Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Suspension, Brake & Wheel Topics
Thread Tools Rate Thread Display Modes
Old 04-07-2008, 02:41:39 AM   #1
fiscus
Arrow Will a 275 tire work better on a 15x8 or 15x10?
I have a set of 275/50-15 nitto drag radials that I'm going to put on rims. They are about 12" wide at the bulge, 25.75" diameter. Will the tire perform better on a 15x10 rim?
Assuming I find the perfect backspacing and fitment is not a problem.
Thanks!
fiscus is offline   Reply With Quote
Old 04-07-2008, 03:44:42 AM   #2
blades67
blades67's Avatar
I think they will work better on the 15X10 rims. The contact patch will be almost bowed on the 15X8 rim and the tire will have more sidewall flex. It can make the rear feel like it is squirmming around when cornering.
David.
1978 Type LT - 350/TH200-4R.
blades67 is offline   Reply With Quote
Old 04-08-2008, 12:22:48 AM   #3
Kamikaze
Kamikaze's Avatar
A 15 x 10 will lay-out the tread more evenly across while a 15 x 8 will bulge the sidewalls out more in the section width.
If you can fit the 15 x10 within the fenderwells, (Mini-tubs?), there will be a slight bowing of the section from the edge of the tread contact patch out to the rim and have a slightly lower overall height but only a slight bit. Sidewall flex on the 15 x 10 should be substantially less.
From the back, it will look really tough!
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 04-08-2008, 01:33:53 AM   #4
1FstChevy
What they said ^^^ a 10" will be a safer and more appropriate wheel width for that tire, assuming you can fit a 15x10 in the rear with minimal modification.
6Spd EFI 1980 Camaro Z28/Z49 - Street Fighter - Amongst other GM autos Atomic Orange Z06 is next!
Project Thread: http://www.nastyz28.com/forum/showthread.php?t=139285
1FstChevy is offline   Reply With Quote
Old 04-08-2008, 02:04:49 AM   #5
blue79z28
hi i know i am a new guy, but thought i would just say i have 28x10x15 slicks on 10 " wide wheels and they just fit but they do fit , sorry no pics, my car is a 79z28 just trying to help
blue79z28 is offline   Reply With Quote
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 04-08-2008, 10:05:56 AM   #6
fiscus
Do you know what backspacing your wheels have? How close does the wheel / tire come to the leaf spring?
thanks!
Now it seems it just comes down to if it fits or not!
Old 04-08-2008, 11:08:54 PM   #7
1981gMachine
1981gMachine's Avatar
Send a message via AIM to 1981gMachine Send a message via MSN to 1981gMachine
275/60R15 on a 10" Rim don't bother asking me backspacing, I have a 1st gen 12bolt
If you measure them, they are 12" bulge to bulge and 28" dia, with about 1/2-3/4 room left inward
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Old 04-09-2008, 08:38:30 AM   #8
74chopper
i got 275/60/15 on rear of a '70, car is raised a bit in the rear though, dont think fit in at normal ride height.
74chopper is offline   Reply With Quote
Old 04-09-2008, 01:11:08 PM   #9
Cam72aro
15x10 with a 5.5" backspace is what you need.
Cam72aro is offline   Reply With Quote
Old 04-09-2008, 04:12:22 PM   #10
1981gMachine
Yea the 60's will rub, when I had taken my shocks off (air shocks) and sat it down the rear tires were close enough that they would rub on bumps. I'd get something with about a 26" dia over the 60's which are 28" dia
Present Setup:
Near Future:
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
