Old 04-11-2010, 11:11:33 PM   #1
ronzz572
ronzz572's Avatar
1970 z28 spiral shock questions
Looking for correct front and rear spiral shocks for my 70 z28. I realize it has been talked about here in the past, I want to confirm fitment of a expensive shock purchase and do it once. Now the rear spiral shock number is 3192282 and avalable from D&R classic. The front shocks part#3192132 are not avalable that i can find. Is there a source to buy the 3192132 front shock or do i have to use the 3192477 as a substitute sold from D&R classic,And will it fit the 70 camaro if i have to use it? Thanks Ron.
rgliebertjr@yahoo.com 1970 Z28 1970 L78 1974 Z28, 1970 firebird formula protour.
ronzz572 is offline   Reply With Quote
Old 04-13-2010, 08:37:13 PM   #2
White81Z
The correct front shock is currently not being reproduced so I just used a set of Monroes and painted them Gray. I will use then until the correct shock comes out.
Matter of fact I am using painted Monroes all around until I have a complete set of correct shocks.
Rick H.
White81Z is offline   Reply With Quote
Old 04-13-2010, 09:40:09 PM   #3
ronzz572
ronzz572's Avatar
I ordered the 3192282 for rear and the 3192477 with no part number stamped for the front. I will let everyone know if the front shocks fit. Judging by what i have read here on other spiral shock threads, it appears this is the only way to go.
Old 07-14-2012, 01:29:10 PM   #4
fmarullo
fmarullo's Avatar
Ron any update?
Its been a while since I posted here, I'm still around and doing well. I'd like to replace the 30 year old shocks in my car and of course spiral ( OEM style) shocks are the prefered replacemnet. Resurrecting this old thread to see how Ron made out.
Frank
1970 RS Z/28 M21 4:10 deluxe black interior
Cranberry Red Black stripes Van Nuys 04D
MuscleCar TV Feb 2011, Haggerty Commercial 2012, Detroit Muscle August 2014
Daily driver:
Challenger SRT8 6.1 L Hemi - Inertia: SRTMax cam, P&P heads, Intake, Cervini's Shaker, Magnaflow exhasut, DSS 1000HP Axles Custom CMR tune from Johan of DiabloSport fame at AMP (Afterhours Mopar Performance )
fmarullo is offline   Reply With Quote
Old 07-14-2012, 03:38:01 PM   #5
ronzz572
ronzz572's Avatar
Frank I did purchase those shocks. They fit well. I do drive my car and have had no problems with the shocks or any handling issues.
Old 07-15-2012, 07:28:58 AM   #6
bkmont
Ron,
Do you know what the difference is between 3192132 and 3192477 front shocks? I see now. Found the old thread about the 69 vs 70 having a shorter travel.
1970 Z28 Auto, 4.10, LA built, NA9 (Calif)
Citrus Green, Green Interior 07B TT
Baseball, Hotdogs, Apple Pie and Chevrolet
bkmont is offline   Reply With Quote
Old 07-15-2012, 09:33:00 AM   #7
ronzz572
ronzz572's Avatar
Yes I was aware or the shorter travel issue with the shocks. I used the shock anyway. I personally felt the shorter travel would not affect the use of the shock which it hasn't for me.
Old 07-15-2012, 10:34:33 AM   #8
bkmont
Thanks Ron. I need to decide what shocks I'm going to use on my 70.
Old 03-21-2015, 10:27:00 PM   #9
Peter Wilson
Iam now going to resurrect this old thread ...lol . I also am looking to buy a set of these 69 Camaro spiral shocks for my 71 Z28 . the shorter travel that has been mentioned , will it be an issue on a Z28 , given the lower control arm bumpers that limit the amount of spring compression ? My car now has an aluminum headed bigblock and new Bigblock front coils . will the shock extend enough to be installed ?
Peter Wilson is offline   Reply With Quote
Old 03-21-2015, 10:36:06 PM   #10
ronzz572
ronzz572's Avatar
My car still have the same shocks on it. No issues. If your car sits at a normal ride height. It should not be a problem.
