Old 11-11-2007, 02:12:00 AM   #1
jaywill
Will 15/8 Wheels With 4.5 Backspace?
Fit On A 80 Camaro W/275-60 Mt/raidals W/out Rubbing?
496 BBC " PUMP GAS "
TO DATE: N/A
BEST ET. 7.14
BEST MPH: 99.6
" X-BREED RACING "
LAST TIME OUT W/CAR
http://www.youtube.com/watch?v=G9uINeUkD74
http://www.youtube.com/watch?v=ubbe0zSAnkY
jaywill is offline   Reply With Quote
Old 11-11-2007, 02:57:04 AM   #2
1970SS385
I have 15 x 8 x 3.75 and 275/60 and it is a tight fit. They rub sometimes because the inner wheel well has some shiny spots. Middle of the tire on mine was cut by the fender lip so i had to roll those But now it seems ok. 1978 Camaro FYI. Probably have an inch total clearance front and backside of tire at largest part.
Aaron
1970SS385 is offline   Reply With Quote
Old 11-11-2007, 09:44:02 AM   #3
Orange71
Orange71's Avatar
Yes. Same wheel/tire size set-up I have...no rubbing.
Orange71 is offline   Reply With Quote
Old 11-11-2007, 11:11:42 AM   #4
Tokyo Torquer3
I also had the same size tire and backspace with a 10" rim and no rubbing (but close to outside lip) and lots of room to move the rim closer inside the wheel well. a 5" backspace would give lots of room all around, especially if she is lowered. I am not sure how 1970SS385 had the tire rubbing on the inside with the backspace he mentions. Must be a typo as the tire would be sticking out the wheel well, and rubbing on the outer lip, with lots of empty room on the inside..
1973 RS Z28: 401ci Dart Little M, Littlefield 8-71 supercharger @14lbs boost, Callies Magnum crankshaft, Lunati Pro-Mod rods, JE pistons, 7.8:1 compression, AFR 227 Comp heads, T&D 1.6 shaft rockers. Reed solid FT cam (240/250@.050, .523/.542 lift, 112 LSA), QFT 750 carbs, Lemons headers, Mezier mechanical water pump, Tremec TKO-500 5-speed, Moser 12 bolt, 33 spline axles & 3.42 gears.
Tokyo Torquer3 is offline   Reply With Quote
Old 11-11-2007, 09:45:18 PM   #5
BACKN73
Should do fine............ran that combo for a long while until I screwed up on my new wheels and got the wrong backspacing w/ 4" instead of 4-1/2"! That 1/2" sucks!
If it doesn't fit- then obviously you're not using a big enough hammer.
If you find yourself in a fair fight, then your tactics suck.
BACKN73 is offline   Reply With Quote
