Old 08-06-2008, 10:33:29 PM   #1
califgold
Hobby stock engine combo
block 3970010 4 bolt
crank 3932442
heads 462614
bottom end has standard bore stock rods and pistons and all balanced
2 brl intake and holly carb 79-80- jets
what do yall think and is there a way to fiqure out h.p.
i run a saginaw in 2nd gear
thanks for the help and i love this site and so far people have been a great help
Califgold
califgold is offline   Reply With Quote
Old 08-06-2008, 10:45:26 PM   #2
cmonson
cmonson's Avatar
huh...
maybe 250 HP
cmonson is offline   Reply With Quote
Old 08-06-2008, 10:57:18 PM   #3
onovakind67
Tell me this:
Bore, stroke, rod length, piston type, ring type, bearing type
any accessories like water pump, fan, power steering, etc
oil pan configuration, windage tray? crankcase vacuum pump? wet sump?
Head type, specifications, modifications, flow numbers if possible, valve sizes, compression ratio
Intake type, modifications, runner length if possible, carb type and cfm
Exhaust system configuration and dimensions
Primary tube size and length, collector size and length, crossover? X-pipe?
Muffler cfm and size
Cam and lifter type, advertised duration, duration @.050”, lobe lift, intake lobe installed centerline, lobe separation angle, rocker arm type and ratio
Horse sense is the thing a horse has which keeps it from betting on people.
onovakind67 is offline   Reply With Quote
Old 08-06-2008, 11:56:56 PM   #4
TheFly
Posts: n/a
Originally Posted by cmonson
huh...
maybe 250 HP
First though would be some form of short track where using first is a waste [dirt]and you never get into 3rd. Sounds fun.
I like to hit back twisty roads on my bike where you rarley see the top of 3rd and staying right in the red ;0 Virago was gear factory to run high R's and loves to stay there all day. Folks often ask how to lower the RPM at 55, we tell em to push red and ignore it.
Old 08-07-2008, 12:18:33 AM   #5
califgold
work with me guys !
First off im the driver and alot of terms we are using are like talking a foriegn tounge to me but learning fast. I will make my best attempt to explain.
1)std bore,stock pistons,rods balenced with crank
2)all bearings are clevitte 77
3)circle track oil pan
4)2 brl holly carb
5)flowmaster duel exaust
6)i believe 485 lift on rv cam
7)slot rockers
8)sportsman heads with over size valves not sure of size.
we run on a 1/4 to 3/8 dirt circle track to much horsepower can oftem times hurt you with a 1 legged rearend. My father was the engine man and since passed i have a very good friend doing 99% of the work and doing a great job! would not still be racing without him. We are kinda learning on the fly!
thx again Califgold
Old 08-07-2008, 12:37:29 AM   #6
Rick WI
Post 2 is about right on the HP. Takes a TON of tricks and lots of cam to get street stocks in the 300 range.
Rick WI is offline   Reply With Quote
Old 08-07-2008, 12:57:38 AM   #7
still working on an engine for that freedom series in the hobby stock division huh ?? like i mentioned in your previous thread a couple weeks ago i've got a friend who is very competitive in the hoby stock division . he races at bakersfield and victorville and he swears by these vacum rule cams from speedway motors that use the rhoades lifters . with a stock sbc with only the speedway motors cam and a good oiling system he's running about 7000 rpm at the end of the straight .he's running a saginaw 4spd also in 2nd gear and i think the rear gear is a 5 series gear but can't remember the actual gear size
muscl car is offline   Reply With Quote
Old 08-07-2008, 12:59:58 AM   #8
califgold
thx
I have always been a top 5 car in this hobby stock class its the class under the streeters. The only difference with this new block and lower end is its not bored .040 the top end will be the same so i guess i hope that ill still be up front. What is the normal hp with a stock 350 with this type of block?
thx again Califgold
p.s any of them tips to help boost the h.p would greatly help
Old 08-07-2008, 01:03:20 AM   #9
califgold
yea i sure am buddy. i looked into that cam and im building a little stronger motor for next year and planning to use that cam thanks for the help and those bako boys are fast ive competed with them are you talking about the johnson boys in the novas? #22 is the number if my memory serves me right.
Old 08-07-2008, 01:05:51 AM   #10
TheFly
Posts: n/a
id be going for a SB that is factory stroked which wouldn't be a chevy.
First thing ya do to SBC, stroker kit, then BB. Get yourself a stroked factory motor and still be hobby stock. Think BOP, they had stroke factory.
Old 08-07-2008, 02:20:48 AM   #11
califgold
bop??
All i came come up with is Buick,olds,Pontiac. am i close ?
Old 08-07-2008, 02:55:55 AM   #12
KansasTwister
KansasTwister's Avatar
yup bop means buick olds pontiac.
1980 Camaro Berlinetta 1979 Camaro Berlinetta w/ T-tops
theflash: Black smoke is generally a sign of running too rich, or you have a diesel.
I want to die in my sleep like my grandfather.... Not screaming and yelling like the passengers in his car.
My nametag says Ryan
KansasTwister is offline   Reply With Quote
Old 08-07-2008, 03:03:12 AM   #13
rustbucket79
What are the engine rules for that class?
First thing that comes to mind is angle milling the heads and swapping to a 2bbl specific solid flat tappet cam. (relatively) lots of HP to be had there. From there you can spend a pile of money on lightweight parts, porting, etc. Depends on what you want to spend and how legal you want to be.
Vids of the car: http://www.youtube.com/watch?v=Fb39m4ToP50
rustbucket79 is offline   Reply With Quote
Old 08-07-2008, 08:00:25 AM   #14
onovakind67
Factory stroked? Is a 350 a factory stroked 327?
I'd be hard pressed to think of one GM motor that came from the factory with no stroke...
Old 08-07-2008, 02:53:42 PM   #15
the hobby stock engine ruling is basically a stock 2bbl motor and ignition and has to pull 16"hg of vacum @ idle
these are some of the cams used like what's in my friends hobby stock
http://www.speedwaymotors.com/p/6615...emNo=hydraulic
