Old 01-05-2010, 08:06:13 PM   #1
80/RS
quick fix rear main seal?
don't have the time to pull the motor right now as i have to many things on the go right now. So i was wondering if anyone has a quick fix additive that would work.
Thanks
80/RS is offline   Reply With Quote
Old 01-05-2010, 10:24:43 PM   #2
dirtplay1975
lucas engine oil stop leak should at least help sow it if not stop it for a while. I use it on my daily driver, my truck tends to get a little crankcase pressure and push past the rear main when workign it on highway but with this stuff its dry
81 "phantom" Z 327, th350
49 Studebaker rat rod truck, S10 frame, chopped top, 425 caddy powered
77 GMC crew cab 1/2ton slammed,2000 5.3L/4L60E and 2000 silverado interior
91 Mazda Miata my lil gas sippin street legal gokart haha
66 Lincoln Continental 2dr hardtop
07 Yamaha YFZ450
dirtplay1975 is offline   Reply With Quote
Old 01-05-2010, 11:32:20 PM   #3
80/RS
I thought about thatjust was not sure if it worked or not
Thanks
Old 01-06-2010, 12:08:26 AM   #4
tom3
Used that stuff in a steering gear and an auto trans, both were leaking. Took a week or so but it really did work. Amazed the heck out of me.
tom3 is offline   Reply With Quote
Old 01-06-2010, 12:22:54 PM   #5
Mark80Z28
I picked up a bottle of Lucas Oil Stop Leak too. I'll put it in when I change the oil in the spring, if there ever is a spring! If it works as well as their Automatic Transmission fix did for me, I'll (or we'll) be in good shape!
BTW- this should maybe be in the engine topic forum?
Mark80Z28 is offline   Reply With Quote
Old 01-06-2010, 12:25:14 PM   #6
nukeemz28
You shouldn't have to pull the engine to replace the rear main unless it's a one piece design. Take the distributor cap loose, jack engine up as high as possible, remove torque converter cover, remove oil pan, (may have to turn crank to position #1 rod journal up) remove rear main cap, replace seal.
nukeemz28 is offline   Reply With Quote
Old 01-06-2010, 02:57:57 PM   #7
80/RS
cool thank proble is with changing it at this time is #1 weather #2 i am giving up my garage and moving the car to another garage but no work is allowed. So i was thinking of just a quick fix for the time being. And when i get moved i will change it
Thanks for all the help
