07-21-2009, 11:43:14 AM
#16
Location: No portion may be used with or without permission
Originally Posted by John Wright
For the moment I am gonna do all the basic stuff first.
Cut tunnel for shifter hole
cut tab on crossmember to relocate.
assemble clutch pressure plate.
And a LT1 starter is needed as I found out. Stock auto does not work.
07-21-2009, 12:33:27 PM
#17
His trans tail is -3 relative to the carb mounting pad, not relative to actual zero level, right? So that still doesn't tell us anything. He needs to know the trans tail relative to the pinion. I think measuring the angle formed by the centerline of the trans output would be easier figured as 90 deg relative to the flat surface on the balancer, since its a larger, flatter surface than sticking an angle finder on the end of the trans mainshaft. And then the driveshaft will make 1/2 that angle at each joint. I think.
Steve
Steven H. www.carfap.net
1985 BMW 745i Turbo, Euro model import, 18" Antera wheels
1986.5 Porsche 928S, 5.0 32v V8, 18" 993 turbo wheels
1999 Chevy C1500, new 5.7 Vortec, 4" lift spindles, EFILive V2 tuner
2003 Mercury Marauder, 4.10s, Heinous billet rear control arms, SCT Advantage III tuner
2004 Taurus SEL, Ingalls tubular control arms
07-21-2009, 12:35:47 PM
#18
Sounds like you are on the right track!
What motor is this going behind? Just curious on what you are going to use for a flywheel if it is a 2 peice rear main.
72 SS396 under restomodification.
500hp 468 w/t56 transmission
and way to much other stuff to list.
07-21-2009, 07:49:55 PM
#19
99 roller cam vortec 350 with a 97 LT1 flywheel.
07-21-2009, 09:15:10 PM
#20
So I wont be able to do much today, but did get some pic's.
the hole for the tunnel will be right at the edge of the floor brace.
Maybe need to cut just a 1/4 of it to clear. Made me feel good to see
thaT CAUSE I seen some folks cut into the brace, like half of it.
I have not cleared the heavy grease away, but it looks like I wont even have to cut
into the brace.
07-21-2009, 10:29:36 PM
#21
Aaah, OK. My T56 looks to be sitting a little further back than yours (but I moved my motor back as well). I did end up cutting in to the brace. No big deal, I'll be welding it back up anyway (and probably cutting out a good chunk of the tunnel and welding new metal in there - to fit the GTO console). The GTO transmission is slightly longer (by about 1cm) than the F-body transmission, and I'm using an F-body transmission case right now for mockup.
94ZRagtop - The Black Car
79Z Hardtop Project BubbaZ GTO LS2/6-speed/APS Twin Turbo Kit has begun... Retrofit in progress...
07-21-2009, 10:50:36 PM
#22
I should be able to start cutting tomorrow.
WOW man, you been on here 10 years with 293 post... thats a long time.
07-21-2009, 10:57:11 PM
#23
That's weird. I'm running my stock 350 bottom end, factory position motor mounts, and my LT1 T56 came back far enough that I did have to cut the brace slightly. Are your motor mounts set forward??
07-21-2009, 11:04:27 PM
#24
LGM, Admin
I was thinking that too. I now mine is waaaay farther back because I used a different setup, but I thought you & Woody had to cut, just less.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
07-21-2009, 11:10:25 PM
#25
Yeah, I pop in and out. Take a few years off here and there, as my Camaro focus changes (I got swallowed up in my 94Z for a while, and then built my 98Z, now I'm back to working on my 79Z). I worked with MadMike when I lived in Georgia, knew about the board within a day or so of it going live. My screen name was actually a joke, as my son Drew was 3 months old at the time. Now he's much much more dangerous. lol.
07-21-2009, 11:16:32 PM
#26
My motor is in the stock position with poly motor mounts. I think if
it was ever moved, the trans crossmember would have to have new
holes drilled in the frame. So with the crossmember in the factory
location, I dont think the motor was moved forward.
07-21-2009, 11:34:01 PM
#27
Here you can see my motor mount location - I'm using poly mounts in stock clamshells, an adapter plate, and the stock block mounts. You can see how the mounts moved back 2" or so. I have to put it there to clear the F-body oil pan and to put that turbo in the right spot.
Here's where my shifter ended up (inside):
07-22-2009, 12:25:50 AM
#28
Check the progress on the second re-incarnation of the same '70 sport coupe (in 6 years)at: Click Here
07-22-2009, 01:17:23 AM
#29
You can use the stock starter for the small diameter flexplate (straight across bolt holes) with the LT1 T56 but you have to clearance the bellhousing a bit.
07-23-2009, 09:46:19 PM
#30
Well the ATS bracket came in. If it works correctly i would say its worth
its price in every way. this is a very well made piece.
| Thread Tools |
| Display Modes |
Linear Mode
