Old 06-23-2009, 01:53:17 PM   #1
bkoz1990
gears!
i have a 81 z28 w/ 400sb and mildly upgraded through out the car and compleatly demolished the old gears n my car and am n need of repalcing them im not all that knoledgible when it comes to the ratios and everything with that. so any help or advice as to wht gears i should replace the old one with would be greatly apprishiated.
bkoz1990 is offline   Reply With Quote
Old 06-23-2009, 02:07:02 PM   #2
BusDriver
What rear end, what trans, and what is your primary useage of the car? Street, strip, combo?
'03 Yellow S-10 4.3L - "The Bus"
'78 Firebird - Progress: http://www.nastyz28.com/forum/showthread.php?t=142245
BusDriver is offline   Reply With Quote
Old 06-23-2009, 02:16:20 PM   #3
bkoz1990
it has a 350 tans auto w shift kit and i believe the rear end is a 10 bolt and id say more of combo im n colege so it is a daily driver but still need some speed
Old 06-23-2009, 02:36:08 PM   #4
BusDriver
Without overdrive, I'd keep the gears moderate. 3.08s, 3.23's or so.
Not horrible performance, but anything higher and RPM when just driving get's pretty high. With a healthy 400 the motor can still turn these conservative gears plenty fine.
Did you have a posi before, and is it still in good shape? If so just a new gearset and install is all you need to be up and running.
Old 06-23-2009, 06:31:35 PM   #5
bkoz1990
i have a limited slip in there right now and is still in good working condition but the gears your sugestioning im guesing are a more high end gear and cause more of a slower accel than with a gear ratio more n the low 4's??? im really not sure how it all works w the ratio #'s and significance as to higher the nubmber means better lowend or wht...
Old 06-23-2009, 06:39:00 PM   #6
-=79z28=-
-=79z28=-'s Avatar
lowest gearing i would go on a DD is 3.42. that'll be nice for highway driving, while still getting you up to speed quick.
but as busdriver said, the torque of that 400SB can make 3.08's feel a lot lower. so in the end its up to you, but you have 2 votes for 3.23's.
Travis
White 79 Berlinetta 4 speed... frame off restoration to a Z28, *silver* with blue decals
building a little 383 for it... traction might be a problem
Progress Thread: http://www.nastyz28.com/forum/showthread.php?t=139000
Originally Posted by CorkyE
Before you turn Gold Member, you must pass orals on tube doors and do a thesis on whether a fixed wing aircraft will take off on a treadmill....
-=79z28=- is offline   Reply With Quote
Old 06-23-2009, 07:01:22 PM   #7
mopar
Over the years (I'm 56), I've run everything from 4.88 to 2.56 on the street. Lately I've grown partial to 3.42 to 3.55 gear ratio for Daily Driver and cruising.
mopar is offline   Reply With Quote
Old 06-23-2009, 09:32:21 PM   #8
z28rod
3.42
z28rod is offline   Reply With Quote
Old 06-24-2009, 02:16:05 PM   #9
bkoz1990
thnks yall have been alota help really aprishiate it
Old 06-24-2009, 03:07:23 PM   #10
BusDriver
Higher numbers are lower gears, you get more mechanical advantage and accelerate faster, but your RPM at any giver gear/speed is higher. thus, worse gase mileage.
Thus the trade, higher gears will give you better acceleration at the cost of higher RPM/worse mileage when cruising at speed.
The best solution, but not the cheapest, is an overdrive trans that compensates with a steeper gear in the transmission to lower RPMs when at highway speeds, while retaining performance ratios in the lower gears.
