Old 02-27-2009, 05:09:55 PM   #1
TommyRS70
ANyone know who is reproducing Z28 Reverse Lockout Linkage
Can anyone direct me to the supplier for 1970 Z28 back drive, reverse lock out rod supplier? Do you know if they stamped these with the correct numbers also???
Thanks!!~
TommyRS70 is offline   Reply With Quote
Old 02-27-2009, 05:22:13 PM   #2
jacsey 70Z
jacsey 70Z's Avatar
No one is making the reverse lockout rod at this time, I looked into it but to do it right you need to hammer forge the ends and the cost was way to high for the number of rods you could sell.
Yes the last four numbers are stamped into the lockout rod. 5618
Jack
jacsey 70Z is offline   Reply With Quote
Old 02-27-2009, 05:28:46 PM   #3
TommyRS70
Wow , Thanks for the fast response, Jack. So that would be a "no repo" on the upper rod 5624, as well?
Old 02-27-2009, 05:35:03 PM   #4
jacsey 70Z
jacsey 70Z's Avatar
No one does the upper rod either, but they are way easier to find then the lower.
Jack
Old 02-27-2009, 05:41:00 PM   #5
M21RSZ28
Thanks!!~
Camaro Specialties in New york use to sell a reproduction lower lock out rod but without the "5618" on the rod for 1970-72 Camaro
Camaro Specialites
12 Elm Street
East Aurora, ny 14052-2536
Phone: (716) 652-7086
M21RSZ28
M21RSZ28 is offline   Reply With Quote
Old 02-27-2009, 05:56:39 PM   #6
Hotrodpaul
Jim Stubbins over at Heartbeat City was making a nice and correct lower lockout rod for 1st Gen Camaro's. I wonder if he would be willing to reproduce the 2nd Gen lower rod since he already has the proper tooling.
Paul
70 Camaro Z28 Citrus Green M40 3.73's
Hotrodpaul is offline   Reply With Quote
Old 02-27-2009, 05:58:44 PM   #7
Dave Nelson
Dave Nelson's Avatar
The lower rod is reproduced, they are on ebay now and then along with the bellcrank. I believe the company is called Chicago Muscle Car Parts? The lower rod from a 69 camaro (with Muncie) is the same,but different part #'s. I have done two of these swaps using the 69 rod.
1970 SS/RS L-34 A/C 4 spd.
When you get to the end of your rope....tie a knot & hang on.
A wife and a steady job have ruined many a good fishermen.
I once gave up fishing, it was the most terrifying weekend of my life.
Dave Nelson is offline   Reply With Quote
Old 02-27-2009, 06:22:30 PM   #8
Dave Nelson
ebay #330308919093
Old 02-27-2009, 06:23:51 PM   #9
CamarosRus
David Nelson, First I read where somebody was claiming that 69' lower rod was SAME AS 70/71 Lower Rod...........(with exception of part #) Hmmmm!!!!
To all of you, how many other years was 5624 upper used with same bellcrank assy as 1970.....and guess I need to study AIM to see what set up was used with T350/400 to lock out steering wheel ??????
Chuck Sharin
Seattle(area)
CamarosRus@Gmail.com
70 R/S Z-28, 70 SS L-78, 70 R/S SS L-48 (all 4spds)
69 COPO "Recreation"
CamarosRus is offline   Reply With Quote
Old 02-27-2009, 06:56:29 PM   #10
M21RSZ28
First of all the 1970-74 muncie lower reverse lock out rod is stamped 5618 for the 3975618 rod - 1969 Camaro with muncie uses 3955733 reverse lock out rod for Z28 and 3955755 for SS 386 Camaros.
If the 69 lower reverse lock out rod were the same for 1970 Camaro with Muncie trans the part number would have been the same
1969 Camaros use the same subframe as the 1968-72 Nova, the 1970 Camaro-up subframe is different and would require a diffferent lever assembly attached to the subframe and a completely different lower lock out rod
Maybe you can make a 69 reverse lock out rod fit on a 1970, i don't know and would never try, but it won't look right no matter what
The picture of the lower lock out rod offered by "Thepartsplaceinc" does not even look close to the "5618" where is the bend in the rod, their rod looks to straight
http://cgi.ebay.com/ebaymotors/ws/eB...9093&viewitem=
The upper rod 5624 was used on 1970-74 Z28 as listed in the Chevrolet Parts catalog dated June 1974
M21RSZ28
Old 02-27-2009, 07:43:12 PM   #11
Dave Nelson
As stated in my previous post,of course the #'s stamped on the rods are different. Have I put the 70 rod next to the 69 rod no. I said the 69 lower rod will function exactly like the 70 version. I did not stumble upon this by accident. Many years ago when I was looking for the rod for my own car,I was told by a gentleman who sells camaro parts in Calf. to use the 69 rod. It fit "exactly" and operated correctly, with no modification.Since then I have used the same rod on another car, same results.Next time my car is on lift I will gladly take pics.
Old 02-27-2009, 08:17:47 PM   #12
Budz
Budz's Avatar
"No one is making the reverse lockout rod at this time"
It doesn't look that hard to make...........
BUDDY
Some day's you're the windshield......Some day's you're the bug.
'70 Z28 PARTS FOR SALE
http://www.nastyz28.com/forum/showthread.php?t=135317
'70 Z/28-->> http://www.cardomain.com/ride/2968317
Budz is offline   Reply With Quote
Old 02-27-2009, 09:00:07 PM   #13
CamarosRus
Most all of you have made your good points..........conclusion is:
No one makes a accurate repop with the stamped #'s 5618
69 part will fit and work
EBAY repop part claims to fit and work
Jack Seymour obtained the G.M. blueprint, researched the expense and says they are too expensive to repop ACCURATELY........
Bottom line, only place these get looked at and/or judged is Carlisle. No other show points system in the country cares.
Thanks guys,
Chuck Sharin
Seattle(area)
Old 02-27-2009, 10:33:41 PM   #14
M21RSZ28
The 69 Camaro reverse rod may fit a 1970 but is not physically the same as shown in the pics below - The bends are different
M21RSZ
Below is a pic of the 69 reverse rod assembly sold by D&R Classic and shows the bend in a different location
Old 02-27-2009, 10:38:23 PM   #15
White81Z
Camaro Specialites
12 Elm Street
M21RSZ28
Yes they do and although not exact, it works. The correct address is 112 Elm St. Was my place of employment for a few years. Had a lot of fun and met a lot of great Camaro people.
Rick H.
White81Z is offline   Reply With Quote
