07-20-2009, 02:41:31 PM
#1
What I learned Saturday. Water Pump. Elec vs Belt
I have used the Moroso electric water pump kit on the Racecar since 2001 as it was on the Vega when I bought the car.
After rolling the Vega a couple of years ago I installed the engine and trans in the Camaro.
Still using the Moroso water pump drive because Overheating was never a problem and I could circulate the water through the radiator in the staging lanes with the engine off to cool it quickly if needed.
Saturday, the Electric motor gave up and shorted out on the return road.
That was the first time run so I had time to R&R the electric set-ups cog pulley and install a stock water pump pulley and belt. Then ran the second time run.
I turned 11.518 @115.41 with a 1.5902 60' in the left lane on the first time run.
I turned 11.546 @115.38 with a 1.6084 60' in the right lane on the 2nd time run.
Looking at the incremental and MPH's it appears that the Engine driven water pump (AKA Stock) is as efficient as using a Moroso electric water pump drive. As far as ET, MPH, and HP is concerned.
First round I had 1 1/2 cars on my opponent at the stripe. I ran 11.51 @ 112 getting out of it so I wouldn't break out, but I did on my 11.54 dial-in.
He ran 11.06 @ 112 on his 11.04 dial-in. His normal MPH is 121 My bad for leaving a 1.5 car margin. As he could see he wasn't going to catch me so he dumped even more that I did. My R/T was 0.0290 vs 0.0904
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
07-20-2009, 02:47:43 PM
#2
I always wondered about those electric water pumps, they really pull some amps and if your running an altenator those amps being pulled by the pump are then being made up by the altenator. Good info, thanks.
07-20-2009, 03:20:14 PM
#3
The power is never free.
I'm glad to see the stock stuff still works well in a direct performance comparison!
It would be interesting to unplug the alternator and run on the battery alone for a pass.
I'm curious if any voltage drop would cost you more in ignition performance than the alternator load itself.
07-20-2009, 04:36:41 PM
#4
I took off my alt belt once and picked up 1/10
old 72 - now driving a third gen
07-20-2009, 05:34:22 PM
#5
If it's worth that kind of gain..... Why only once?
07-20-2009, 05:46:28 PM
#6
'cause he didn't want to end up with a dead battery?
07-20-2009, 06:51:41 PM
#7
Yep! I ran a string of 12.04-12.06 about 10 passes and I said I wonder what would happen if I took the belt off, I wanted an 11.XX so bad. Very next pass only difference was alt belt off and I ran 11.94 my first 11sec pass ever!
07-20-2009, 08:15:59 PM
#8
Dang....how much did that belt weigh???
-Andy
1979 Z/28 (better than cloned)
ΜOΛΩΝ ΛΑΒE
Proud NRA Lifetime Member
GeorgiaCarry.org Member
GeorgiaPacking.org Member
07-20-2009, 09:14:42 PM
#9
bout 200lbs lol, I assume it was the drag on the engine, Ive done it a few times in the past and always gained around 1/10 so I had to do it being so close to 11's at the time.
07-21-2009, 01:22:40 AM
#10
Moderator
I lost my belt after the burnout...Ran a 10.81 on a 10.84 slamming on the brakes...mph was like 110.
But HHott you only run the electric h20 to cool bt rounds right? I have a spare motor I keep in the truck...just in case. And guess what happened....I lost the cog and the belt one night..lol Yeah I just have not had good luck lately.
07-21-2009, 06:48:09 AM
#11
you could do this old trick we did back in the 70's .......... find the alternator field wire and splice in a toggle switch in your dash somewhere .when you get ready to run the 1/4 just hit the switch and you'll easily drop your ET by a 10th or more
07-21-2009, 08:33:05 AM
#12
The old school guys know all the tricks.
And to think people always wondered what all those spare toggles on the dash were for.
07-21-2009, 09:29:44 AM
#13
I used to have one in my car, when I got to the ned of the staging lanes id flip the switch shut the car off then restart and when I came through the lights Id flip it on.
Ive run the moroso drive kit as well for 10 yrs original motor & belt, been considering swapping to conventional belt pully lately just for the heck of it but the car runs so cool and I can cool while its off.
| Thread Tools |
| Display Modes |
Linear Mode
