Old 05-07-2010, 05:07:56 PM   #1
Eric_04
How to install motor mounts??
Hey all, I have a 76 camaro and am going to be putting in new motor mounts before I put my motor back in, but my question is how the heck do you get to the nuts for the motor mount bolts? The passenger side kinda has access holes in the subframe but the driver side has nothing. Any help would be greatly appreciated.
Eric_04 is offline   Reply With Quote
Old 05-07-2010, 06:35:07 PM   #2
Danish Guy
Use some fishing line to put in the bolts from below and put the nuts on top of the motor mounts just did it myself it is a 20 min job.
If you want more inches, stroke it
My 76 LT Build:
http://www.nastyz28.com/forum/showthread.php?t=178855
http://www.youtube.com/watch?v=TjhkgfusAYM
Danish Guy is offline   Reply With Quote
Old 05-08-2010, 10:25:58 PM   #3
Eric_04
Thats a good idea but how did you get to them to take the nuts off in the first place? Did you have to take the front tires off and the wedge your arm between the control arms to get to them?
Old 05-08-2010, 10:50:36 PM   #4
OldCamaroNut
OldCamaroNut's Avatar
I did it without taking the tires off. I used a distributor wrench to hold the nuts and removed the bolts from the top. I then used fishing line as mentioned and pulled the bolts up from the bottom, got on them with the distributor wrench with a little duct tape to keep the bolts from falling through and put the nuts on top.
SOLD <sigh> 1979 RS weighs 3580 lbs. with me in it. 406 w/ Victor Jr, Pro Systems 850 CFM carb, Pro Topline 220cc heads, solid roller cam with .630 lift, 264-270 duration @.050, Ross -5cc racing pistons, 12.5 to 1 compression, Forged crank and rods, splayed 4 bolt mains, 1.875" headers. Converter stalls at 3200, Trans Specialties turbo 350, 4.10 gears. Fastest to date is 10.67 @ 124.
OldCamaroNut is offline   Reply With Quote
Old 05-09-2010, 07:54:02 AM   #5
Steve's 77
Hi Eric: I'm doing this job right now. I had one heck of a time getting the old mounts off and thought when the time came to put the new ones on I would try the fishing line idea. No way man. That is just too frustrating. I dropped the lower control arms (just one side so far) which allows you the room to get your fingers in there and put the nuts on the bolts. I was afraid even if I was able to get the bolts in there that it would be next to impossible to torque them down enough so I was satisfied with the job. It is one B..tch of a job I'm sorry to say, but mine are 33 years old and I have a vibration I'm trying to chase. Oh....and now I can replace my coil springs which I cut a full coil off of a couple years ago. MISTAKE...cut too much off. Car is too low. Have fun and don't cuss too bad. Don't throw anything. Later
Steve's 77 is offline   Reply With Quote
Old 05-09-2010, 08:08:49 AM   #6
theflash
theflash's Avatar
Has it been a week already since this was asked?
Old 05-09-2010, 12:15:46 PM   #7
OldCamaroNut
What's frustrating about using fishing line? The fact that it coils up and doesn't go all the way through when you're trying to feed it down? I tied a small nut to the line so that the weight of the nut pulled the line through to the bottom. Problem solved. And a whole lot easier than removing a control arm, IMHO. And the job went very fast and easy. Again, I used a distributor wrench to hold the bolt in place and tightened the nut down as tight as I wanted. I am not at all worried about the mounts being secured properly.
Old 05-09-2010, 01:55:36 PM   #8
Eric_04
I tried the search 7 times over the course of an hour or so before I posted this question and it didn't work once.
Im gonna try the fishing line first because I dont feel like taking my control arms apart, but if I were putting springs in or new control arm bushings in it would be a different story. Hopefully it goes somewhat easily, tonights project when I get home.
Old 05-10-2010, 11:26:00 AM   #9
OldCamaroNut
How'd it go?
Old 05-10-2010, 02:17:55 PM   #10
1980camaroguy
Distributor wrench and alot of patience. A second set of hands to help remove and tighten helps too. Mine took half a day by myself removing from parts car but then 20 minutes to reinstall with extra set of hands on my car. Good luck.
1980camaroguy is offline   Reply With Quote
Old 05-10-2010, 04:02:04 PM   #11
badazz81z28
Took me 20 minutes (by myself) . Its not that complicated.
Drill a hole on the drive side just like the passenger side. Stick the wrech in with tape behind it to retain the nut (opposite for install). I used fishline for the single lower bolt to pull it up through the hole and install the nut. Once I did it, I was amazed how some made me feel it was so trivial.
1970 Camaro
LS Swap/T56 Magnum
Mini-Tubbed!
Detroit Speed Frame/Quadra-Link
Moser/DSE Ford 9"/Tru-Trac 3.90s
14"/13" Baer Brakes
badazz81z28 is online now   Reply With Quote
Old 05-11-2010, 05:40:33 PM   #12
Eric_04
The new ones are in now it was kind of a pita but all in all not that bad. I used some string, a distributor wrench, and some duct tape and 45 minutes later they were in. Probably would of been easier with a second set of hands but I made it work. Thanks for all the tips.
Old 06-10-2011, 11:06:26 PM   #13
dcart1
Did mine today using a magnetic pocket pen. It was small and put nut on end. Pushed it right up to and through hole from the bottom. Quick and easier than fishing line.
dcart1 is offline   Reply With Quote
Old 06-11-2011, 10:59:25 PM   #14
crome dome
Here's how I cured mine forever but you gotta have the lower control arms out.
http://www.nastyz28.com/forum/showthread.php?t=210150
crome dome is offline   Reply With Quote
