11-28-2008, 10:24:55 AM
#1
power steering pump cap spraying fluid
Whats up guys , my power steering pump has started spraying fluid it looks like it is coming out of the little vent hole in the middle top part of the cap. I noticed it after doing a couple of dounuts in a parking lot,and at first thought I had some how caused it with the round and round action. but I drove it again for the first time the other day and noticed it was coming out of that little hole, and landing on my inner fender. Any ideas what the problem is? thanks for any help you may offer.
11-28-2008, 12:53:18 PM
#2
If the pump is over filled it will do this,check when cold and see where level is at.
1970 SS/RS L-34 A/C 4 spd.
When you get to the end of your rope....tie a knot & hang on.
11-28-2008, 02:38:03 PM
#3
Overful, or air in the system are things I'd check. Jack the front in the air, and with the engine running, steer the wheels in both directions slowly until "lock" and hold for a second to bleed any air that "may" be in the system
Adding more power since 1971
Big Willie and Tomika's Street Racers
STUGOTS-SoCal
11-28-2008, 03:43:16 PM
#4
thanks for the input guys, i'm sure it's not overfilled because i've been driving it around for a couple of years with no problems. it started after my dounut/burnout adventure. it's making noise now because it's low on fluid.I was going to put some more in but I don't won't it to makle a bigger mess. could turning the wheels all the way and running up the rpms cause it to gulp some air somehow? I'll try to bleed it just in case. thanks again.
11-28-2008, 03:57:29 PM
#5
Well, if it was low on fluid during your thrash, it may be "foaming", and that's the problem. THAT would introduce air to the system. Let us know
STUGOTS-SoCal
11-29-2008, 08:22:57 AM
#6
hopefully your right, my wife has to work on sat and I have a sick 2 year old . so I'll try to check it sunday and I'll let you know. thanks again
12-19-2008, 10:56:30 PM
#7
update , I tried adding fluid and bleeding the system and it didn't help. so I pulled the pump and checked it out .I noticed there was something rattling inside. pulled it apart and a little round metal plug was laying inside. Looks like some sort of pressure bypass thingy. so I purchased a new pump and I'll give it a try and report back. I just wonder what caused the plug to come out, hopefully old age ha ha. maybe the new one won't self destruct.
01-18-2009, 02:25:55 PM
#8
final update the new pump is working fine so far. thanks for the help
01-18-2009, 04:37:01 PM
#9
You keep doing donuts with the steering pump CRANKED and presure on the pump and you maybe changing that one later on, you wont be saying $$$$ ha ha $$$$$
01-18-2009, 07:16:22 PM
#10
Cure-stop doing donuts in the future. I go to the donut shop for my donuts.
I haven't done a donut since 1973. That's when I blew my tranny. Never again.
01-23-2009, 11:37:10 AM
#11
Give it the donut test and find out
STUGOTS-SoCal
| Thread Tools |
| Display Modes |
Linear Mode
