Old 04-18-2010, 07:52:38 PM   #1
Phaedrus44
Please tell me abou 461x heads
Hi all,
So I've been told by alot of my fellow competitors that for our Street Stock class, 461x heads are what you want....nothing else. I bought a set of bare heads from a guy who said they are 461x heads, and showed them to a friend who happens to work on a pro top fuel car and knows his stuff.
This friend says they are NOT 461x heads, they are regular 461 heads. The heads in question have the X stamped on the bottom of the water passage and nowhere else. My friend says if they were real 461x heads, the X would be stamped after the 461 on the bottom of the intake runners. I paid $500 for just the bare heads and he told me to get my money back. He told me that real 461x heads are super rare, and I probably won't even be able to find them.
Information I've found on the internets is mixed....there are two heads on ebay right now that the sellers claim are 461x even though they are just like mine with the X under the water passage.
Does anyone know for sure? I'm super confused! These heads are not even all that nice, with the side broken out of one head bolt hole and really bad seats and guides. My friend gave us a super nice set of 462 heads which he said will work better than the 76cc smogger junk I have on my race car now. Thanks!!!
Phaedrus44 is offline   Reply With Quote
Old 04-18-2010, 08:38:16 PM   #2
flowjoe
Originally Posted by Phaedrus44
Hi all,
Don't know a lot about early heads but this might help:
http://www.camaros.org/forum/index.php?topic=547.0
You'd have to measure runner volume to truly know. Since 462's were the next iteration might they have larger runner volumes also? Just a thought
Camaros
'67 LA V8 Convertible, Butternut Yellow
'69 NOR Z/28, Yellow w/black stripes - X-77
'69 LA SS 350, Fathom Green
'69 LA Z/28, Daytona Yellow
'70 LA Z/28, Daytona Yellow
'71 LA RS/SS, Nevada Silver
'71 LA SC, Green
Pontiacs
'67 Firebird convertible
'69 GTO - Triple black, 50,000 miles
Corvettes
'70 LT-1, T-top, 4spd, Bridgehampton Blue
'82 T-top, white
flowjoe is offline   Reply With Quote
Old 04-18-2010, 09:26:30 PM   #3
Musmoke
461X head will have an actual "461x" cast in the underside.
A normal 461 head has "461" cast.
Not a huge difference between the two but they are different as cast from the factory.
Musmoke is offline   Reply With Quote
Old 04-18-2010, 10:15:08 PM   #4
NYH1
Does your class allow you to use World Products S/R or S/R Torquer heads or even Dart 165cc Iron Eagle heads?
I know some tracks and/or sanctioning bodies allow certain new aftermarket heads to be used in place of older worn out 40 year old heads. The aftermarket heads are usually thinker in the crack prone areas of stock heads. They usually flow better and have better combustion chambers too.
If you have to use stock heads I really can't help you. I've heard a lot about the old "camel back" heads. I don't know what casting numbers they are. I've always' used aftermarket heads on my street cars. I like using iron heads, makes them look more original and I'm not building racecar's. I used Dart Sportsman II heads on my last build. This time I want with Summit Vortec heads which are made by Dart.
good luck, NYH1!
'78 Camaro, mild Vortec head 385 stroker motor, 9.1:1 comp., 6" rods, Lunati Voodoo 262/268 hyd. flat tap. cam, Performer RPM Intake, 650 AVS carb, 1 5/8" full len. Hedman Headers, 2 1/2" full len. Flowmaster Dual Exh. Sys. w/Trans. Flow Muffler. TH350 Coan 11" 2600 stall conv., 10 bolt 3.42's Duragrip Posi, '70-'79 Z28 5 spoke mag wheels.
NYH1 is offline   Reply With Quote
Old 04-18-2010, 10:24:12 PM   #5
Phaedrus44
That's what my friend says. It says "461" on the underside with an X cast all by itself seperate from the number. Guess these aren't 461x.
Old 04-18-2010, 10:25:14 PM   #6
Phaedrus44
good luck, NYH1!
Unfortunately no, stock iron heads only. No angle plugs, no Vortec. It kind of sucks, cause you have to put $1500 into a 40 year old set of crack prone heads, instead of spending the same amount on some decent aftermarket heads and being done with it.
Old 04-18-2010, 10:46:04 PM   #7
1972L
The 461 x heads I have seen have the X cast (not stamped) on the underside of the intake runner.
1972L is offline   Reply With Quote
Old 04-18-2010, 11:26:42 PM   #8
NYH1
That sucks. Well good luck with your heads and racing!
Old 04-19-2010, 12:03:57 AM   #9
Bikefixr
461X heads have the X cast in, not stamped. They always read 461X. They do not have accessory holes. They have screw in studs. They usually have 2.02 intakes, but I have see them with 1.94 intakes. They are rare. I've had maybe 4 or 5 sets...and that was in the late 70's to late 80's when they were still around. They flowed a little better than the standard Fuelie heads like the 291, 041, 461 and the like. They needed a lot of work to make them really run. A stock Vortec will put it to shame right out of the box.
Bikefixr is offline   Reply With Quote
Old 04-19-2010, 02:28:33 AM   #10
hhott71
hhott71's Avatar
Change classes.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 04-19-2010, 09:20:28 AM   #11
warped
Location: Sitting in my command bunker waiting for the zombies
I've never seen the 461X but on the 041X heads, the "X" is part of the casting number.
I'm not sure exactly what the rules are in your class, but you might want to take a look here:
http://www.castheads.com/disguise_work.php
Pat
'Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd
by the clean end.'
warped is offline   Reply With Quote
Old 04-19-2010, 09:42:30 AM   #12
tom3
That's neat. Expensive. But I'd check for a claimer deal in the race series.
tom3 is offline   Reply With Quote
Old 10-19-2011, 09:14:07 AM   #13
djgriff
461x heads were mostly 1.94,1.5 valves with some 2.02s the X was never in the cast # under the valve covers between the rocker studs but was cast on the under side of the water jackets on the intake side on the ends of the heads they do have 170cc intake runners and were the best factory heads in the early 60s(most were cast in 63-64,65, with some 62 66 date codes, they were The head to have in stock and super stock classes and came mostly on the hp corvette 327s with and without the Rochester FI but could be found in other models with hp 327(ss chevelles ,ss impalas and are highly sought after by collectors for restorations and by street stock roundy round racers. check out the ebay listings for original un modified 461x and most are getting well over $1,000 for them compared to $200-$500 for the other (461,462,186,ect.. )camel hump hp small block heads. one last thing they will support370-400 horse power even in 1.94 valve sizes, proper porting with 2.02s(attn.to un shrouding) will support 450+ and maxed out welding by a few elite porting gurus have gotten 600+ out of these suckers and if you think i am wrong check out some of the NHRA records that still stand today with these heads
djgriff is offline   Reply With Quote
Old 10-19-2011, 09:18:11 AM   #14
djgriff
X marks the port
Old 10-19-2011, 09:36:18 AM   #15
flowjoe
18 months later rip van winkle woke up.....
Camaros
'71 LA SC, Green
Pontiacs
Corvettes
'82 T-top, white
