Old 12-17-2009, 04:46:51 PM   #1
jtscollect
Suspension Setup Suggestions for 1973 Z-28 Camaro
Good Afternoon:
I am going to be in the planning stages in early 2010 regarding suspension setup for our 1973 Z-28 Camaro.
I would appreciate any input or suggestions.
Several things we would like to accomplish with a suspension upgrade/change:
1. Improve overall ride
2. Improve cornering capabilities
3. Have a profile with car slightly higher in the rear than in the front (subtle)
Currently, we have 17x7 wheels with 225/17/45s in the front and 17x8 wheels with 255/17/45s in the rear. Will probably change to 245/17/45 in the front and 17x9.5 wheels with 285 or 295/17/40 in the rear (not sure on the rear tire size yet).
The car will be used for street/strip, but mainly street use.
Thanks for your help.
Jim T
“Red Bomber”
jtscollect is offline   Reply With Quote
Old 12-17-2009, 08:25:28 PM   #2
mjoc
go with the hotchkis TVS system all around. if you are looking for a stock style setup. or go with coilover fronts and a torque arm setup in the rear.
Mike
1995 GMC Yukon 4x4, 2 door with 6 in. Lift, 1967 Buick GS400 Convertible, 1970 RS/SS Camaro,, 2008 F450 crew cab Lariat 4x4, 1954 Triton Motorcycle (original period correct cafe racer.) 1967 triumph Bonneville chopper.
mjoc is offline   Reply With Quote
Old 12-17-2009, 08:34:58 PM   #3
jtscollect
Quick Reply
Good Evening Mike:
Thanks for your input.
Jim T
Old 12-17-2009, 09:09:36 PM   #4
79T/Aman
Site Sponsor
79T/Aman's Avatar
I think in order to actually finish a project it is a good idea to also set a budget, things can get out of control fast, tire choices are good, I would stay away from hybrid coil over kit and use a std. spring and shock, miles ahead dollar wise and proven combination, paying attention to the chassis is also very important, frame connectors and solid body bushings are one of the first things to do.
Manufacturer of The original GT suspension kits, frame connectors, modular roll bars. www.pro-touringf-body.com
79T/Aman is offline   Reply With Quote
Old 12-17-2009, 09:54:23 PM   #5
jtscollect
Quick Reply
Thanks 79T/Aman.
Yes, we are keeping the car basically stock looking and do not want to get out of control on upgrades. My wife is a CPA and CFP, so she'll keep on my butt in that regard!
This will not be a $50K or above car.
We plan on building another muscle car in a few years, so we want to make them enjoyable drivers, not show cars.
Jim T
Old 12-18-2009, 09:25:52 AM   #6
warped
Location: Sitting in my command bunker waiting for the zombies
Go to Dave's (79T/Aman) site and look at one of his complete front end rebuild kits. It will be a good start, and in combination with the correct rear springs and shocks, will offer just what you are looking for. give Dave a call and he will be glad to give you all the help you need. good luck.
http://www.pro-touringf-body.com/cha...omponents.html
Pat
'Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd
by the clean end.'
warped is offline   Reply With Quote
