07-05-2012, 03:40:46 PM
#46
Originally Posted by hhott71
I use slicks and a 350. I've published the combo a dozen times on here.It's in my user info too.
I want to be able to drive the car to the track sitting in traffic and run 11s with a 4 speed. I would not mind changing to slicks at the track but I'm not gonna have room to carry the tires.
How street-able is your combo ?
07-05-2012, 04:43:20 PM
#47
Originally Posted by high impact
For a strong street engine I don't think you could ever beat a pump gas big block with a mild hydraulic cam and good heads. #4 is your best bet for an easy budget 500 horsepower.
same here for me - my combo will be in my 80 camaro - 700R4 and 4.10 posi
and I hope to reach this goal - although I fell in love with roller cams and just cant get over the sound/response
MY 460ci -
.030 454 gm block (not decked) cast crank/ scat 6.385 capscrew
mahle powerpak 28cc dome/1.395 c/h /11:1 (2618 material)
comp. solid roller 254*/262* - 108*-.703"/.703" @ 1.7
Brodix cnc chamber option rect. RR 294cc int. - 114cc chamber
Victor 454R square flange (mild port/gasket match - M.Theroux)
Eq Quay 2inch headers for 82-92 camaro (yes they fit the 2nd gen)
T.K.
85 Camaro
383ci/AFR 210 CNC-65cc/SRPdome/ProSystems850DP/Motown intake/Comp.sld roller/Big Shot plate/TH-350 T-brake/Protorque 8in./4.56 Ford 9in./29.5x10.5x15 - VIDEO Test & Tune night http://youtu.be/X-pGZlp3H3Y
NEW PROJECT-1980 Berlinetta coupe - basic budget resto - 460ci with mahle pistons/Brodix RR's/700R4 - VIDEO Motor fired http://youtu.be/KDUUFRFykGQ[/b]
07-06-2012, 01:07:54 AM
#48
Originally Posted by 973800CamaroRs
Thats great to hear and if I go custom cam it should have an even better outcome. The only question I have is how street able was that car and what octane was the car running ?
That engine went into a 4x4 truck for street use and climbing sand hills.
With a 4 speed car it would be easily street able.
It was run on the dyno. with 93 octane.
Compression was 10.3-1.
1975 camaro
360ci.
291 pocket ported heads1.94/1.5
stock bottom end (cast flat tops)
288/290 108LCA herbert cam
victor jr 750 vac.
st-10 4 speed
10 bolt 4.10 gears
305-60-15 McCreary road stars
07-06-2012, 01:09:23 AM
#49
1975 camaro
360ci.
victor jr 750 vac.
st-10 4 speed
10 bolt 4.10 gears
07-06-2012, 04:29:08 AM
#50
It uses a very streetable HR Crane cam. HR-296-2S-12 IG
Unless you can shift a 4 speed, you can MPH like an 11 second car but only run 12's. or MPH like a 10 second car @ 125+ mph and dabble in the 11's.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
07-06-2012, 08:39:51 AM
#51
I find with a 4spd getting out of the hole is the hardest part(no slicks).
The clutch is the key. Check out the UMTR site.
1975 camaro
360ci.
victor jr 750 vac.
st-10 4 speed
10 bolt 4.10 gears
07-06-2012, 09:40:16 AM
#52
You guys are a huge help. I cant thank you enough, you have made me look at many more aspects than I was at first.
Some more info on the car is 4 speed 3.73 gears, 26 inch tall tire, leaf springs, 275 drag radials (still in the restoration)
I'm only gonna take the car to the track maybe 2-3 times a year. Some years maybe not at all, so I want the car setup for the street but beable to pull on the track and after some practice hit mid 11s.
I want something I can put in the local parades and not have to worry about it stalling out, etc, etc. But at the same time I want to beable to take it to a dyno day and have it lay down 4xx+ numbers at the wheels.
07-06-2012, 10:20:32 PM
#53
Drag radials and a manual trans don't mix. I tried to hook mine unsuccessfully at 4-5 visits to the track before I found out slicks are pretty much a necessity. I was trapping 106-107mph and only running 13.5s.
I am in the same boat as you. My 400hp 355 has been fun since I built it about 7 years ago. Now I want more power. I've got lots of SBC goodies, but the LS idea is calling my name.
80Z build thread
11:1 forged 383 w/ AFR 195s, .575/.584 roller, 1000cfm Accel EFI, T56 6spd w/ SPEC 3+ clutch, Moser 8.5" w/ 4.10s, 12"f/11.6"r disc brakes w/ line lock, Hotchkis springs & sways w/ PTFB stopflex, 18s w/ 255/295 Nittos, Slide-A-Links w/ 275 Mickeys, elec fan & water pump w/ battery in trunk, 4th-gen interior w/ Equus gauges & custom bezel
My Chevy garage GEARHEAD dezign
07-06-2012, 11:28:16 PM
#54
You can take a ride and buy my motor haha. $2500. Has everything you need for that exact power level and you can go bigger on cam if you want... ricky6991@hotmail.com
40 miles on fresh motor. Runs awesome.
406, trw flat tops, dart pro1 heads 64cc/215intake, comp cam 12-250-3, edlebrock rpm intake mani, barry grant 750 dbl pump carb, th400 tranny(no convertor yet), 2900lb car, 3.69 gears.
07-07-2012, 07:04:45 AM
#55
A totally stock LQ4 or even a 4.8/5.3 with some sort of power adder is alot of fun, and great street manner and fuel economy can be retained and likely smoke the BBC.
I did a turbo Lq4 and she would run with my 502 with only 7psi. Never did get to crank the boost up, but could only imagine what 12psi would of felt like. 23 mpg quick tune-up.
I did the turbo lq4 for 7000.00 installed. Engine was only 1200.00 complete shipped to my door with all access and computer/harness, ready to run.
VINCE
1969 CHEVELLE SS
EFI 502/AFR305/224-228 HR CAM
T-56/3.90
11.5/124mph
