10-31-2009, 01:52:16 PM
#16
Originally Posted by hhott71
I'm using stock hinges and no springs on a used fiberglass cowl hood. It has the inserts for the hood molded in it.
I use an ultra high tech prop rod,,,, 1/2 PVC pipe cut to 39" long. It is stored in front of the core support resting on the place where the hood latch and hook (hook removed) and the ends tuck up under the header panel. It stays put there when racing.
I use a cut down hockey stick, keep it in the back seat, or trunk.
Just use a bottle of "New car smell".
11-01-2009, 07:37:39 PM
#17
Thanks 82 Vettrin...I am looking into shops that can beef up the attachment points on my hood...I'm with you on removing it..I tried by myself but it's too awkward for one person, at least this person...lol...
11-02-2009, 03:54:37 PM
#18
Are you from Canada?
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Accel EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ Equus gauges & custom bezel
My Chevy garage GEARHEAD dezign
11-04-2009, 02:32:34 PM
#19
I have a similiar situation except I've got the Glasstek 4" "bolt on" hood. I was able to use the factory hinges but my radiator core support was completely removed along with the hood latch mechanism. Same situation as you, I needed to have my hood pop up after I removed the hood pins so I could lift the hood up and prop it open. I researched through the Grainger catalog and found some springs that were perfect in size, length and strength that fit over the hood pins and pushed my hood up just enough to clear the forward valance panel. Also, instead of using a prop rod, I extended the hood hinges to the full up position and drilled a hole in each of the hinges so I can use a quick release pin to lock the hood in the up position. Then I welded a mount plate with 2 holes to store the pins under the hood when not in use. I don't use springs of any kind on the factory hinges with fiberglass hoods. My experience with light weight hood hinge springs is, over time they will warp the hoods and bow them up. Sorry I don't have any pic's of it, the front clip is off the car right now. Hope this helps, Rob
| Thread Tools |
| Display Modes |
Linear Mode
