Old 02-13-2008, 09:50:29 PM   #1
Pacecarjeff
Radiator hose for BB 2nd Gen
This has been the typical shape for the BB upper hose #3979192 on the 2nd gen cars.
(As well as small block - showing different number -->3970124)
all the resto houses sell this shape - I believe it is wrong.
After researching a while - I think I have an exact match on what it is REALLY supposed to be.
Here is one I made (top), next to the original hose I found.
What do you guys think? - Is this correct?
I am still looking for an original BB lower - any one have one?
Pacecarjeff is offline   Reply With Quote
Old 02-13-2008, 10:01:41 PM   #2
Dave Nelson
Dave Nelson's Avatar
Pacecarjeff:I believe the original hose has a slight bend at the thermostat housing,some repros do not have this bend.
1970 SS/RS L-34 A/C 4 spd.
When you get to the end of your rope....tie a knot & hang on.
A wife and a steady job have ruined many a good fishermen.
I once gave up fishing, it was the most terrifying weekend of my life.
Dave Nelson is online now   Reply With Quote
Old 02-13-2008, 10:11:26 PM   #3
Pacecarjeff
I need to find an original 124 hose also -
I believe that shape is not exactly right either.
Old 02-16-2008, 10:33:10 PM   #4
70-SS/RS-L78
70-SS/RS-L78's Avatar
Hear are 2 Original 1970 Big Block upper hoses, The hose on the bottom is the Original L78 upper hose and clamps from Kentucky Gold.
The middle one is a GM upper hose from a 70 L34 I parted a few years back. The Top hose is “Not Even Close”. It is a Piece of $hit Reproduction!
It has the correct markings; but it is JUNK!!!
Mark Lenhard
I'm Getting Too Old For This $hit
70 Kentucky Gold SS/RS-L78 36,000 Miles
09 G8-GXP #992/1829 24,000 miles (For Sale)
90 Old's Touring Sedan. SPRCHRGD-L32/3800
1983 El Camino Lingenfelter LS1 Stroker 4L80E
BAC-Restorations
"Only two things are Infinite
The Universe and Human Stupidity
And I'm Not Sure About The Universe"
Albert Einstein
70-SS/RS-L78 is offline   Reply With Quote
Old 02-16-2008, 11:31:03 PM   #5
Pacecarjeff
Thanks - do you have pictures of the lower hoses too.
I would like to see them.
That is kinda what I was saying, the repro hoses for these applications are not right.
I want to try and produce them exactly correct.
Old 02-17-2008, 01:01:51 PM   #6
MagicRatt
Mark, I tried using that top (upper) hose on my car. That thing was a mess!!
In order to finish first, you must first finish...
MagicRatt is offline   Reply With Quote
Old 02-17-2008, 09:01:34 PM   #7
79ZED
The 3970124 hose was designed for a/c cars, at least in SBC form. The 3970120 was for non a/c cars.
You can use the 124 hose on a/c or non a/c cars, but you can't use the 120 hose on a/c cars because the hose is very close to hitting the a/c pulley or belt.
I guess they just wanted to simplify parts stocking.
John
79ZED is offline   Reply With Quote
Old 02-17-2008, 09:39:55 PM   #8
Pacecarjeff
I don't show a 3970120 hose in any of my books.
Do you have a picture of an original hose?
From what I can see, the 124 hose is noted for ALL SB Camaros 1970-75 SB.
I don't think the current repro shape being produced is exactly right.
Below is the hose shape for the 3970124 that I believe is more like the original.
However - I don't want to change over from the other one (way at the top of this thread)
until I get another original example to compare to.
I had one for a short time, but it was very early in my research, and I had to send it back to quickly.
Edit...........
I have now determined that this hose above, is the correct shape for the 3970120 non H-Duty Radiator. Broadcast code JN.
Old 02-18-2008, 02:29:22 AM   #9
79ZED
Pacecarjeff,
Sorry, I don't have any pictures, wish I did though. My GM Parts Manual 1977-81 lists the two hoses as described. It also shows the same in the assembly manual. I no longer have my original 3970124, but I have seen the 120 hose and it is much straighter than the 124, since it doesn't have to "go around" the a/c clutch and belt.
I'll dig up my GM Illustrated Parts Book and have a look for an illustration.
John
Old 02-18-2008, 05:15:04 PM   #10
Pacecarjeff
Just looked through my AIM for 1970.
There it is- page 79 -UPC6/B3 --- the hose called for for the small block V8 is the 3970120.
Don't find the 3970124 hose listed in this .....
and I don't see the BB hoses in this thing anywhere ???
Old 02-19-2008, 11:43:16 PM   #11
Hotrodpaul
The 3970124 hose is listed with HD cooling which is the supplied radiator for the 70 Z-28. Below is a pic of an original NOS 3970124 hose and picture of an original new 70 LA built Z-28 underhood shot showing the hose.
Paul
70 Camaro Z28 Citrus Green M40 3.73's
Hotrodpaul is offline   Reply With Quote
Old 02-20-2008, 03:57:45 AM   #12
Pacecarjeff
GREAT PICTURES.
Thanks -- those are a big help.
Old 02-20-2008, 10:19:59 AM   #13
GREGS396
Jeff, please let me know what hoses would be correct for a 1972 SS-396 Camaro w/o A/C. You may PM me with cost and availibilty.
Thanks, Greg
GREGS396 is offline   Reply With Quote
Old 02-20-2008, 11:34:41 AM   #14
Pacecarjeff
You need a 3973192 - 70-72 Camaro Upper BB Radiator Hose.
click here for all applications ---> Radiator Hoses
Old 02-20-2008, 04:54:14 PM   #15
CamarosRus
Jeff, Are you buying these misc hoses from XYZ source, removing any XYZ printing, logos, etc .............and imprinting the clean new XYZ hose with your reproduction, same as original numbers/letters/words??????
Is this THE process??????????????
Just want the education, before I buy!!!!!!!!!!!!
Chuck Sharin
Seattle(area)
CamarosRus@Gmail.com
70 R/S Z-28, 70 SS L-78, 70 R/S SS L-48 (all 4spds)
69 COPO "Recreation"
CamarosRus is offline   Reply With Quote
