Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Thread Tools Search this Thread Rate Thread Display Modes
Old 03-28-2009, 03:15:55 PM   #1
Orange71
Orange71's Avatar
Factory Gauge Harness Connector
Edit - added pics
I just spent the last hour or so doing a wire check on this 12 wire connector. I'm swapping out to aftermarket gauges and I needed to know which wire was for what in that connector. Thought this might help others when they do the swap.
My '71 had the factory U14 gauges.
#1 Brown - Tach Lead
#2 Green/White - Temp Gauge to Sender
#3 Pink - 12volts switched from #8
#4 Tan/Black - Fuel Level Gauge to Sender
#5 Gray - Dash/Gauge Lights
#6 Black - Ground
#7 Tan - Emergency Brake Light
#8 Pink (2) - 12volts switched - looped to #3
#9 Light Blue - Left Signal Light
#10 Light Green High Beam Light
#11 Blue - Right Signal Light
#12 Blue/White - Oil Light to Sender
Orange71 is offline   Reply With Quote
Old 03-29-2009, 09:03:58 PM   #2
Orange71
Orange71's Avatar
Added pics above and while I was in there I figured I take a few pics of the other connectors that attach to the dash/gauge panel.
Amp Gauge:
Clock:
Factory Radio connector - taped to the Clock harness plug:
Wiper Switch:
Headlight Switch:
Heater Motor Switch (nonA/C):
Cigarette Lighter:
Old 04-03-2009, 06:36:46 PM   #3
DrSmaggs
Send a message via AIM to DrSmaggs Send a message via MSN to DrSmaggs Send a message via Yahoo to DrSmaggs
Thanks a million for this thread. Although my color diagram is odd, this helped me hook up my gas gauge that I bought for my 75 camaro.
I'll surely be posting follow ups when I drive a distance and test the gauge
DrSmaggs is offline   Reply With Quote
Old 04-03-2009, 08:06:11 PM   #4
Orange71
Orange71's Avatar
Cool...glad it helped!
Old 06-03-2009, 05:08:10 AM   #5
Bias
Orange71:
Are you sure thatīs the AMP gauge contact?
Since i switched to a U14 my temp meter dosent work.
to my pin #2 goes a dark green wire. not a green/wihte. Are there any diffrent betwene AC and non AC cars?
Bias
Bias is offline   Reply With Quote
Old 06-03-2009, 06:03:27 PM   #6
Orange71
Orange71's Avatar
Originally Posted by Bias
Orange71:
Bias
Yep, positive on the amp gauge connector. Here's a pic of the backside of the amp gauge showing the conector pins:
The wiring diagram in the '71 Assembly Manual refers to that #2 wire as DG (dark green). No mention of the white stripe. Others have mentioned the same thing with the temp wire and also the tan fuel gauge wire that on mine was tan with a black stripe. I re-connected the original gauge sender wires to my new gauges and they all work.
You may need to swap the sender (different for gauges) for the temp gauge to work.
Here's a few pics showing the circuit path of #2 terminal to the back of the temp gauge:
Old 06-03-2009, 06:59:36 PM   #7
XxWickedz28xX
XxWickedz28xX's Avatar
Great pics Orange71....really helpful
A bit off topic...but any idea off hand where the console light plugs into? I know its behind the dash somehwere, should I have a connector for it hanging around somewhere there?
XxWickedz28xX is offline   Reply With Quote
Old 06-03-2009, 08:19:22 PM   #8
Orange71
Orange71's Avatar
Thanks!
Many years ago when I took out my console I cut those wires and forgot about them. I found them as I was cleaning up the wiring. Mine are white and orange (same circuit as the door switch/dome light) and they exit the under dash harness on the right side of the steering coluum down behind the large coluum wire connector. Hope that helps.
Old 06-05-2009, 08:48:47 AM   #9
Bias
Ok. Looking att your firts picture i can see some diffrets to mine. ( mine was a 1976 gauge)
I tryed to change the temp gauge sender to a gauge sender but it dosent work. Next step for me are changing the wire from the sender to the gauge.
Thanks so far.
Bias
Old 08-07-2009, 04:38:29 PM   #10
Ravenous70
U are a life saver........Thanks for the layout, someone should make this a sticky
70'Camaro-Teal,Black Cloth,Cowl Hood, T/A spoiler, Built TH350
LS1, LS6 Stg2 heads, Futral Custom Cam, Victor Jr, 4000 stall, Vette Brakes etc... Prowling the Streets of DFW!!!http://www.cardomain.com/ride/3069774
Project Link http://www.nastyz28.com/forum/showthread.php?t=114784
06 GSXR 750
Frum Roll Racing
Ravenous70 is offline   Reply With Quote
Old 08-07-2009, 06:01:03 PM   #11
Twisted_Metal's Avatar
Send a message via AIM to Twisted_Metal
Might as well throw this in here too.....
This pic is the rear of a 1980 U14 cluster.
http://img181.exs.cx/img181/2526/gau...terback5qx.jpg <- Link to HUGE pic.
It let's you trace all of the circuits in back so you have the whole thing plug/circuit panel in one thread.
Old 08-10-2009, 11:21:50 AM   #12
408maro
I got a 71 and swapping from dummy gauges to the u14 swap. If I just match my wires to how you posted in the first post it'll work? Thanks
John
408maro is offline   Reply With Quote
Old 08-10-2009, 12:30:43 PM   #13
John
Pretty much... You need a new temp sender unit too.
Here's a great write-up on the process. ----> http://www.nastyz28.com/2gcog/tech/u14swap.html
Old 08-10-2009, 01:13:42 PM   #14
408maro
Whats the temp sender unit?
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 08-10-2009, 01:21:51 PM   #15
It's a sending unit which is screwed into a port on the head or intake.
(Stock position is between cyls 1 & 3, in the head, between the exhaust ports.)
It connects to the temp gauge electrically to give the gauge a signal.
The sending unit for an idiot light won't work for a gauge cluster.
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
