Go Back   NastyZ28.com > Drivetrain & Performance > Competition Camaros
Old 03-27-2010, 12:00:54 PM   #1
OldCamaroNut
OldCamaroNut's Avatar
Pushrod guide plate help please!
These are old school Pro-Topline 220 heads, not the new ones from RHS. I'm wondering if the pushrod guide plates are the wrong ones, although they are the same ones that were on the heads before. The pics clearly show that the intake valve pushrod doesn't line up with the rocker stud. These are the same heads that came off the motor for a rebuild and valve job. I never noticed before that the rocker arm was that far off the valve stem. I'm installing all new roller cam, lifters, pushrods, and rockers. What gives? I removed the guide plate to check for pushrod length with my checker, because it wouldn't fit through the guide plate, and yes, I put it back on the correct way. Help please!!!!
Pic #1
Pic #2
Pic #3
OldCamaroNut is offline   Reply With Quote
Old 03-27-2010, 12:44:16 PM   #2
sooner
sooner's Avatar
Looks like you need some adjustable guide plates like these
http://www.competitionproducts.com/I...tinfo/300-AGP/
I think thats a pretty common problem on the big runner heads.
1997 ws6 t/a
sooner is offline   Reply With Quote
Old 03-27-2010, 01:17:37 PM   #3
gregh
gregh's Avatar
My Protopline 220cc heads have the split guide plates, I think that's your solution.
10.236@131.52mph with a 150 shot & 11.60@118mph NA
A 10 second street car, eh!
SBC 409, through the mufflers, on DOT radials, you know, like a street car should be.
gregh is offline   Reply With Quote
Old 03-29-2010, 05:18:41 PM   #4
OldCamaroNut
Well, upon further review, I found the problem. I took the pushrod guide plate back off and stuck the pushrod back in. If I lined up the pushrod with the stud and valve stem, it was very close (like almost touching) the side of the head. I then pulled one of my old intake rockers out, and guess what? It is offset .150 inch! SOOOOooooo........ I'm sending the new rockers back to Jegs and am going to run my old roller rockers and pushrods on the new setup. Between returning the new rockers and not having to buy new pushrods and adjustable guide plates I just saved $470!
SOLD <sigh> 1979 RS weighs 3580 lbs. with me in it. 406 w/ Victor Jr, Pro Systems 850 CFM carb, Pro Topline 220cc heads, solid roller cam with .630 lift, 264-270 duration @.050, Ross -5cc racing pistons, 12.5 to 1 compression, Forged crank and rods, splayed 4 bolt mains, 1.875" headers. Converter stalls at 3200, Trans Specialties turbo 350, 4.10 gears. Fastest to date is 10.67 @ 124.
