Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 04-02-2010, 11:51:27 AM   #1
esgal
cable exhaust cutouts
has anyone here ever used cable exhaust cut outs?
im looking into buying just a cheap set of cable exhaust cut outs such as
http://cgi.ebay.com/ebaymotors/Mr-Ga...fAcc essories
as anyone used these specifically, or have an extra set, or have an comments/warning/suggestions on them?
iv heard cable exhaust cut outs get rusted alot and dont work has that happened to anybody? i wouldnt be driving in any weather
or is something like this
http://cgi.ebay.com/ebaymotors/Exhau...item414b413e51
will work just as well
esgal is offline   Reply With Quote
Old 04-02-2010, 02:56:00 PM   #2
http://cgi.ebay.com/ebaymotors/Mr-Gasket-Exhaust-Cut-Out-5424_W0QQcmdZViewItemQQhashZitem4cee8f2051QQitemZ3 30419871825QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcc essories
http://cgi.ebay.com/ebaymotors/Exhaust-Cutout-Cast-Iron-NEW_W0QQitemZ280435441233QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item414b413e51
i used to run cable style cut outs in the 70's but they didn't seal all that well and trying to weld cast iron to muffler pipe is kinda tricky !!!!
Old 04-02-2010, 05:03:58 PM   #3
esgal
Well the guy that helps me with my project is a professional welder, and I'm in high school if it doesn't seal all the way and is louder all the time I'm happy.
Old 04-02-2010, 07:55:32 PM   #4
1971BB427
I used cable cutouts years ago, and eventually the cables or plates stick and you either can't get them open or can't get them shut. Nothing but a hassle.
1971 BBC 427, 2nd owner since 1973.
http://www.nastyz28.com/forum/showthread.php?t=167036
1971BB427 is offline   Reply With Quote
Old 04-02-2010, 08:34:38 PM   #5
1980RS
If you want some cheap cable cutouts just go to jeg's they now have them in
2 1/2" size.
If you want to make some cheap why not try and use to 90mm GM electric throttle bodies and use the TAC with a switch to make them cheap. you could also use some cable t-bodies and run a cable to them and they are spring loaded.
1980RS is offline   Reply With Quote
Old 04-02-2010, 09:48:57 PM   #6
esgal
i found a place to buy them cheap, $27 shipped off ebay per side, for cast iron cable cutouts. but are they to cheap? i dont want to get into the electric ones because they could easily be litterly 10x the cost for both sides
Old 04-02-2010, 11:03:36 PM   #7
Toomanyhobbys
Toomanyhobbys's Avatar
NO NO and Hell NO. I put them on my Camaro. I hated them, They would open up on one bank and make the car sound like crap. No NO NO NO NO
don't waste the money.
RATDOG RACING
Marks71BB ---
remember, ya dont have to own a second gen to hang with us
Toomanyhobbys is offline   Reply With Quote
Old 04-02-2010, 11:24:51 PM   #8
don't get them ........they don't seal worth $#$&^&%* and you'll have nothing but problems .why not just get a set of 3 bolt flange cut outs and this is what is on my camaro and takes less than 5 minutes to remove both caps
here's my set up :
Old 04-03-2010, 03:32:17 AM   #9
Damon
Cable-operated exhaust cutouts are crapola for all the reasons stated above. Do like Muscl Car says. Use stainless steel hardware to hold the cap on so you can get it on and off easily for years,
1990 454SS pickup. Original "tow truck motor" 454 upgraded to something a little more "aggressive." Seems pretty stout but the fuel bill is nuts.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid 12s appears to be the best it's gonna do on street rubber. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 04-03-2010, 04:47:26 AM   #10
ZS10
ZS10's Avatar
And lock washers, don't forget lock washers.
Just use a bottle of "New car smell".
ZS10 is offline   Reply With Quote
Old 04-03-2010, 06:28:54 AM   #11
Do the eletric or the ones like muslce car has
Old 04-03-2010, 09:42:48 AM   #12
esgal
i think ill go with the ones muslce car has, thanks for everyones help
Old 04-03-2010, 04:36:17 PM   #13
tom_79
I used cable operated cut outs on mine, had to use such a heavy spring to stop them rattling that I couldn't open them with the cables!!
tom_79 is offline   Reply With Quote
