Old 08-10-2010, 10:41:00 AM   #46
BondoSpecial
BondoSpecial's Avatar
will the radiator panel fit a firebird
If you mean the top metal cover plate that includes the 2 rubber upper radiator mount pads on a camaro, then the answer is, no this will not fit a Firebird. Firebirds use a totally different fan shroud setup that is not interchangeable with camaros. The top of the Firebird radiator/header panel bumps up about an inch instead of being flat across where a Camaro cover plate would bolt on.
If you mean the whole front radiator/header panel, the answer is also no, does not interchange with a camaro front end.
Steven H. www.carfap.net
1985 BMW 745i Turbo, Euro model import, 18" Antera wheels
1986.5 Porsche 928S, 5.0 32v V8, 18" 993 turbo wheels
1988 K1500, 5.7 TPI swapped
1999 C1500, new 5.7 Vortec, 4" lift spindles, EFILive V2 tuner
2003 Mercury Marauder, 4.10s, Heinous billet rear control arms, SCT Advantage III tuner
2004 Taurus SEL, Ingalls tubular control arms
BondoSpecial is online now   Reply With Quote
Old 08-10-2010, 06:25:47 PM   #47
PolarBear
I love hood, I love lamp
Originally Posted by Toadman2230
Sorry to bring this thread back from the dead, but has there been any progress on these? Anyone have pics?? I have the front sheet metal off of my car and now would be a great time to consider these.
the short answer is, no.
i wont get into it but they wont be from keith or cheap
Hey man, someone stole your battery....
I love hood
The artist formerly known as notchbackgta
PolarBear is online now   Reply With Quote
Old 11-23-2010, 04:59:54 PM   #48
Teetoe_Jones
I'll get into it for you.
Anvil Auto took over the production, modification and development of these inner fenders. We had to rework the steel set that we got and ended up with 70 hours of labor to make them good enough to tool from. We added the pockets to increase tire clearance and smoothed and filled every hole that is not used for mounting.
We offer them in 4 levels-
100% dry carbon with an autoclave
100% carbon wet-lay up, vacuum bagged
carbon/fiberglass wet lay-up, vacuum bagged
100% fiberglass, wet lay-up, vacuum bagged.
We offer the parts in both glossy and satin finishes, and all our parts have a UV protectant in the clear coat.
There is a set on Mary Pozzi's 73 Camaro built at JCG, and Brian Finch is running a set on his car too. They weigh 6 lbs each.
Tyler
American Touring Specialties
Teetoe_Jones is offline   Reply With Quote
Old 11-23-2010, 05:05:28 PM   #49
badazz81z28
BANNED
Who is "we"?? Do you have a link?
Tyler
badazz81z28 is offline   Reply With Quote
Old 11-23-2010, 05:08:13 PM   #50
MikeDVC
MikeDVC's Avatar
Anvil http://www.anvilauto.com/
1 gen wheel wells listed, not 2nd gen
Progress thread http://www.nastyz28.com/forum/showthread.php?t=155184
BBFL- Big Bumpers for Life!!
MikeDVC is offline   Reply With Quote
Old 11-23-2010, 05:16:15 PM   #51
badazz81z28
BANNED
Looks like more for racing/competition. I don't think the steel ones are all that heavy.
Old 11-23-2010, 05:16:48 PM   #52
Teetoe_Jones
We are updating our site this week and next week. We have over 25 new products going up, including an entire Mustang line. We also will have full front fenders in carbon available in the next month for the 2nd Gen Camaro.
Tyler
Old 11-23-2010, 06:43:48 PM   #53
ks71z28
ks71z28's Avatar
Stock ones weigh 12 pounds each FYI.
Hey Tyler!
Custom Works- your source for
Suspension kits, Brakes, and wheels
HOLLEY EFI/Carbs- best pricing!
Authorized Tremec transmissions dealer
530 864*5846
www.customworksproducts.com
I just wanna go FAST
ks71z28 is offline   Reply With Quote
Old 11-23-2010, 07:29:29 PM   #54
Prototype4342
where's the carbon fiber 78-81 dash?!
i plan on purchasing a lot from that anvil carbon fiber place. as well as some valve covers from custom works.
i love carbon fiber! my wedding band is 100% carbon fiber, haha
My '81
'81 Camaro: 5.7L '86 350 LT9, Edelbrock Performer Intake man., Edelbrock 600 carb., Drop base air cleaner, unnamed headers, pypes crossflow exhaust, ECP all aluminum radiator, Mark VIII electric fan, PTFB GT suspension, single adjustable AFCO shocks, C/E subframe connectors, 4-speed.
Prototype4342 is offline   Reply With Quote
Old 11-23-2010, 10:29:21 PM   #55
78LT383
78LT383's Avatar
Have you done any actual testing on these inner fenders to verify that they are at least as strong as the stock inner fenders in the truss structure they were designed to create?
As you said, by weight, carbon fiber is stronger than steel, but only in tension- not in shear, and not even close in compression. The front fenders and inner fenders create a sort of boxed structure & truss with the front fenders, and so these inner fenders are a vital part of how the whole unibody chassis cradles the front subframe. Like the others, I'm concerned that you might be exposing yourself to a bit of liability and us to extra risk of fatigue fractures of the four subframe mounting points on the cab underbody. I have photographs that I took of floor/toe panel cracks from stresses caused by removed inner front fenders, and it appears that these might also eliminate some of the needed structure in the nose.
Carbon fiber can be a great material, but extensive structural endurance testing should be done to verify things like this on highway vehicles don't reduce the crash and/or fatigue strength.
I'll get this thing put back together eventually!
78LT383 is online now   Reply With Quote
Old 11-24-2010, 02:47:49 AM   #56
ks71z28
ks71z28's Avatar
That is why we sell the G-braces! Carbon fiber is 10x stronger than steel by weight, so if they are 1/2 the weight, then they are 5x as strong. Oh yeah they are a 20x more expensive. The strength of them will be fine. The biggest concern is from small rocks causing fischers or star cracks from underneath.
530 864*5846
Old 11-24-2010, 07:01:36 AM   #57
Prototype4342
Couldn't this be alleviated by "rhino lining" the wheel well portion? Or is it non-paintable?
My '81
Old 11-24-2010, 12:56:46 PM   #58
ks71z28
ks71z28's Avatar
You bet, but then you add 5 more pounds to the parts! I have a race car with fiberglass box fenders and they get murdered, hot sticky tires coming off the track. I glued a foam material underneath and it still happened
530 864*5846
Old 11-24-2010, 01:42:58 PM   #59
77nomad
Location: Muskegon, MI (the beer tent capitol of the world)
I've followed this thread from the beginning. I figured the g bars would compensate for the weakness. How big of tire are we talking about fitting up front? Thats the reason I would buy them. Are the offered in fiberglass?
PTFB Comp. Suspension, Control Arms, SFC's, Steering, Bushings, G-Bars and Sway Bars
383 w/ ST10 4 speed
3.73's
LS brakes front and rear
17x 8/ 17x 11 Torque Thrust II's
Every penny!
77nomad is offline   Reply With Quote
Old 11-24-2010, 02:40:42 PM   #60
Prototype4342
the rhino lining isn't that heavy if you use it sparingly. granted it is slightly more weight, but i 'd say worth it to save the fenders you probably paid 500 dollars for.
My '81
