Old 08-20-2009, 12:05:10 PM   #1
gookc
Transmission electrical wiring for Turbo 350? and Turbo 400?
HI guys. I am a member of 2nd Gen Camaro owners group, as well as NastyZ.com. I have a 1972 R/S, and a project 1970 Camaro.
I have some questions on my latest Fbody project .
I just recently swapped a whole drivetrain from a 1970 Formula 400, into my 1970 Esprit.
The esprit came with a Turbo 350 auto trans, and had an electrical connection on the passenger side of the trans.
- Can anyone tell me what this wiring plug is for?
Also, I did swap out the stock Turbo 400 wiring for the kickdown on the gas pedal side.
- But how do you wire up the kickdown switch to the turbo 400 trans?
Any help much appreciated.
gookc is offline   Reply With Quote
Old 08-20-2009, 12:32:50 PM   #2
buckwheat
The switch below the cooling lines is a TCS switch Transmission Controlled Spark . Allowed the transmission to disengage the spark advance when in high gear . The 400 kickdown is a 12volt B+ supply No relays required . The wire simply dumps the clutch fluid supply solinoid inside the pan allowing the next lower clutch to take over . You need a contact switch on the throttle when in the wide open position .
buckwheat is offline   Reply With Quote
