Old 03-28-2010, 04:47:50 PM   #1
gutted72
TH350 Fluid Capacity ?
Just got done rebuilding my th350 and need to know how much fluid goes back in it. The book says 20 pints (10 qts stock pan) if the trans is dry but it doesn't say if that is with a new converter or reusing the old one. I am reusing the old one and I don't want to over fill the transmission.
"Stupid people shouldn't Breed"
http://img.photobucket.com/albums/v3...o/Myrides2.jpg
1957 Chevy 3200
1972 Camaro
2004 Victory Vegas
gutted72 is offline   Reply With Quote
Old 03-28-2010, 06:08:38 PM   #2
TheMeat
http://www.tciauto.com/Products/Tech...d_capacity.asp
BlownCornBanana
https://www.youtube.com/watch?v=GpLCjrayo-8
TheMeat is offline   Reply With Quote
Old 03-28-2010, 06:18:22 PM   #3
gutted72
I looked at that site and thats why I had to ask the question.
Lets say new converter = 2 qts
Stock pan = 4 qts
Thats 6 qts
My rebuild book says 10 qts. Big difference.
1957 Chevy 3200
1972 Camaro
2004 Victory Vegas
Old 03-28-2010, 06:50:46 PM   #4
retorq
You don't account for all the valve body passages, cooler, cooler lines, etc.
Why are you reusing the old convertor?
The first digital hijinx I designed was quite naturally perfect. It was a work of art. Flawless. Sublime. A triumph only equaled by its monumental failure.
retorq is offline   Reply With Quote
Old 03-28-2010, 09:25:55 PM   #5
gutted72
Because it has less than a 1000 miles on it. The only reason I rebuit the trans in the first place was due to a thrust washer that spun in its location and gave the input shaft to much end play which in-turn created a vibration in the transmission.
1957 Chevy 3200
1972 Camaro
2004 Victory Vegas
Old 03-28-2010, 09:55:20 PM   #6
ZS10
ZS10's Avatar
That's a pretty small converter.
Put 4 in start for a couple seconds (fills the converter and passages). Another 2 (depending on the converter size or how much oil is left in a used one). 2 more and check the dip stick while running. Add as necessary, usually another 1-2.
I'd want to have 8 quarts on hand.
Just use a bottle of "New car smell".
ZS10 is offline   Reply With Quote
Old 03-28-2010, 10:01:29 PM   #7
gutted72
I've got 8 qts in it as of now and it seams to be working pretty good. I'm going to let it sit over night and tomorrow I will start it, let it get up to temp and then check the level from there. If I need to add more then I will.
I really just wanted to know if anyone knew how many qts would get me in the ball park.
1957 Chevy 3200
1972 Camaro
2004 Victory Vegas
Old 03-29-2010, 08:43:05 AM   #8
warped
Location: Sitting in my command bunker waiting for the zombies
A TH350 with stock pan and converter will take between 10 and 11 quarts if completely dry. Once you get 8 or 9 quarts in, start checking the dipstick. get it close and then run the shifter through the gears a couple of times. Check again and fill to the proper level, try not to overfill. Good luck.
Pat
'Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd
by the clean end.'
warped is offline   Reply With Quote
Old 03-29-2010, 09:48:11 AM   #9
gutted72
warped - Thanks for the info. Thats what I needed to know.
1957 Chevy 3200
1972 Camaro
2004 Victory Vegas
