Go Back   NastyZ28.com > Drivetrain & Performance > Competition Camaros
Old 05-10-2009, 11:05:36 PM   #1
vegas1974z28
Moderator
vegas1974z28's Avatar
calvert leafs
those stupid little clips broke that hold the front spring perch, now I have to wait for classic industries to send me new ones.
They weigh 24 lbs
stock leafs weigh 34.6 lbs
just the shocks and some 29's netted me 1.52 60's our DA was over 5000 feet so no good times to speak of. 10.94-11.04
Mattie
74 Camaro 498
10.319@128
www.wix.com/gamattie/2ndgenracing
vegas1974z28 is offline   Reply With Quote
Old 05-11-2009, 04:52:57 AM   #2
jaywill
nice springs...lmk if they lower your car any...might have to try a set if they want lower my car.........
DO U HAVE THE CALTRACS???
496 BBC " PUMP GAS "
TO DATE: N/A
BEST ET. 7.14
BEST MPH: 99.6
" X-BREED RACING "
LAST TIME OUT W/CAR
http://www.youtube.com/watch?v=G9uINeUkD74
http://www.youtube.com/watch?v=ubbe0zSAnkY
jaywill is offline   Reply With Quote
Old 05-11-2009, 11:07:56 AM   #3
vegas1974z28
Moderator
they have a 1in lowering spring, stock height, and 1 in raise.
Yes I have the caltracs, shocks and leafs now. The complete set up. Hoping for 1.4 60'
Mattie
74 Camaro 498
10.319@128
Old 05-11-2009, 11:25:01 AM   #4
LILRED496
You will get it: Do you use a tranny brake?
It looks like the calvert springs made a difference for me I got a 1.450 with drs.
Have you set up your pinion angle?
78 Camaro,3550,555,NA,on 93,4500
Driven 75 mile round trip to the track.
1.36 275/60s street radials
6.10 @111.8
9.63 @137.7
1.58 275/60s soft leave on 91 octane pumpgas
6.36 @112.2 MPH
9.88 @138.1 MPH
Best 60ft 1.331
LILRED496 is offline   Reply With Quote
Old 05-11-2009, 11:43:55 AM   #5
vegas1974z28
Moderator
No. I don't understand the "pinion angle". I use a tranny brake, leave at 3000 now. I can feel the front tires leave the ground probably 6 inches or so. The car unloads the rears and they spin a little I can see it in the video.
Friday night I tried (without the leafs) rear shocks at 2 what calvert reccommended (1.55-1.56) 60' Then moved to setting of 5 1.52-1.54 Then to 9 1.57-1.58. Tire pressure At 13.5. Bars set on top rung, 1/4 preload.
My reaction times went to crap... .001, .005, .016, .016 all RED
Mattie
74 Camaro 498
10.319@128
Old 05-11-2009, 05:21:51 PM   #6
LILRED496
Whats it leave like on the foot brake?
Setting up the pinion angle perfect can help plant the tires.
Do You have caltrac bars?
6.10 @111.8
9.63 @137.7
6.36 @112.2 MPH
9.88 @138.1 MPH
Best 60ft 1.331
Old 05-11-2009, 06:44:29 PM   #7
TNT
Pinion angle on a leaf spring car is all over the map while under power. Especially with the split mono's.
The hook then spin problem is a tough one. Some times if you hit the car with more power it maintains that intitial hook. If you can't do that then you are limited to suspension adjustments. Slowing down the rear separation then keeping it separated is the trick.
1980 Z28, 23* 409 SBC on Spray,Glide,3030 lbs Stock Suspension with 275 Radials. 1.25 - 5.22 @ 134mph.
Videos http://www.youtube.com/user/Yerluzin
Mike Thompson,TNT Performance X275
TNT is offline   Reply With Quote
Old 05-11-2009, 07:57:56 PM   #8
LILRED496
I have yet to set my pinion angle.Are you saying its a waste of time if so I'm not gonna bother with it.
I thought the whole point of caltrac bars was to set up the pinion angle then adjust the preload to fine tune the hit?
6.10 @111.8
9.63 @137.7
6.36 @112.2 MPH
9.88 @138.1 MPH
Best 60ft 1.331
Old 05-11-2009, 09:09:41 PM   #9
74RAT
not necessarrily a waste of time at all. u-joints are really only meant to be used within about a 3*-4* angle max. otherwise they can load and unload the tires from the u-joints changing velocity at the higher pinion to driveshaft angles under load.
just that they're not constant velocity joints like a front wheel drive alxe uses. i.e.--- the u-joint caps attempt to change speeds slowing down and speeding up at the higher driveshaft to pinion angles. just the physics of how they work when angled alot.
you're just trying to get it to be within the range of 0*-1/2* to the positive side(pinion nose down to the driveshaft) under max power and load on launch,, but not above center (nose up),, and somehow try to keep it somewhat in that 3*-4* window after the power starts falling off some in the higher gears when the pinion yoke starts falling to the ground again from less force through multiplication of the gears.
hope it helps.
andy
you know you really blew it when,,, all your parts will again,, fit loosely in a 5 gallon bucket!!!!
74RAT is offline   Reply With Quote
Old 05-12-2009, 08:01:45 PM   #10
jester1
TNT is completely right. There is no traction device that will elimintate pinion rise or spring wrap up while on leafspring.
Does pinon angle affect the initial hit, yes. You just cant control it unless your running ladderbar or 4 link even though it will still move just not as much. How much depends on the power available and materials used.
"I'm done"
bIg BabY
jester1 is offline   Reply With Quote
