Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Suspension, Brake & Wheel Topics
Thread Tools Rate Thread Display Modes
Old 03-13-2010, 05:21:55 PM   #1
Knuckle Dragger
SoCal Team Mom for Life / Moderator
Knuckle Dragger's Avatar
Send a message via Yahoo to Knuckle Dragger
Caliper rebuild with pictures.
OK I just rebuilt the calipers in my Nova. Seems like this is a bit of a lost procedure given the cost of rebuilt calipers. I thought I would go through and show the process I use. Now, this may or may not be the text book method, I don't know. It's the way I've rebuilt hundreds if not thousands of calipers over the last 20 years or so. The GM single piston is about as simple as they come.
Here we have the caliper in all it's unwashed glory. Notice I have an old pad between the caliper "fingers" and the piston. I'd rather not have the piston slam into the caliper.
Using compressed air I'm going to force the piston out of the bore. This is no time to put your fingers in the way. I'll tell you for a fact that hurts really bad.
I use another rag like this to keep the fluid from flying all over. If you have a customer that likes to stand right over you and watch you work this step can be skipped.
The piston pops out.
Pull the piston out. Take a screw driver like this and wedge the dust seal out. You may have to do this in multiple places.
Pull the seal out of the bore.
This one isn't too bad. I've seen a lot worse. Remember nothing seals in the bore. The o-ring we pulled out of the groove seals on the piston Get it clean but don't stress over perfection. Some of the stains will not come out. As long as it's smooth you are good. Get the groove very clean.
The piston is fairly bad, but will clean up.
A little brake clean, elbow grease and a scotchbrite pad and we have a usable piston again. You can use krocus cloth or if you're careful a wire wheel. It has to be smooth. Any pitting or groves means you need to replace it.
www.jakesperformance.com High performance automotive solutions based on real world experience; a welcome change in the copy and paste world of internet experts.
POS71RS is a gunky
Wheel Vintiques = Horrible customer service.
Knuckle Dragger is online now   Reply With Quote
Old 03-13-2010, 05:35:25 PM   #2
Knuckle Dragger
The bore cleaned up pretty much the same way. I used a screw driver to scrape the crap out of the bottom.
Now we need to assemble. Start with the dust seal.
Push it down to get the lip into the grove on the piston
And then pull it up to sit on top of the piston.
Now comes the o-ring seal, just put it in place no real trick to it. I didn't even take a picture.
Get the lube out.
And liberally coat the piston and bore. Make sure you coat the o-ring seal.
Place the piston in the bore and gently rock it back and forth until it starts to slide in. If you need anything other than your hands to compress it you either need to eat more Wheaties or you have it cocked.
Once the piston is in the bore tap the outside of the dust seal into the caliper. Here you see I have a tool just for that. In the past I've used a punch and even a screw driver when desperate. Don't slip off the ring with either or you will puncture the boot.
POS71RS is a gunky
Old 03-13-2010, 05:48:25 PM   #3
Knuckle Dragger
And we have an assembled caliper ready for service.
I've been preaching the importance of hardware for a bit now. Lets take a look at what I'm talking about.
These little buggers look like they are pretty unimportant. There pretty simple but are often over looked, as they were with my Nova.
It consists of a sleeve
and o-ring
And the grove in the caliper
I replaced mine, more on why in a bit. If the o-ring is OK you can clean and lube the sleeve and move on. They need to be really clean but use enough lube to let them slide up and down with your fingers, but not enough to attract all kinds of dirt.
Remember, the other side of the caliper has a smaller o-ring that rides on the pin. It needs to be changed too. Pay attention to the end of the pin. This picture doesn't show it well, but the end is grooved and will hinder caliper movement and they need to be replaced.
The sleeves on my Nova had to be forcefully driven out with a punch and harmer. I suspect this was my pull and my brake pull. The caliper could not slide back and held the right brake slightly on. Pay close attention to these slides because they are the source of a lot of brake complaints.
I hope this post helps someone. If you have any questions or corrections feel free to ask or reply.
It's important
POS71RS is a gunky
Old 03-13-2010, 05:53:51 PM   #4
1973bigblock4sp
How long did it take to rebuild them.
1973bigblock4sp is offline   Reply With Quote
Old 03-13-2010, 05:55:52 PM   #5
Knuckle Dragger
It takes me about 15 minutes a side start to finish. I'd say the average hobbyist could have both done in 45 minutes to an hour.
POS71RS is a gunky
Old 03-13-2010, 05:53:04 PM   #6
Knuckle Dragger
and o-ring
With the low cost of replacement calipers it may seem like a waste of time to rebuild your own. IMO when I'm done with the job I know for a fact it was done right. The rebuild kits were $2 each, the hardware kit was another $3 for both sides. Well under the cost of a rebuilt caliper and I trust my work over some dude on an assembly line any day of the week.
POS71RS is a gunky
Old 03-13-2010, 07:07:19 PM   #7
Big-Dave
Big-Dave's Avatar
Nice How-To. Would be a good Stickie. I have an old set of calipers ,maybe I'll do a rebuild while Camaro is stored. Thanks
Big-Dave is offline   Reply With Quote
Old 03-13-2010, 07:22:37 PM   #8
Gary S
Great information. Who sells the kit with the O rings to do this job?
Gary S is offline   Reply With Quote
Old 03-13-2010, 08:04:06 PM   #9
BonzoHansen
LGM, Administrator
BonzoHansen's Avatar
Send a message via AIM to BonzoHansen
Rockauto does, any auto parts store should be able to order them for you.
O-Rings
DORMAN Part # D35494 More Info {First Stop #5468767, 8124574, J8124574, J8126755}
Front; Bore = 2-15/16" $1.77
RAYBESTOS Part # WK524 More Info {Professional Grade}
Front $2.06
Hardware:
ACDELCO Part # 18K265 More Info {#18034594, 18034639, 18K220}
CALIPER KIT,FRT BRK DURASTOP
$3.62
You know, reman calipers are only like $20, but after going through a number of remans with casting issues, this may be the way to go.
"stickied"
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJFBOA
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
BonzoHansen is online now   Reply With Quote
Old 03-14-2010, 12:30:23 AM   #10
INSPECTOR57
INSPECTOR57's Avatar
"stickied"
Plus you know the ones that came off your car will fit (should ) back on.
And the owners concerned about numbers matching are happy.
P.S. I did this with my original calipers; excellent pictorial
Gary
INSPECTOR57 is offline   Reply With Quote
Old 03-14-2010, 01:04:49 AM   #11
Philip
Philip's Avatar
Nice job Dave. I remember when the O rings and sleeves for the slide bolts were included in the brake pad box. Now they charge extra for them.
The calipers I purchased for the Nova had metric holes for the banjo bolt and the old ones were SAE. Another reason why rebuilding what you have makes good sense.
77 Nova 406, TKO-600, 3.73 posi
82 Corvette
Philip is offline   Reply With Quote
Old 03-14-2010, 02:06:25 AM   #12
Kunihiro
Daver's,
I'm just curious,,,,how come you didn't get the calipers powder coated when you had them apart?????
Did you want to keep the original look?????
Nice pictorial,,,,,,,but you must've been either 390 (drunk) or a better camera for the close up shots...LOL!!...
Allen
Allen's 71RS
"Z" car - Sorry it's a 350Z!!
Kunihiro is offline   Reply With Quote
Old 03-14-2010, 02:17:13 AM   #13
Kamikaze
Kamikaze's Avatar
Thanks for going back to the basics for everyone Dave!
Takes time to do the lesson and photograph step by step but this is one of those basic service things too many people take for granted and need to know!
There's another thread I replied to about calipers causing uneven wear and need to refer the OP to this thread!
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 03-14-2010, 09:17:05 AM   #14
79camaro2001
79camaro2001's Avatar
Originally Posted by Kunihiro
Daver's,
Allen
Powder coating brakes? That cost money and a normal hobby man wouldn't waste money on something like that when they aren't seen through the wheel anyway! They would buy beer!
Check out my camaro
1979 Camaro picture site
79camaro2001 is online now   Reply With Quote
Old 03-14-2010, 09:54:25 AM   #15
Knuckle Dragger
Daver's,
Allen
Normally I would have put the housings in the parts washer and done a much better clean up job. I don't have access to one this weekend and this is my daily ride so it was a wham bam type deal today.
POS71RS is a gunky
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
