03-09-2010, 10:45:55 PM
#1
Advice with 144 blower combo--500hp goal
Whats up,
I just picked up a B&M 144 blower for a good deal and its in great condition. I'll be doing a 357ci motor with it and its going into my corvette. My vette is a stick with 3.73 gears. weights 3650lbs with me driving.
Heres my car:
So far I have:
144 blower (5.8psi pulleys-will swap to 7psi 2.86 top pulley)
357ci block machined with GM forged Crank
forged gm "pink rods"
new 1.6 roller rockers-harland sharp
750cfm speed demon mech carb (not boost referenced)
I was thinking of getting:
Forged pistons
AFR 195cc eliminator heads
850cfm blower carb
hyd roller cam with split duration and 113LSA
MSD boost retard system( i have HEI with re-curve kit and MSD coil and 6a box now)
Looking to make as much power and torque as I can with the mini blowerin the idle-6200rpm range for street/strip driving. I want be close to 400rwhp/400'lbs of torque if possible. I wanna spins tires for a roll but also have plenty of mid-upper rpm power.
My car buddies tell me I'm wasting my time with a mini blower and they dont make power so I'm trying to prove them wrong. I have connection at local dyno shop so it will be tuned once completed.
My questions:
Should I get a blower carb or can my current carb be boost referenced? Is 750cfm fine for my power goals or is 850cfm a better match?
need options on cam size? i thinking of something like a nX288HR comp nitrous roller cam:
288/315 236/248 .555/.576 113/108 2500-6500rpm....cam will be too big in N/A 357ci but will the blower keep low end torque up and cam will make power in upper rpm?
Will a mech fuel pump work to support blower motor? have a high vol carter mech pump now.
need opinions on decent priced forged pistons?- looking for 8.5.1 CR (75cc heads, blocks not decked)
combo wont be rushed and I'm opened to all suggestions and opinions.
03-10-2010, 08:57:44 AM
#2
I just typed out a whole long thing and then lost it. Here's the shorter version:
You're at the limit with that blower hitting the 500HP level. Doable, but at the limit.
Overall, it's a good plan, but I'll make a few suggestions from my experience of what works:
1. A little too much cam. I like the cam family you've chosen but you're about 10* too big. Notch down 1 step. High revs are not in the cards with these little blowers (efficiency falls like a stone as RPMs rise) and you can't waste what little airflow they're capable of by blowing any of it straight out the exhaust with a big cam. Sub-6000 RPMs is what you're looking for since the blower's efficiency drops quickly in the higher RPMs. You have to build the combo around the blower, not the other way around. Unlike a big X-71 blower there is very little "headroom" to pulley them up. The old rule about the COMBINATION of parts being more important than any single part alone.
2. A little too much compression. You're going to want to be down in the 8:1 range or a little less. Boost is much more important to making power than compression is. And you don't want to flirt with detonation in a blower motor- it can destroy things very fast. Nothign exotic- just a set of forged SpeedPro pistons will work fine. Do the math on which ones will get you down in the 8:1 range or even a little lower.
3. Just changing the top pulley won't get you to your goals. You need the bigger 7" bottom pulley and maybe the smaller top one with it as well.
A 750 carbs is good enough to get your going but is marginally too small for your goals. Can't say if your existing carb can be boost referenced but most Holley carbs can. This isn't the first place I'd look to drop big coin, though. If buying a big new carb already set up for a blower was going to impact your ability to afford those really good AFR heads, I wouldn't do it (just as an example). But if you can afford both, do both.
The 383 in my Malibu lays down 390HP at the rear wheels along with 420+ ft/lbs of torque (factoring out converter flash spikes which are well over 500). I have worse heads (older AFR 190s and 8:1 compression), a tiny flat tappet cam (214/224* on a 112* LSA) and I use a home-tuned QJet carb (no boost referencing) along with a near-stock HEI distributor (no box, no boost retard, just careful ignition curve timing). I'm running the 7" bottom pulley and stock 3.07" top pulley, yielding about 5PSI of actual observed boost. Converter is a Redneck unit built for a blower with a stall around 2700. Rear gears are highway 2.73s.
Peak power is at 5500 and falls off rapidly past 6000 (I never take it over 6000 for that reason). Peak torque is so low I can't measure it on a chassis dyno with the converter effects at the low end of the RPM range. Real peak is probably right around 3000-3500.
Low end torque is absolutely unusable on street tires. I can spin violently ANYWHERE in 1st gear, including from almost a 40 MPH roll (downshift into 1st). 2nd gear is marginal traction for about a second or two after the shift as well. Quite frankly, it's a silly-stupid combo to try to hook up on the street. But silly-stupid fun as well.
You'll probably quickly tire of the 3.73 gears out back without an overdrive. It's not going to be a high revving combo and hooking up with steep gears is going to make your traction situation even worse than mine on street rubber. The little blowers make MOUNTAINS of low end torque (much more so than your would think from just a half dozen pounds of boost) and just don't need very much gear to pull you away from the line.
1990 454SS pickup. Original "tow truck motor" 454 upgraded to something a little more "aggressive." Seems pretty stout but the fuel bill is nuts.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid 12s appears to be the best it's gonna do on street rubber. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
03-10-2010, 10:17:13 AM
#3
Welcome to the site. What part of CT are you from?
Damon knows his stuff when it comes to the baby blowers
03-10-2010, 11:01:08 AM
#4
Thanks for response, sucks the first post was lost but thanks for taking time to redo it. sounds like your combo is making good power and torque. The 383ci probably helps out with torque also, with my 357ci I'll probably be under you numbers.
For cam I was thinking of having a custom grind made. keep duration lower then posted cam like in 226-230, 236-240 range and on a 112/107 or 113/108? Going hyd roller
I should have enough in budget for both AFR heads and blower carb. I'm thinking an 850cfm mighty demon blower carb with annular boosters. Then I'll sell my current carb.
As far as gearing I'm gonna have to keep the 3.73s, rear is new and a custom built 12bolt. I'm thousands invested in it and it only have about 100miles on it so far. However, I was planning a 5spd od swap in future.
As far as boost, will it be hard to make 7psi of boost with good flowing heads? I was told on a few other forums to expect 5psi even with swapping pulleys because heads flow too good to get higher boost. chart in instructions shows 2.86 top pulley with 6" lower will be 2.11 drive ratio and create 7.2psi of boost with 357ci, Whats the advantage of swapping to 7" bottom?
03-10-2010, 11:01:40 AM
#5
Thanks,
I'm from wallingford, ct
03-10-2010, 12:01:35 PM
#6
Originally Posted by L-82kid
Thanks,
Cool, they're building a Sonic there soon, I'm psyched, lol.
I used to go to the Wallingford Walmart cruise a lot, back when BJ's was a walmart. I still head down to Heavenly Donuts in Derby on Sundays. I'm anxious to get the car out for the season soon.
03-10-2010, 01:58:28 PM
#7
I've got a 355 with a B&M 144 blower I race all the time so you can copy my setup if you like:
4 bolt main
Speedpro forged 4 valve relief flat top pistons.
X-rods
Steel crank
Dart Iron Eagle 200cc heads with 72cc chambers
Holley 950hp carb
Hedman 1 3/4 headers
2 1/2 exhaust w/2 chamber Flowmasters
Performer RPM cam + 1.6 rockers
Mallory Unilite LOCKED distributor set to 34 degrees total
Mallory HyFire VI box
1.61 60 foot still sprinning - too much bottom end. Went 12.07 @111mph last time out. The car weighs 3500lbs.
Have fun!
03-10-2010, 02:17:03 PM
#8
The old walmart cruise nights were the best. They were the 2nd and 4th sat of the month, i used to go all the time.
Ive heard local rumors that the Sonic is being delayed because of issues with zoning laws. Rt 5 is too close to the build site and they cant move it back from road because of railroad tracks behind lot. A few people are saying that it might not even happen at all now!!!
we'll just have to wait and see.
03-10-2010, 02:22:31 PM
#9
4 bolt main
X-rods
Steel crank
Holley 950hp carb
Have fun!
thanks man, Do you have videos of you car or sound clips?
I've seen another 144 blower combo with the RPM cam in an S10, that set up made around 400rwhp 420'lbs. whats your Shift rpm with that cam and heads? rear gear ratio?
Whats your CR with the flat tops and 72cc heads? how much boost is the blower set up for?
My short block with me similar to yours: I have a 4-bolt block with GM forged crank, X rods, and I was thinking of speed pro forged pistons.
03-10-2010, 02:58:55 PM
#10
Blown Camaro
I called Weiand and they recommend a lunati flat tappet cam:
303/315 234/244 .488/.509 112/107
Your cam is very close: Rpm cam
308/318 234/244 .488/.510 (.520/.544 w/1.6) 112/107
duration at .050" is dead on recommended and so it LSA/ICL
how does that cam idle? I enjoy a rough idle for that muscle sound.
03-10-2010, 07:13:02 PM
#11
Won't eat McDonald but will eat Sonic? LOL
Welcome to the site L-82kid
03-10-2010, 08:41:45 PM
#12
Speaking of blowers and the old walmart cruise, maybe you remember my old car?
http://i31.photobucket.com/albums/c3...e/Mvc-014f.jpg
03-10-2010, 09:17:55 PM
#13
Your smaller cube motor would actually make almost exactly the same numbers as my 383 if all other components were the same. It's just that you would likely see higher boost while hitting those nubmers. In short, the amount of power it makes is mostly a function of the blower pulley ratio, not so much the difference of a few dozen cubic inches of displacement.
A roots blower moves basically the same amount of air per revolution no matter what engine is under it. Boost is just a by-product of how much restriction the engine is to the amount of air the blower is trying to cram down it's throat. In fact, if I was building my engine over again I'd probably just do a 350. Piston selection is much broader for hitting the low compression ratio you're looking for with a blower. Off the shelf low compression 383 slugs aren't nearly as plentiful as for a 350.
A roots blower combo is different than a N/A combo in this respect. A larger cube N/A engine can simply draw in more air per revolution to fill the larger cylinders. A roots blower engine can only draw in how much air the blower is feeding it, no more, no less (even though it is bascially force-feeding it, which is, of course, the whole idea). If it's filling smaller cylinders it will just show more boost but the same quantity of air is still being shoved in. The difference is, of course, with higher boost levels come greater heat and greater tendency towards detonation.
Note how different my combo is from some of the others you've see and have been posted about, above. Yet they all make similar power numbers.
03-10-2010, 11:52:57 PM
#14
Whats up,
Heres my car:
So far I have:
Forged pistons
850cfm blower carb
My questions:
Your proposed motor with 0.100" dome forged pistons and a Crane HR 119841 .539/.558", 234*/242* dur, 112LC Cam exceeds 500 HP on 64cc AFR's Makes it 11:1 and 93 octane friendly.
To go with the blower you need big chambered heads, 75CC or so and dished pistons to make 8:1 compression. The over boost will bump you up on the low end but may not help the big end because of air flow limitations of the small blower heating the air. Build it N/A and save the headaches.
Don't over carb it, it'll drop its pants and cough more times than not, especially when everyone is watching.
Your car isn't a Dyno, magazine articles are written to sell products.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
03-11-2010, 10:50:03 AM
#15
It's pretty hard to over carb a blower motor. I was running 2 750's on my 355 sbc.
I figure at it's peak performance it was close to 500 hp. I probably could have gotten 100 more if I had better heads and cam.
| Thread Tools |
| Display Modes |
Linear Mode
