Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Suspension, Brake & Wheel Topics
Thread Tools Rate Thread Display Modes
Old 05-07-2009, 09:20:02 PM   #1
Chris77Z28
Chris77Z28's Avatar
Need pics please!!!!!!
I need a pic of exactly how the front sway bar is mounted to the A-arm rod bushings? Is it more metal on the A-arm or is it the other way, I can't remember it's been a while since I tore the car apart. Thanks in advance. Chris
check out MY progress thread!!!
http://www.nastyz28.com/forum/showthread.php?t=113203
Chris77Z28 is offline   Reply With Quote
Old 05-07-2009, 09:27:44 PM   #2
1981gMachine
1981gMachine's Avatar
Send a message via AIM to 1981gMachine Send a message via MSN to 1981gMachine
Should go
nut
washer
bushing
sway bar end
bushing
washer
metal shaft
washer
bushing
control arm
bushing
washer
nut
edit:
here's a pic, not sure if you were talking about the endlinks
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Old 05-07-2009, 09:30:25 PM   #3
Chris77Z28
Chris77Z28's Avatar
doing it this way it will be up off the control arm 4 inches or so give or take?
Old 05-07-2009, 09:33:59 PM   #4
1981gMachine
Yeah, if you want an exact measurement I can walk outside and measure from where ever you want me to.
Present Setup:
Near Future:
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 05-07-2009, 09:35:21 PM   #5
Chris77Z28
Chris77Z28's Avatar
Thanks A Million!!!!!!!!!no measurement needed! Just printed the pic and headed back out to the shop. Thanks gmachine
Old 05-08-2009, 01:41:22 AM   #6
che77vy
Just make sure to keep the bar level at the mounting point on the lower control arm.
If it's not broken, fix it!
Marks71BB Great job!! she should be nice and stiff now!
Upstanding member of E.V.A.L
(Enemies of Vacuum Advancement League)
che77vy is online now   Reply With Quote
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
