Old 05-06-2010, 05:05:38 PM   #1
adz372
brodix hv1000 manifold
ive just got my motor back in my car got ive brodix18* heads and brodix hv 1000 manifold, ive noticed my carb is laying back more than normal! ive got the old motor on the stand with an edlebrock manifold ,it seems they cast them to compensaite the lay back of the motor to make your carb near level, problem ive got is, now with this brodix top end its laying back, does anyone else use this manifold? will i have problems with loss of fuel in the bowls of the carb when i accelerate?
adz372 is offline   Reply With Quote
Old 05-06-2010, 06:48:56 PM   #2
1972L
Use a tapered (like a wedge) spacer
1972L is offline   Reply With Quote
Old 05-06-2010, 08:07:08 PM   #3
mrdragster1970
mrdragster1970's Avatar
Location: Chicago, Illinois..... Far S.W. Subs, RT 66 Area
If it works for a drag car, I highly doubt it will run dry on a street car.
Worse comes to worse, and you have enough power to worry, stick an extension on there.
Good luck,
Founding member of the Cloudyside. US Navy veteran, and damn proud of it!!
PARTS FOR SALE
'94 Pro-Modified Lumina. Photo's of fast car Photos & License 6.54 @ 213 mph 1.00 60'
'70 1/2 RS, 8.57 @ 159 1.27 60'
'72 plain jane, getting chrome moly chassis
For my babies, never forgotten
mrdragster1970 is offline   Reply With Quote
Old 05-06-2010, 08:42:41 PM   #4
adz372
thanks guys, guess il take it for test and see what happens.
Old 05-06-2010, 08:45:52 PM   #5
1972L
Moroso 65030
Old 05-07-2010, 05:02:37 AM   #6
adz372
so mrdragster are you saying i should be right with it laying back 4-5 degrees? i could use that wedge but ive got clearence issues with my cowl hood.
Old 05-07-2010, 09:59:33 AM   #7
mrdragster1970
I'm half senile, and may be missing what you're asking??
If you are worried about uncovering the jet's, or running the bowl dry when you take off, I wouldn't.
Like I said, I don't know how fast you are, but you won't run dry unless it's a pump issue,
and if you have enough power to uncover the jets when you nail it, get extensions.
You can also get a little extra bowl volume by using a vent extension.
I always run vent extensions, mainly because when I launch hard or throw the chutes,
fuel comes out, but it also lets you run the float higher. Which gives you a little more volume.
PARTS FOR SALE
Old 05-07-2010, 05:30:55 PM   #8
adz372
ok thanks it sounds like i should be alright, il soon find out ,it'l be back on the road in couple of weeks.
