Old 06-10-2008, 12:31:56 PM   #1
rjc1629
Someone help a Newbie!
First off, forgive me if I ask any stupid question, this is my first project car and I'm kinda lost on what to do next. I have a 79 z28 that I have completely disasembled. The body has been soda blasted and is on a body dolly waiting for body work. I have a couple of areas that need patching and a few dents. My problem is that the body has already began to get surface rust on it. Should I go ahead and prime it now and grind off the primer to weld in the patches or weld them in asap and then primer (might be a couple of weeks)? Also, I have a spray gun but I'm not sure what kind of primer I need and how to mix it. Any help is greatly appreciated
"What becomes of me but death, deserved, received.
What of a crooked man's desperate plea,
seeking The Good Judge's mercy.
He loved the lovable, the decadent, the holy
and He made a way for me..."
rjc1629 is offline   Reply With Quote
Old 06-10-2008, 01:38:26 PM   #2
BTTB71SS
BTTB71SS's Avatar
There are several ways to do this. You could spray an epoxy primer on the car until you are ready to weld in the patches/repairs your are doing. Then sand the area off where the welding needs to be done and you should be just fine.
I used a product called prep step that i get. I have sanded the entire car done to bare metal and then sprayed this on to prevent rust. It has been like this for 8 months now with no rust showing. It does something to the the metal to give it the right ph balance before I usually spray it with ZeroRust.
BTTB71SS is offline   Reply With Quote
Old 06-10-2008, 01:44:53 PM   #3
rjc1629
Where can I get this "prep step" stuff? Is it ratle can or do you spray it w/ a gun?
Old 06-10-2008, 02:02:59 PM   #4
BTTB71SS
BTTB71SS's Avatar
prep step is product you mix with water and then use a regular spray bottle. No spray gun or anything else needed. You can even wipe it on with a towel.
Here is the link where i get it from:
http://autobodystore.net/Merchant2/m...gory_Code=RCAC
Old 06-10-2008, 02:20:12 PM   #5
rjc1629
cool, thanks for the info.
Old 06-10-2008, 08:56:35 PM   #6
BTTB71SS
BTTB71SS's Avatar
Here's a pic of the rear quarter sanded to bare metal and sprayed with prep step
Old 06-11-2008, 09:33:41 AM   #7
rjc1629
can you primer right over it, or do you have to sand it off first?
Old 06-11-2008, 09:44:55 AM   #8
BTTB71SS
BTTB71SS's Avatar
Nope you just have to wipe it down with wax/degreaser and you are good to go
Old 06-11-2008, 10:18:12 AM   #9
rjc1629
sweet, I might give that a try.
