Old 02-07-2009, 03:07:09 PM   #1
badazz81z28
BANNED
Whats brand-type solid bushings with SFCs?
What type/brand of solid bushings did you use with the Alston Subframe connectors. Thanks
badazz81z28 is offline   Reply With Quote
Old 02-07-2009, 05:49:22 PM   #2
skatinjay27
in all honestly its just a piece of aluminum round stock...
the Brand doesn't really matter... what to look for is price and if it comes with all new GOOD hardware.
ptfb's
global west
speedtech
just to name a few solid bushing brands.
i personally would just get the ones with the best value.
AJ
70 rs- down for a streetfigher/pro-touring face lift!!!!
skatinjay27 is offline   Reply With Quote
Old 02-07-2009, 06:11:13 PM   #3
ParkerRS
^^X2
Tommy
ParkerRS is offline   Reply With Quote
Old 02-07-2009, 07:35:46 PM   #4
krabben1
krabben1's Avatar
GWs are a pretty blue color!
Gen VI 454, Autogear M-22 W, Moser 12Bolt
Hurt-Johnny Cash
http://www.youtube.com/watch?v=McV7pjwVFbE
http://www.youtube.com/watch?v=gg8xYSWOFR8
krabben1 is offline   Reply With Quote
Old 02-07-2009, 09:07:33 PM   #5
Lowend
Lowend's Avatar
Yep, as long as they are interlocking all of the SFB's are about the same.
Global West, DSE, PT F-body
“Realists do not fear the results of their study.”
- Fyodor Dostoyevsky
  • This makes sense. I'm agreeing with Lowend,. - Shawn 1/27/2011
  • Lowend sit down for a minute because I'm going to agree with you on this point - Knuckle Dragger 12/14/2012
  • I (gulp) very much agree with this - 69LM1 1/12/2013
Come make a difference at Kiva!
Lowend is offline   Reply With Quote
Old 02-08-2009, 12:09:28 AM   #6
BonzoHansen
LGM, Admin
BonzoHansen's Avatar
LOL, true.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
BonzoHansen is online now   Reply With Quote
Old 02-08-2009, 10:13:05 AM   #7
Hoot
As they said. They are just round stock aluminum. Now I made mine interlocking so had to do some work on the lathe. But I made this for a fraction of the cost of new. I got my stock from speedymetals online. Could have got local but wanted to try them out for future purchases.
1973 Firechicken "Troy Built"
Project thread http://www.nastyz28.com/forum/showthread.php?t=130791
Member of the Dark Side
Nothing to it, but to Duit !
Hoot is offline   Reply With Quote
Old 02-08-2009, 10:29:35 AM   #8
volsfan
volsfan's Avatar
Those turned out nice Hoot!
volsfan is offline   Reply With Quote
Old 02-08-2009, 10:49:21 AM   #9
Hoot
Thank you. I have access to a lathe at work so It was a no brainer for me. Took longer then I thought but still good experience for me. Was my first real project with the lathe.
Old 02-08-2009, 12:04:44 PM   #10
79T/Aman
Site Sponsor
Of course I'll tell you to get the pro-touring f-body, but othere than being able to be set up 3 different ways there is also another feature of our bushings that is never mentioned, the ability to still "square" the frame to the body with ours, all others do not allow for factory missalignment to be corrected because the center hole is the same size as the bolt
frame connectors, roll bars, suspension, engine parts www.pro-touringf-body.com
79T/Aman is offline   Reply With Quote
Old 02-08-2009, 12:58:39 PM   #11
volsfan
volsfan's Avatar
I was wondering if that was a good thing. I bought mine from you and noticed most of the others only had enough room for the bolt only. Now I feel good knowing I can correct some misalignment issues. Thanks again!
Old 02-08-2009, 01:01:25 PM   #12
hucks 70
are they really needed ,i put new stock ones in and i installed alstons,im running a big block ,what will it hurt on the car if they are not solid mounts ,anything to look for.
THERE IS NO REPLACEMENT FOR DISPLACEMENT 1970 CAMARO 396
hucks 70 is offline   Reply With Quote
Old 02-08-2009, 01:49:57 PM   #13
skatinjay27
if your subframe connectors are bolted in they will loosen over time and wallow out the holes...
if thier welded in you will end up cracking the welds...
AJ
Old 02-08-2009, 04:47:58 PM   #14
79T/Aman
Site Sponsor
the frame is still bolted with rubber between the frame and body that will allow the frame to move independently of the body, so when you connect the two together the connector bolts or welds take all the twisting load, I have a customer that had CE bolt on connectors with rubber body bushings and he broke the welds on the connectors themselves.
The best analogy I can give you is imagine using a shovel that is put together with electrical tape all solid pices but held with rubber!
Old 02-08-2009, 04:56:12 PM   #15
badazz81z28
BANNED
Those are nice!
Does anyone know which brand and where is the best deal is?
