04-13-2009, 09:06:16 PM
#1
Finally found the engine that will go in the camaro....
 well i picked this up today for $500 kentuckian dollars. i really dont care if i was ripped off or not, i couldnt find one cheaper than this and i am very pleased that it is going into my 73 camaro....
Now introducing the 454!
the pics are of the heads and block with numbers.
JESUS SAVES!!!
04-13-2009, 09:07:21 PM
#2
sry if pics are messed up, my comp is goin crazy lately, i cant even play world of warcrack for 5 inutes without it crashing on me and now its affecting my internet too.
JESUS SAVES!!!
04-13-2009, 09:33:50 PM
#3
BANNED
Thats not too much of a bad deal. $400-$500 is the range I find 454s all the time. Im still loking for my 454....I want one that doesnt have the heads at around free to $200.
04-13-2009, 09:57:12 PM
#4
free is always the best route
JESUS SAVES!!!
04-13-2009, 10:21:12 PM
#5
the motor is out of a 73-77 truck and the heads are HI-Proformance heads out of an 86-90 something.
JESUS SAVES!!!
04-14-2009, 12:06:20 AM
#6
yeah baby
04-14-2009, 02:20:24 AM
#7
Whole bunch of motor in a Camaro, sounds like fun.
04-14-2009, 04:29:08 AM
#8
Poke it, stroke it, try not to smoke it!
Brothers and sisters have I none, but that man's father,... is my fathers son
04-14-2009, 07:09:54 PM
#9
wehn it gets rebuilt im thinkin new cam and everything else stock for now, cuz i need to put more time and money into the body of the car. the engine will be the project after the project.
JESUS SAVES!!!
04-14-2009, 09:18:20 PM
#10
BANNED
I would think long and hard about using her for a core to make a 496 out of and I did out of my good "TSC", '75 454 P/U motor that had a bad crank in it is all!
550hp at 5500 rpm and 580 t at 4500 rpm will come easy w/ 9.8 CR., big valve heads, headers and something like no more than a CC 282S solid lifter cam or whatever Isky's 280 Mega solid lifter cam is?
I have this UDHarold solid lifter cam in my bedroom closet and I figure it's worth at least 50, maybe 75 hp more!
278/249/161, 110/106, .618" gross lift and needs .018" lash on both sides!
Please take the time to compare it to CC's great old 288AR solid street roller b/c Harold say's it will run right w/ it! I bugged Harold for quite a while, (b/c I won't run a roller lifter cam for fear of when I will eat the needle bearings), to come up w/ a solid lifter cam like the great old CC 288AR and he did for me!!
Call Harold here (662) 562-4933
if you want a SOTA cam and I have to say that you can't go wrong buying a UDHarold cam!!
And if you do call him, please say hello from ol' pdq67 for me.
Harold did the great old CC 268HE and others, his own Ultradyne line and the Lunati VooDoo cams so go..
Btw, let's chat BB heads.....
If the intake ports of the heads are wider than they are tall, they are little-bitty peanut port heads that range from 198 cc's up to a supposed 230.
If taller than wide large oval ports.
We get into a deal here b/c GM's early true closed chambered heads like the -206's and then some newer semi-closed chamber heads like the -215's, and jumping to the -781 or a -049 open chamber heads , all can be/are the best large oval port heads going, (and are generally 255 to maybe 262 cc's), IF you match your compression to them cc chamber-wise AND YOU HAVE TO CC BB HEADS b/c they can vary from 112/113 for squared-off way open, shallow-chambered, smog heads to say -049's that can run from 113 to as big as 120+ cc's...
pdq67
PS., forget the later L-29, peanut port replacement heads, imho!
04-15-2009, 12:09:54 AM
#11
mine's a 289 casting block. 2 bolt mains. one of the better 454 castings imo. good score. got my core with 049 oval port heads for 250$ back in 1989 or so.
not many "hi perf" heads during the 80's. if you can find some 049's or 781's you'll do well.
andy
you know you really blew it when,,, all your parts will again,, fit loosely in a 5 gallon bucket!!!!
04-16-2009, 08:11:42 PM
#12
finally got it unstuck today, i had some time to work on it now i need to find good complete rebuild kit, if any of yall know any. and how much.
JESUS SAVES!!!
04-17-2009, 12:50:50 AM
#13
BANNED
Sure, please check Speed-O-Motive and Ohio Crankshaft Co.
Buy what you need unbalanced, mock it up and then have it looked at locally by a good Machinist and then balance it once it's checked good to go.
496, buy at least 1/4" longer rods to help balance her.
pdq67
| Thread Tools |
| Display Modes |
Linear Mode
