06-26-2008, 02:29:26 PM
#1
Location: Striking fear and destroying the enemy from my borders
Low speed fan controller inop
Fan works, I partially tested the fan and it DID work thru the controller, but I dunno if I mighta burnt it up jumping the temp probe like it says...
Anyhows....found a source for 75A/12V relays....same guy on ebay...
RELAY - http://cgi.ebay.com/ebaymotors/75-AMP-tyco-12-volt-12v-spst-DIODE-RELAY-fan-motor_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el12 62QQcategoryZ133192QQihZ024QQitemZ370056315673QQtc Zphoto
SOCKET -
http://cgi.ebay.com/ebaymotors/ws/eB...m=370056312865
So I buzzed him and am awaiting a reply back.....I gotta do SOMTHING to get this working how I want it....
Anyone else having issues ?? Controller is wired properly...but something just isn't 'right'.....
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America ' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in THIS country who no longer understand it.'
http://community.webshots.com/user/rscamaro73
Facebook - rscamaro73
I'm sometimes called Wayne
06-26-2008, 05:31:07 PM
#2
07-01-2008, 09:35:52 PM
#3
Anyways...found my problem....
the 12V SWITCHED ign wire I had......I used a splice/crimp connector (blade that cuts/contacts 2 wires). Anyways, it never 'cut' the insulation to the line to my temp control, so I had a 'dead' control....then I jumped it and burnt the controller
$35 later I think I'm back in business....but now I'm involved in another project and dragging it out....
07-01-2008, 09:59:32 PM
#4
What are you talking about Wayne?
Ev
Trust me...you don't have to see it to be able to use it. - cam80
I've been trying to get the hummers in my yard, but no luck. - spoonLT1355
Levi, I can understand.....buzzers would be annoying on a car with tube doors - John Wright
ugly chicks need lovin too - Lammy
NW Lifetime Member of GFB Fan Club.
07-01-2008, 10:40:54 PM
#5
LOL.....Whatever it is, he fixed it, with no help from anyone!
Go Wayne!
Ask not what your country can do for you, but what can you do for your country.
07-01-2008, 10:54:06 PM
#6
LOL'Z....
Nah, the problem was that my low speed temp controller wasn't working....all I had was a manual switch for HIGH....
Well, after buying a new controller and rechecking the wiring...I found that my 12V switched wire was dead....and the source ended up being these -
The 'blade' portion didn't cut thru the insulation on the wire going to my controller, so it was 'essentially dead' , til I jumped it and burnt it out....
HOPEFULLY the way I have it wired now is good....with the 75A relay  I can't check it til I'm done replacing my oil pressure sending line....
07-01-2008, 10:55:30 PM
#7
Ahhh...gotcha. So you had a 2 speed switch?
Ev
07-01-2008, 11:37:03 PM
#8
No, its a Taurus fan with 2 speeds, I just wired the HI speed to a manual switch....and the low speed was connected to the controller....
HOPEFULLY tomorrow it'll work that way....
Of course I had help wiring it the first time...cus I dunno where to start...
07-01-2008, 11:38:17 PM
#9
I think on Monday I'm going to pull the belt driven fan off the truck and put the electric I got on there. Just gotta figure out how to wire it so that its running when the truck is running. Red is hot and Black is ground. I do know that much.
Ev
07-01-2008, 11:44:41 PM
#10
Its got HEI, correct ? Wire your 12V to a relay off your IGN terminal on the fuse block....then run another line 12 V hot off the battery to the relay (switched) to the fan....ground the other side of the fan. Then its on when your engine is running only....not 'on acc' or anything.
What kinda fan you got ??
make sure you got a diode wired in so that it don't mess nuthin up when the engine is off....and the winds blow....
07-01-2008, 11:51:05 PM
#11
LGM, Admin
Nice fix, those connectors suck azz.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NJ Camaros and Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Originally Posted by big gear head
Just remember, if you can't afford to do it right the first time then you can't afford to fix it the second time.
Where's that confounded bridge?
07-02-2008, 03:14:21 PM
#12
Originally Posted by rscamaro73
NOOOO!!!! Those things are evil!!
07-02-2008, 03:47:01 PM
#13
these style connectors are nothing but a piece of junk and will cause many hours of frustration until they're removed
| Thread Tools |
| Display Modes |
Linear Mode
