04-30-2009, 01:20:27 PM
#1
I need pics of an engine cradle with no body side motor mounts installed (bolt holes)
I have a 76 Firebird that is getting an SBC chevy (maybe this weekend if I finally get off my butt and start putting this car together). The transamcountry guys are telling me that a 76 will not be drilled for the chevy bolt holes, since only 77+ pontiacs could have SBC power from the factory. Can someone show me a close up pic of the engine cradle of a 2nd gen camaro, both with the motor mount installed, and without the body side mount, so I can pattern where my new holes need to be drilled?
Thanks
Steve
Steven H. www.carfap.net
1985 BMW 745i Turbo, Euro model import, 18" Antera wheels
1986.5 Porsche 928S, 5.0 32v V8, 18" 993 turbo wheels
1988 K1500, 5.7 TPI swapped
1999 C1500, new 5.7 Vortec, 4" lift spindles, EFILive V2 tuner
2003 Mercury Marauder, 4.10s, Heinous billet rear control arms, SCT Advantage III tuner
2004 Taurus SEL, Ingalls tubular control arms
04-30-2009, 02:14:58 PM
#2
Location: Striking fear and destroying the enemy from my borders
No way to hang it in with the mounts bolted up and lower it in then just mark the holes after a lil weight is put on it ?
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America ' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in THIS country who no longer understand it.'
http://community.webshots.com/user/rscamaro73
Facebook - rscamaro73
I'm sometimes called Wayne
04-30-2009, 02:16:18 PM
#3
I can do that but I want it to be in the stock location so I don't screw up driveshaft length. I would have to have the trans AND shaft in the car with the engine to mark it then, which I can do I suppose...
04-30-2009, 02:38:48 PM
#4
I have done this before Steve... I used the rear trans mount to reference the MM locations...
04-30-2009, 02:55:11 PM
#5
the rear trans mount I have for 2nd gens has a slot about an inch long so there is a lot of variability there. I can mock it up this weekend w/ the engine in the car and see how it looks. I have the fenders off anyway so it will be easy to get in and out
Steve
04-30-2009, 03:00:24 PM
#6
line the rear trans seal up with the marks on the drive-shaft yoke
honest... it worked fine for me
05-01-2009, 12:35:11 AM
#7
Here is a 73 subframe.
05-01-2009, 10:41:01 AM
#8
I love the fork on the newspaper! That frame does look clean enough to eat off of!
SOLD <sigh> 1979 RS weighs 3580 lbs. with me in it. 406 w/ Victor Jr, Pro Systems 850 CFM carb, Pro Topline 220cc heads, solid roller cam with .630 lift, 264-270 duration @.050, Ross -5cc racing pistons, 12.5 to 1 compression, Forged crank and rods, splayed 4 bolt mains, 1.875" headers. Converter stalls at 3200, Trans Specialties turbo 350, 4.10 gears. Fastest to date is 10.67 @ 124.
05-01-2009, 10:48:00 AM
#9
Steve, I will get you a pic of one when I get off of work today.
Robert
73 Formula
05-10-2009, 03:33:22 AM
#10
Does that 73 frame pictured above use the same body side clamshell mounts as 74-81?
05-10-2009, 11:30:36 PM
#11
I think they do, but I am not 100% sure.
05-11-2009, 10:18:41 AM
#12
thanks guys, it turned out that the 76 ponticrap actually did have the holes for the Chevy 350 mounts, despite what the guys on tacountry were trying to tell me
We's all good and thanks for the pics, they were helpful
Steve
| Thread Tools |
| Display Modes |
Linear Mode
