Old 01-21-2008, 07:53:41 PM   #1
woody80z28
woody80z28's Avatar
S10-Blazer rear disc conversion
A comprehensive list of what needs to be done to go from factory rear drum on a 70-81 Camaro to 98-04 S10-Blazer rear disc.
Once finished you will have an 11.6" rotor with aluminum 1-piston calipers that are staggered to clear the factory shocks. The backing plates bolt right on to the factory rear end housing with no modifications and the parking brake is a shoe inside the rotor hat. The brakes clear the factory 15" 5-spoke steel wheels with no problems. I am assuming they also clear other 15" wheels.
This stuff can be found at your local parts store, ebay, GM dealer, gmpartsdirect.com, rockauto.com, etc. or even a salvage yard.
My total cost was cheap since I used salvage parts. My only new parts were rotors, Hawk pads, Vette master and Summit prop valve for about $160. It was $275 for all the salvage parts, so grand total was about $435. You will be looking at more like $500 going all new.
Please sticky. I will post up more info later on, but this is at least a start.
Parts you will need:
  • 1 - Driver side 4WD backing plate, e-brake assembly (GM PN-15064302)
  • 1 - Passenger side 2WD backing plate, e-brake assembly (GM PN-15773309)
  • 8 - 3/8 bolts, lock washers and nuts to mount backing plate to rear housing
  • 3/8 washers to shim the backing plate for perfect fitment of the caliper to rotor (2 each bolt in my case)
  • 2 - Driver side 4WD caliper, or passenger side 2WD caliper, mix & match (Loaded kit w/ brackets & pads Cardone PN-164712) (Loaded kit w/ brackets & pads NAPA PN-TS 1422228)
  • 2 - Caliper brackets - if needed
  • 1 - Brake pad set - if needed (HWK-HB305Y-610)
  • 4 - caliper bracket bolts (GM PN-15726460)
  • 2 - banjo bolts (GM PN-10286122)
  • 2 - 2WD Blazer rotors (NAPA 4886725) (Powerslot 8638PSL & 8638PSR)
  • 1 - Master cylinder (80 disc/disc T/A, 79 disc/disc Vette, 70 manual disc/disc Vette all work)
  • 2 - Brake hoses (you can use stock Blazer hoses or any braided stainless ones with a 10mm banjo fitting)
  • 1 - Prop valve (stock 80 T/A works, I used a Summit adjustable)
  • New style brake cable (I used the Blazer cables, but Lokar universal would be less work)
  • Brake fluid, gear oil, axle seals
Rotor Specs
Outside diameter: 11.61"
Height: 2.87"
Thickness: .79"
Mounting face to friction surface: 2.08"
E-brake surface diameter: 7.5"
Caliper Specs
Aluminum
Single 1.875" piston
Floating
http://www.motortopia.com/album/view...frontrear_disc
http://www.nastyz28.com/forum/showthread.php?t=94303
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Holley HP EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ custom gauges
My Chevy garage GEARHEAD dezign
woody80z28 is online now   Reply With Quote
Old 01-23-2008, 12:51:40 PM   #2
BigAls87Z28
Do you have aprox total cost?
I would also like to see a write up like this for 1LE brakes?
GM Inside News: Your GM News Source!
2009 Malibu LT: Sexy in Black
1987 Camaro Z28: lots of stuff, but the heart is bad...
1972 Camaro RS: 350 with Hooker Comp LT coated headers, Magnaflow exhaust, Edelbrock Performer intake, Edelbrock 600cfm carb, PTFB Suspension with Bilstein Shocks. For Sale?
BigAls87Z28 is offline   Reply With Quote
Old 01-24-2008, 09:09:52 AM   #3
woody80z28
woody80z28's Avatar
My total cost was CHEAP since I used salvage parts. My only new parts were rotors, Hawk pads, Vette master and Summit prop valve for about $160. It was $275 for all the salvage parts, so grand total was about $435.
I'll work on a 1LE writeup.
80Z build thread
Old 01-24-2008, 12:24:21 PM   #4
BigAls87Z28
AWESOME!
I am deffinatly gunna do this, thanks for your hard work!! Guys like you make this hobby great!!
Old 01-25-2008, 07:55:58 AM   #5
kstripes
kstripes's Avatar
Thanks for the write up. I have some of the parts already but do you know the part # for the caliper brackets or a loaded caliper that comes with them? Thanks.
kstripes is offline   Reply With Quote
Old 01-25-2008, 09:25:52 AM   #6
woody80z28
woody80z28's Avatar
Both calipers PNs provided above are loaded with the brackets and pads.
80Z build thread
Old 01-25-2008, 09:29:13 AM   #7
kik_start
BANNED
kik_start's Avatar
Good job and great information Woody!
kik_start is offline   Reply With Quote
Old 01-27-2008, 11:29:47 PM   #8
onerealZ
Thanks for the great info in this post, i already started gathering parts for the swap, but what did u use for the rear lines? not ebrake but to the calipers
Onerealz- 79Z arrival Blue met. Just finished July 06' June of 2007 NastyZ Calender
onerealZ is offline   Reply With Quote
Old 01-28-2008, 10:43:52 AM   #9
woody80z28
woody80z28's Avatar
My buddy who got the opposite-staggered rear said the single rubber hose to the whole rear was standard and all he had to do was thread it in. The hose at the caliper I had was metric, so I cut my line and re-flared it with a metric fitting. Later on I replaced the hose and the replacement for a 2000 Blazer was standard thread, so you can get away without converting your lines to metric, just have to do some work to figure out which one. If you get a PN let me know and I'll post it up in the instructions.
80Z build thread
Old 01-28-2008, 11:01:24 PM   #10
onerealZ
So ur saying i need the stock rear blazer brake lines?
Old 01-29-2008, 04:09:04 AM   #11
Mikey18
Anyone know if this setup will clear with factory 15" rims?
'81 v-6 w/355 & th350
'77 z28 4-speed parts car
Mikey18 is offline   Reply With Quote
Old 01-29-2008, 08:28:43 PM   #12
onerealZ
Yes it will, woody has it behind is 5 spoke Z wheels..
Old 01-31-2008, 10:10:31 PM   #13
BigAls87Z28
I think CPP sells a cool flex line system for people who convert to disk from drum.
Old 02-22-2008, 12:25:36 PM   #14
Timeattack
Great write up, im just a little confused. So if i found a s10blazer in the junkyard i need all of this:
- one drivers side 4WD backing plate AND the e-brake assembly
- one passengers side 2wd backing plate, AND e-brake assembly
- two drivers side 4wd calipers OR passengers side calipers
the thing i am confused about is this: 2 - Driver side 4WD caliper, or passenger side 2WD caliper, mix & match..... does this mean you have to use a 4wd caliper on the drivers side and a 2wd caliper on the passenger side??????? sorry if my question sounds stupid, i just wanna make sure i grab the right stuff
Timeattack is offline   Reply With Quote
Old 02-22-2008, 03:38:41 PM   #15
pete0331
yes, because of the staggered shocks that Camaro's have in the rear.
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
http://community.webshots.com/user/Pete0331
pete0331 is offline   Reply With Quote
