i got about 5 yards of the stuff at work
http://www.dotmar.com.au/products/ac...rtacetal_c.htm
it seem to be the same stuff as the del-a-lum bushings are made of
(delin ore POM depending on the supllier)
i can make the compleet bushing out of that stuff and use a 1" piston rod drilled out to the oem bold size
ore do i need an alu sleeve that goes in the arm itself and delrin washers
i made the bushings with grease fittings and delrin washers already for the rear will post pics later
