Old 12-08-2009, 04:44:23 PM   #1
Drg racr
Semi Trailer For Storage?
I'm curious if anyone has used a semi trailer as a storage unit. I've seen a few being used as such.
1. Can you control the humidity in them?
2. Where can I get one to rent or buy?
3. Are they expensive?
4. Or would it be better to just rent a space? (I'd need a lot of space).
I may be moving after Christmas and a lot of my stuff will have to go into storage. Most of my house stuff will go into storage. My car will be coming with me
If it makes a difference, I'd be using it in East Central Indiana (near Richmond, IN).
Real musclecars have 3 pedals!
Drg racr is offline   Reply With Quote
Old 12-08-2009, 05:56:52 PM   #2
dcs13
this is one of the popular rentals...http://www.pods.com/
I see them on craigslist a lot. Not sure on the humidity issues though.
dcs13 is offline   Reply With Quote
Old 12-08-2009, 05:59:14 PM   #3
Kregb
1. Can you control the humidity in them? If you get a refrigerated trailer
2. Where can I get one to rent or buy? Check the auction companys
3. Are they expensive? depends on your idea of expensive
Most storge facilitys are more secure but there are exceptions.
P.S. My 1926 Model T has three pedals one makes it go backward.
Kreg Burke
Erie, CO
'70 Camaro what ever it is when ever it's done
Kregb is offline   Reply With Quote
Old 12-08-2009, 06:38:15 PM   #4
Drg racr
I checked into Pods, they said they cannot rent to me because I'm not in their service area.
I looked at Craigslist, I found a few from $1000-$2000. Still cheaper than a shed, though. I'll end up spending around $100 permonth for a 10x15 storage unit, and I'm not certain that'll be enough. I have to fit almost all the contents of my house into it.
Old 12-08-2009, 07:40:40 PM   #5
MidnightBlue72
MidnightBlue72's Avatar
Ive drawn up some plans for these "Shipping Containers" I posted my ideas here a few months ago. These containers are piling up by the tens of thousands from China becuase nearly nothing is being shipped back.
One idea I had was 2-20's placed next to each other, welding the center together, cutting out the innerwall and having a 16x20' gargage.
Next was 2-20's placed 30' apart and building a connecting roof between the two and using one for the tools and storage and the other a garage. The space between would be closed off on the back wall and used for the actual work area.
The "Shipping Containers" are 8' wide and 20' or 40' long, interior is 7' (?) ALWAYS inspect and check the container, all of them have hardwood floors and some are so old the are rotten. Also some have rust/rot because of the exposure to sea air/spray
Homes are being build with these, VERY nice examples too.
My posts are not intended as legal advice and do not represent the positions of any public or private organization that I am employed by or associated with.
*Disclaimer*I'm calm, I'm not angry nor enraged. If you read my sterile, inflection free post to yourself and felt I AM angry, please seek professional help and or increase the dosage of your meds. Call 1 (800) 950-NAMI
MidnightBlue72 is offline   Reply With Quote
Old 12-08-2009, 07:43:52 PM   #6
Kamikaze
Kamikaze's Avatar
To add to the details of the shipping containers, the heights vary from 96" inside to 110" (high Cube).
Lengths available from 20', 26', 40', 48' & 53' Not all are easy to get like the standard 20' & 40'.
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 12-08-2009, 07:49:00 PM   #7
ATM
King of the World
ATM's Avatar
My company has a storage shed, and the place is entirely made up of these containers. All in a row, different aisles, right next to one another. It works out very well. When I used to work construction, we used one for a mobile shed, kept alot of tools and spare parts in it. Moved it around with a wheel loader and forks. I like them, I would go that route, if you get one with a trailer under it already you could have it moved. Getting one without a trailer may pose a problem moving it with all your stuff in there.
Steve
79 Camaro Project
ΜOΛΩΝ ΛΑΒΕ
350 4 bolt, Line Bored & studded, Zero Decked, Scat Crank, Forged Rods, Forged pistons, custom Bullet solid flat tappet, 247/256 @ .050, .570/.556 on a 106lsa installed at 102ic. , Fully Ported, milled Dart Iron Eagles 2.05/1.60 5 angle valve job, back cut valves, 1.6 Full Roller Rockers, Ported RPM Air Gap, Holley 850, Edelbrock Aluminum Water Pump, MSD
ATM is offline   Reply With Quote
Old 12-08-2009, 07:50:22 PM   #8
there's a place over near the port of long beach off of santa fe ave and alameda and the 405fwy that sells and rents used shipping containers from 20' up to 53' including refrigerated containers
muscl car is offline   Reply With Quote
Old 12-08-2009, 08:23:27 PM   #9
z28rod
how much do the cotainers run
z28rod is offline   Reply With Quote
Old 12-08-2009, 08:27:37 PM   #10
back in early 2000 my company purchased (2) 40' containers from that company for $3k
Old 12-08-2009, 10:11:06 PM   #11
bfmgoalie
Shipping containers (ocean going) are 20' or 40'. Trailers of 48' and 53' are not considered containers, although they basically do the same thing, depending on the structure and design.
The Biker 69
"It's not the destination....its the journey!"
1973, 500 CI, L88 Heads, Holley 950 3 Barrel, Edelbrock C427X Intake, TH350, 3800 Stall, Reverse Manual Valve Body, Tranny Brake, Line Lock, 3:73s and a bunch more.
2011 Adirondack Nationals Favorite F-Body
bfmgoalie is online now   Reply With Quote
Old 12-08-2009, 10:58:23 PM   #12
patgizz
patgizz's Avatar
there are usually full rolling semi trailers on craigslist here for $600 but i dont know how legal they are to get to your location.
patgizz is offline   Reply With Quote
Old 12-08-2009, 11:11:34 PM   #13
MidnightBlue72
I called a place in Montclair that quoted me $1500 for the 20'ers dropped on location and pre-inspected.
The reason I was going with shipping containers is the city Nazis dont require a permit due to no permanent foundation.
Then I found out that installing to 20' long 8' wide containers between a 10' RV gate was a no go.
I would need to rent a crane to drop them on my RV parking, so my plans are on hold now
Old 12-08-2009, 11:57:20 PM   #14
Kamikaze
Kamikaze's Avatar
bfmgoalie,
48' and 53' ocean freight containers are available here on the west coast and are commonly used from the Pacific Rim / Asia shipments. At one of our businesses, we've dealt with the receiving and shipping of goods in these sizes frequently overseas to many parts of Asia.
I will grant you that they are more commonly found on over the road movements for some inter-modal carriers and are rarely used in the shipping lanes from Middle East, Europe and South America to the East coast.
Old 12-09-2009, 03:19:11 AM   #15
1981z28owner
we have a 40 container box that we used to extra storage for our trucking company and even stored a lemans in there for a bit. works pretty good.
Blue 1981 z28 4 speed with SBC 355 and 4.11 rear end. 12.43 at 121.72mph, but best ET at 12.23 at 113.4.
1981z28owner is offline   Reply With Quote
