Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Drivetrain & Performance > Competition Camaros
Thread Tools Rate Thread Display Modes
Old 02-04-2009, 10:57:28 PM   #1
allen.m
is mid to low 11 seconds in this set up
3550 lbs
434 9.8:1
msd ignition
850 holley hp
Super Victor port matched to heads
RHS 220 cleaned up
HR 240 248 .560 .578 112 ls
1 3/4 headers 3inch x pipes in to borla xr1 muffler
tko 600 5 speed
CE drag shock, Moroso Trick Springs
CE slide-a-link
detroit locker
3.89 rear gear
295 65 15 mt drs
i know its a stick but lets just say i can get it to hook good, do you think this combo will do mid to low 11s? if not what would get it there?
70 Camaro, 434 sb,TKO 600, currie 9" 3.89 rear gear
79 T/A, 403 heads, cam, intake, th400, 10 bolt 4.10
74 260z, stock, hoping to put a 406 in someday
06 road glide
allen.m is offline   Reply With Quote
Old 02-05-2009, 05:05:23 AM   #2
Mwilson
Its probrably possible but you'll be shifting! I went 11.4's with 50 less cubes but more compression & bigger cam & automatic. everything else is very simular. I dont even want to guess anymore, I expected more outta mine. If I had your combo Id be shooting for low 11's high 10's myself.
1977 CAMARO PROJECT
Mwilson is offline   Reply With Quote
Old 02-05-2009, 10:11:09 AM   #3
bski224
Id have to say mid to upper 11's depending on your 60' time. Also what kind of heads are you running on that motor. Suspension is the key factor in this!!
1972 Z28 388 SBC
bski224 is offline   Reply With Quote
Old 02-05-2009, 10:15:47 AM   #4
vegas1974z28
Originally Posted by allen.m
3550 lbs
434 9.8:1
msd ignition
850 holley hp
RHS 220 cleaned up
tko 600 5 speed
CE slide-a-link
detroit locker
3.89 rear gear
295 65 15 mt drs
I love the guessing game......
I weigh 3550 race weight
4:11
496 cubes
13:1
400 with a brake and slicks
10.73
You will break that 5 speed b4 you will ever get close to low 11's. That being said, look at the MPH if you can get that thing around 119-120 that is a low 11 car with traction. JMHO
I would say an auto with tire that should run 11.30's
Mattie
70 RS 454
74 Drag car 496
10.425 @123.36 1.425 60'
02 Z28
vegas1974z28 is online now   Reply With Quote
Old 02-05-2009, 10:30:12 AM   #5
smallblock413
Thumbs up
3550 lbs
434 9.8:1
msd ignition
850 holley hp
RHS 220 cleaned up
tko 600 5 speed
CE slide-a-link
detroit locker
3.89 rear gear
295 65 15 mt drs
possibilities look good.. it may even suprise you
welcome to the gun showbest n/a run spining '81 camaro
7.35@96.20
best nitro show
6.78@101.87
best mph
102.58
best 60...1.48
best 330...4.36
best react...287
"BFW"Racing..DOING IT ON...
SLAPPERS,RADIALS,ANDLEAFS
http://www.youtube.com/watch?v=qhcvG0dSyGw
http://www.youtube.com/watch?v=k2pKLYNEcbg
smallblock413 is offline   Reply With Quote
Old 02-05-2009, 11:08:36 AM   #6
TooLateVTEC
Send a message via AIM to TooLateVTEC
Im going to say mid 11's.
'86 IROC-Z Stock 350TPI with a cam....5.63@126 so far
'79 Z28 streetcar - 7.01 - 11.05 pump gas - sold
http://i32.photobucket.com/albums/d1...RaceCar011.jpg
TooLateVTEC is offline   Reply With Quote
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 02-05-2009, 01:47:21 PM   #7
allen.m
bski224- the heads are (racing head service 220), they have had some minor porting, mostly just a clean up.
vegas1974z28- I hope not to break the trans. Tremec said the tko 600 could handle quite a shock load and a consistent 600 ft/lbs but i guess there is that word "could" in there.
i'll take 11.99 that would make me happy for now but i've got the bug pretty bad, so im sure i'll want more. but this is a street/stip car and i would like to keep it that way since it will see more street than strip.
if i went auto, what would be a good set up for the trans and converter on the street? would it still be good at the strip?
06 road glide
Old 02-05-2009, 02:07:17 PM   #8
John Wright
John Wright's Avatar
Send a message via AIM to John Wright
Check out this vid of a manually shifted car....Tremec 6 speed though, not the TKO 5 speed.
http://videos.streetfire.net/video/W...-Car_87153.htm
John Wright is offline   Reply With Quote
Old 02-05-2009, 02:56:58 PM   #9
Mwilson
I wouldnt go auto unless your looking for bracket race consistancy, I want to go manual myself
1977 CAMARO PROJECT
Old 02-05-2009, 05:31:42 PM   #10
grog
What will the TKO 600 take? The 6 speed in that Viper can't be stock.
grog is offline   Reply With Quote
Old 02-05-2009, 06:21:33 PM   #11
OldCamaroNut
OldCamaroNut's Avatar
My sig line says 11.5 with an automatic. Your setup is very similar. Shift quick and good luck!
1979 RS weighs 3580 lbs. with me in it. 406 w/ Victor Jr, Pro Systems 850 CFM carb, Pro Topline 220cc heads, solid roller cam with .630 lift, 264-270 duration @.050, Ross -5cc mini dome racing pistons, 12.5 to 1 compression, Forged crank and rods, splayed 4 bolt mains, 1.875" headers. Converter stalls at 3200, Trans Specialties turbo 350, 4.10 gears. Fastest to date is 10.87 @ 123.
OldCamaroNut is offline   Reply With Quote
Old 02-05-2009, 06:40:15 PM   #12
John Wright
I'm putting a Viper T56 in my Camaro, it is the tougher of the T56s, so I'm told. I do know that the output shaft is really beefy on the T56 that I have.
Old 02-05-2009, 06:48:59 PM   #13
yobin67
You should go 11's easily.I used to run my current engine combo with a Muncie M21.Best it ever ran was an 11.60 with the 4 speed.Granted it was a lot of fun,but clutch changes and inconsistancy got the best of me,so I went auto.
pump gas 355,3400lbs,11.31@119.4
100 shot NOS,little less gear,all else the same 10.85@125
http://i553.photobucket.com/albums/j...7/IMG_0129.jpg
http://i553.photobucket.com/albums/j...7/IMG_0125.jpg
yobin67 is offline   Reply With Quote
Old 02-05-2009, 08:01:59 PM   #14
allen.m
John Wright- that is a cool video but i dont think my trans would take that kind of power . But that Viper T56 does look beefy.
Mwilson- ya im going to atleast see what i can get her to do. i had an auto in my last car and it was definetly not as fun to drive.
grog- 600 ft/lbs is what it is rated at.
yobin67-i sure hope it does 11s easy that would make my day. if not guess i'll have to look into some spray.
06 road glide
Old 02-06-2009, 10:02:35 AM   #15
hhott71
hhott71's Avatar
You'll have to master these 3 things first.
launch
traction
shifting abilities.
Engine is way over kill for low 11's.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
