinetta - parts car
RacerRick is offline   Reply With Quote
Old 05-11-2010, 11:37:47 PM   #6
Air_Adam
XE274 or XE282 would be excellent street/strip cams in that engine.
Spandex is a privelige, not a right!
Air_Adam is offline   Reply With Quote
Old 05-12-2010, 12:52:34 AM   #7
jakeshoe
jakeshoe's Avatar
I would look for a cam in the 240 @.050 range minimum.
The 406 "absorbs" more cam than other SBC due to it's cubes and unshrouded valves.
240/244 would be a good place to start with a hydraulic profile.
The tighter LSA makes a mid range killer but will suffer a more erratic idle.
If it were my combo it would be done on a 108.
I custom order cams though and rarely run a shelf cam.
It will idle decent and pull from 2000 rpm with a torque curve like a locomotive.
I prefer some of the older profiles in a street oriented combo. Comp Magnum lobes. Plenty aggressive lobe, not giving up much HP to the "latest greatest" but more stable and reliable.
www.jakesperformance.com
Performance GM Automatic Transmissions, Converters, and valve bodies.
jakeshoe is offline   Reply With Quote
Old 05-13-2010, 10:26:24 PM   #8
Silver75
Thanks for all of the responses. I have been looking at a bunch of the grinds that you folks have recommended. I was planning on a smaller cam, I am glad I posted this on here before buying.
Thanks,
Dave
Old 02-20-2011, 02:09:30 PM   #9
Silver75
Hey guys,
I am resurrecting this post to finalize the cam. I wanted to add that I have power brakes and would like them to fuction correctly in the car. I also will be running 1.6 rockers on this engine.
Cam choices
Voodoo 60104
233/241
.504/.525
110 lsa/ ICL 106
Lunati 07102
235/235
.507/.507
108 lsa/ 104 icl
Lunati 07103
245/245
.534/.534
108 las/ icl 104
Isky 292 Mega
244/244
.505/.505
108 lsa
Thanks again,
Dave
Old 02-20-2011, 06:27:14 PM   #10
rustbucket79
Originally Posted by Silver75
Hello,
406ci
cast crank and rods
rpm intake
750 Holley carb
2500 stall TH350
3:73 gears
1 5/8 tube headers
Thanks,
Dave
I built an engine quite similar for a customer maybe 10 yrs ago. Performer RPM heads, similar compression, etc. I used the XE274H flat tappet cam, it pulled very nice from 3000 (converter flash) to well past 6000. Not sure how much more you'll need. The engine felt like it would happily turn 6500+ but the stock cast crank/350 rods/external balance shouldn't be that high.
If you had a 4000+ stall I would look for a larger cam.
Vids of the car: http://www.youtube.com/watch?v=Fb39m4ToP50
rustbucket79 is offline   Reply With Quote
Old 02-22-2011, 01:49:09 PM   #11
middleagecrisis
I ran a stock bottom 400 SBC with double hump heads and the old 280 Magnum Compcam. All kinds of torque and pulled hard to 5500. That cam has fallen out of favor with all the new higher ramp speed cams (XE, Voodoo, etc.), but it's easy on valve trains and one of my favorites. Just my .02
middleagecrisis is offline   Reply With Quote
