Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 04-01-2009, 05:52:53 PM   #1
joze56
Best Factory 350 Heads Ranked?
I have a 1994 5.7 TBI block that I want to build into a mild street engine, to go in a 1960 2dr Belair. I will be using a 700R4 trans & about 3.78 rear gears. My question is: In order of best-to-worst, what used factory heads should I use for this engine, starting with vortecs, down to something I can afford? I will be using an aftermarket intake/carb, mild cam & HEI ignition. If possible, please rank your recommendation by Chevy casting #'s. Thanks for helping a novice!
joze56 is offline   Reply With Quote
Old 04-01-2009, 05:55:41 PM   #2
hardline_42
hardline_42's Avatar
My only suggestion would be Vortecs. You can find them used for about $200. There aren't any other factory heads that will provide any siginificant improvements, IMO.
'81 Sport Coupe 229 V6 - Junked
'93 Z28 5.7L LT1 - Parted
"Is that a rat? No, it's just a really fat mouse."
hardline_42 is offline   Reply With Quote
Old 04-01-2009, 05:56:17 PM   #3
BondoSpecial
BondoSpecial's Avatar
I don't know about ranking them, but if you are looking for Gen I heads, you definitely do not want to use the 193 truck swirl heads. The 083 TPI L98 heads from F bodies are cheap and plentiful and are about as good as factory gen I heads get, 64cc chambers, 1.94/1.5 valves, slightly under 200 cfms intake @ 0.500 lift. Should be able to find them for $100/pair no problem. Plus they are modern heads so you don't have to mess around w/ adding on hardened seats to camel hump heads or anything like that.
Steven H. www.carfap.net
1985 BMW 745i Turbo, Euro model import, 18" Antera wheels
1986.5 Porsche 928S, 5.0 32v V8, 18" 993 turbo wheels
1999 Chevy C1500, new 5.7 Vortec, 4" lift spindles, EFILive V2 tuner
2003 Mercury Marauder, 4.10s, Heinous billet rear control arms, SCT Advantage III tuner
2004 Taurus SEL, Ingalls tubular control arms
BondoSpecial is online now   Reply With Quote
Old 04-01-2009, 05:57:55 PM   #4
TooLateVTEC
For that build using only a factory head, it would without a doubt be Vortec heads.
Some of the worse are the TBI heads you have right now lol.
The Vortec #'s I cant remember, one of them is 0XX and the other is 9-0-6 I think...I know its 9-0-something.
www.mortec.com is a good place to look at different head casting #'s and a description of them.
'86 IROC-Z Stock 350TPI with a cam....5.63@126 so far
'79 Z28 streetcar - 7.01 - 11.05 pump gas - sold
http://i32.photobucket.com/albums/d1...RaceCar011.jpg
TooLateVTEC is offline   Reply With Quote
Old 04-01-2009, 05:59:15 PM   #5
hardline_42
^^ 062? Check out the Vortec sticky for all the info you could ever want.
Old 04-01-2009, 06:01:13 PM   #6
TooLateVTEC
062, yes thats it thanks for clearing it up for him...and me
Old 04-01-2009, 07:13:15 PM   #7
joze56
Thanks guys for the info.. I hear the vortecs tend to crack, is this rumor or fact? If they crack easily, I would not be comfortable putting on a "good" pair and worrying about "when they are going to crack". Comments?
Old 04-01-2009, 09:39:10 PM   #8
pdq67
BANNED
Please look into the aftermarket RHS Vortec heads here!
pdq67
pdq67 is offline   Reply With Quote
Old 04-01-2009, 09:47:41 PM   #9
hardline_42
FWIW, I've had many pairs of Vortec heads on several different engines having undergone different levels of machining and never had any cracking, but I know some have had that experience, especially while tapping rocker stud bosses and other mods. They shouldn't crack with regular use.
Old 04-01-2009, 11:25:38 PM   #10
pdq67
BANNED
Please read me again!!!!!!!!!!!!!!
Good value is what I'm talking about long term here and I can squeeze a Buffalo nickel until it bellow's is all!
pdq67
Old 04-02-2009, 02:29:19 AM   #11
rustbucket79
It is quite common to see them crack, but these are all stock applications. We have lots of hills in our neck of the woods, big temp swings, etc which can lead to cracking. In a properly tuned application in a car I would be very suprized to see one crack.
The RHS version looks very similar, and come with hardened seats and screw in studs. If you buy the large valve version, they are supposed to have both intake bolt patterns, something to think about if you're looking at vortecs. They aren't all that cheap mind you, lots of options out there in that price range.
Vids of the car: http://www.youtube.com/watch?v=Fb39m4ToP50
rustbucket79 is offline   Reply With Quote
Old 04-02-2009, 02:58:28 AM   #12
joze56
I appreciate the summary comments on the vortec "cracking" problem. My question now is: What is the next best factory head (non-vortec)? Thanks again for comments!
Old 04-02-2009, 08:04:04 AM   #13
MyBoTy
I've torn down a ton of engines and the only vortec heads I've seen cracked came off of engines that had been significantly overheated.
If you can find a decent price on the RHS vortecs, grab 'em. They're thicker and are already machined for higher lift and screw-in studs. They are the best value, IMHO. My son has a set on a 383 in a Tahoe with an LT-4 cam, it's a runner!
To answer your question, there aren't any other factory heads that are in the same class with Vortecs.
MyBoTy is offline   Reply With Quote
Old 04-02-2009, 02:47:20 PM   #14
joze56
It looks like everybody is pointing at the vortecs. That will delay my project a while, until I save some more $'s. With stock vortecs, will I be able to run a good street cam without modifying to screw-in studs & milled guide bosses? I am only looking for 300-325 HP.
Old 04-02-2009, 03:51:50 PM   #15
woody80z28
woody80z28's Avatar
I have press-in stud 062 Vortecs with a .480 lift cam and ~400hp. I beat the piss out of it all the time and never have issues.
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Accel EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ Equus gauges & custom bezel
My Chevy garage GEARHEAD dezign
woody80z28 is offline   Reply With Quote
