Old 07-29-2012, 12:55:18 AM   #46
AJ_72
Originally Posted by EricsZ28
I would think that throttle position (as you have done) is the best indicator of potential air flow. How much travel does the switch have? Can you set this up to open at 1/2 throttle?
With a microswitch, half-to-full throttle is doable. The thin arm that depresses the pin switch is very flexible, with just enough rigidity to have a memory and return to its original position.
http://www.summitracing.com/parts/EDL-72279/?rtype=10
->Click Here<- for an exhaust clip of my car.
AJ_72 is offline   Reply With Quote
Old 07-29-2012, 07:31:45 AM   #47
Z28zz383
That looks very easy to do. Cheap as well. I'm gonna try it, before I burn up my solenoid with the switch hook-up I have now....
81 Z-28. ZZ383 power. Got it new, never selling it! Lifetime project....
Z28zz383 is offline   Reply With Quote
Old 07-29-2012, 03:08:53 PM   #48
rydeer
Be very careful that you don't set it up half throttle and jamb yourself open!! The switch that I used would not be good for half! Use one with a much longer actuator arm.
rydeer is offline   Reply With Quote
Old 11-14-2012, 08:48:06 AM   #49
CDesperado
CDesperado's Avatar
I'm posting this here for future reference. These are the adjustable RPM switches.
MSD 8743 chip kit... this is a kit with 5 different chips. Each chip is designed for a different RPM setting, in 200 RPM incremenets. It contains different chips for 3000, 3200, 3400, 3600, and 3800 RPMs.
You can buy these in lots of places, including O'Reillys, SummitRacing, Amazon, etc.
1978 Camaro Restoration.
There is always a better way. Find it. (Thomas Edison)
CDesperado is online now   Reply With Quote
