if its a 4 speed u can change out the plastic gear @ the trans, that matches your rearend gearing. some times they go bad or the trans or rearend came from a different donor. my 4 speed came from a chevelle so the speedo out put gearon that trans didnt match my 373 rear gearing on the 73 Z
350 .60 = 360/1182 crnk /frged scat rods/ross frged lght wt slugs/sld flat tap 246 @ .050. 531lft 106cl/041 hds prtd to mx ss mnly vlvs/vic rpm air gap/Holley 670/11",4spd/373posi. F the 383 I need an lq9.cny carver http://s303.photobucket.com/home/Daves73Z28
